Question about Refrigerators
I have a Electrocool Model GR-382R upper freezer and lower fridge and the fridge part will freeze after about 2 weeks. If you unplug it for a day and plug it back in it will work fine for another 2 weeks.
    Genius:
  • Refrigerators Master
  • 1,669 Answers
If there is a vent control in the freezer unit, it allows cold air to fall into the refrigerator below. How you regulate those vents will affect the temperature below. If yo put a thermometer in the lower section you could adjust the vents to get the desired temperature below...37degrees Farenheit is good for the vegetables in the cold drawers...
Posted on Jan 11, 2013
    Top Expert:
  • 41,697 Answers
Probably a defective temperature control
  • pete Jan 11, 2013
    Can I get the part at a a local repair shop or do I take the fridge to a shop
I have LG Electrocool GR-252SQ(Double door).the freezer is very cool but the lower fridge section is not getting cool.Plz guide.
i have same fridge and my problem is that the water from freezer is not going out pf the fridge, instead it comes down to fridge section through condensation
Mar 24, 2013 | Refrigerators
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
Hello i have an lg refrigerator GR-620RW which
LG 620 RW water in fridge below crisper problem.
The issue is most likely a blocked condensate drain line at the back of the freezer. The purpose of the drain line is to take away the water from the end of the defrost cycle.
Task time, approx 2 hours.
Unplug fridge.
Empty out the fridge, let warm up & remove the back panel of the freezer. There is a 3" x 4" snap in door at the upper left corner of the back panel with a round snap in cover. Remove the snap in cover & remove the screw to take out the 3" X 4" panel, gently pull out the back panel from left to right. There is also an elect connector to the fan on the upper right corner, unclip this. The drain is at the back in the centre, it will likley be blocked with 2 or 3" of ice. You can let it melt or sparingly use a hair dryer on it, do not over heat or damage the coil/fin assembly. The fridge will continue to drip water for a day after the drain is cleared if the water has rin inside of it for any period of time.
There is also a fan/control assembly in the refrigerator section held up by 2 screws & snaps. This should be dropped down to ensure there is not ice buildup in the vents to the freezer or water inside it.
Finally, make sure you run warm water down the freezer drain tube to the pan underneath the fridge, this is accessible by taking of the rear compresser cover behine the frigde. Ensure the lower drain line is clear & back on the locater peg.
Of course if you want to do this the easy, & have the time, leave the fridge open, unplugged for 2-3 days & the ice will all melt.
Good Luck
Jun 12, 2010 | Refrigerators
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
I have electrocool LG MOdel# GR-382R ser# 206MR17803. my bottom fridge cooler area is freezing up.
I have the same problem.It seems that the gasket around the freezer door and fridge door are no longer tightly adhering to the fridge therefore allowing the cool air from the freezer to continiuously entering the fridge storage and making evreything freeze up. I am trying to find out if I can purchase new gaskets and install them myself.
Any recommendation on where to find these and how to install them?
Thanks.
Jun 22, 2009 | LG Refrigerators
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Refrigerators Logo
162 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
