Question about Panasonic KX-T7730 Corded Phone
I have panasonic kx tes824. i assumed that CO2 and CO3 are not asdsigned
I CAN only CO1 in making calls. (outgoing and incoming)
3 Suggested Answers
cnavarro
  • 2460 Answers
SOURCE: we have the panasonic KX-TA 824 with the 3CO x
By calling the telephone line provider or going into the web interface and using Call Forward Busy to CO2 and CO3. Normally, hunt groups are established by the telco or the "poor man's way" with CF-B.
Carl
Posted on Feb 18, 2011
cnavarro
  • 2460 Answers
SOURCE: How to program ring tone
Analog Panasonic phones have one "ring tone". You program it to ring or not ring, but the tone is exactly the same. Ringing programming is in SYSTEM programming in the 40x's, depending on the cabinet. In a TA series, inbound ringing is program 408 409 and 410.
Carl
Posted on Jun 15, 2011
CO problems
Check your Phone if connected to Jack 01 to do programming below:
on KX-T7730 phone Press Program *# (enter Password) default is 1234
Press 400 SP-Phone(CO NO.? will be displayed) Press *(Mixed or Connect will be displayed), Press AUTO ANS/MUTE untill (NOT Connect will be displayed) Press AUTO/STORE. Press HOLD(SYS PGM will be displayed) Press 400 (CO Connection will be displayed) Press SP- Phone(CO NO.?) Press SP-Phone (Not Connect will be displayed) Press AUTO ANS/Mute until (Connect will be displayed)Press AUTO/STORE PRESS PROGRAM to return to NORMAL Display.
For the incoming Calls PRESS Program *#1234 (ENter Sys PGM will be displayed) PRESS 408(Day IN CO will be displayed) Press SP Phone (CO No? will be displayed) Press SP Phone (CO1:#01:DISABLED if this is displayed PRESS AUTO ANS/MUte the Enabled will be displayed) Press AUTO/STORE. Press Program to return to normal display. In this Manner All Calls will ring to extension which is connected to Jack 01. you dont need to press the button anytime there is an incoming call.
Dec 04, 2013 | Panasonic KX-T7730 Corded Phone
By Default Panasonic - 824 CO1, CO2, CO3 are working. now i add 2nd card How can i assign CO4, CO5, CO6?
Lines are assigned in program 400. Normally, they are assigned by default so someone had to work very hard to unnasign them even though you didn't have the hardware.
Apr 01, 2013 | Panasonic KX-TA824PK Phone
Determining which CO you get when pressing 9
Set outgoing line preference.
Or simply swap the CO1 and CO2 line plugs.
The plug from your service provider that enters in CO1 put it in CO2 port and vice versa.You may need alittle config as well.
Oct 26, 2012 | Panasonic KX-T7730 Corded Phone
How to program ring tone on KX-T7730 for each CO? For example I want the inbound call on CO1 and CO2 to ring differently, and for the call for CO3 not to ring ... thank you !
Carl
Jun 15, 2011 | Panasonic KX-T7730 Corded Phone
I had a KX-T7730, i have 2 line and use to be store as CO1 & CO2.. then other time when i try to store a speed dial.. everything got mix up.. now when i colleague hold a call, i can't pick up the call...
From the idle phone, press PROGRAM the button where line 1 used to be and dial 0 1 STORE do the same for line 2 if you unprogrammed that, using 2. Press PROGRAM or pick up the handset and drop it back down to end programming
Carl
Apr 18, 2011 | Panasonic KX-T7730 Corded Phone
We have the panasonic KX-TA 824 with the 3CO x 8ext we have disa on on CO1. We are trying to route the incoming calls to CO2 & CO3 to live the main number available. How can we acomplish this.
Carl
Feb 18, 2011 | Panasonic KX-TA824PK Phone
I have PBX Tes824, Main phone kx-t7730 When it income call my office all phone ringing. Help me my english bad but i mean.
to ring only at extension 101 and 106,you can do this press *# 1234# press 408 speaker phone CON. press * CO1. Enable press right arrow key from 7730 phone CO2. mixed CO3. mixed CO4. mixed CO5. mixed CO6. enable press Auto dial store thats it
Sep 13, 2010 | Panasonic KX-T7730 Corded Phone
I need help programming the phone to pick up CO1
This is a guess because you still didn't tell me what system you're connected to. On an idle phone, try pressing PROGRAM 131 STORE. In a TA-824, that makes you select line 1. If it's busy, nothing happens.
Carl
Nov 19, 2009 | Panasonic KX-T7731 Corded Phone
Two phonelines no longer accessible. Using Panasonic KX-T7730 with a Panasonic KX-TES824 system. Lines were working fine and have now disappeared. They don't ring in and I can't ring out on them. ...
This is most likely a service provider issue. If these are analog lines, take a regular phone, not a Panasonic system phone, and plug it into wherever the CO1 CO2 CO3 lines go into the cabinet. If they work there, you have a system fault (not likely). If they don't you have a line problem.
Make sure that you plug the phone into the lines coming in, not into the cabinet :-)
Carl
Oct 09, 2009 | Panasonic KX-T7730 Corded Phone
I HAVE STILL GOT ALL THE SPEED DIAL NUMBERS IN MY TELEPHONE BUT SEEM TO HAVE LOST THE OUTSIDE LINE TO CALL ANYBODY, ALL I GET IS co NOT ASSIGNED, CAN ANYBODY HELP ME THROUGH IT?
If your 773x phone is connected to most Panasonic systems, you can press PROGRAM and the place where lines are supposed to be assigned and it will tell you what's under the button with names like CO1, CO2, CO3 etc.
If it says something else, you can make it become outside line access buttons by the command 0+a number 1,2,3 and STORE.
You can do all 3 buttons at once, just keep pressing them and dialing the sequence with a STORE. After you've finished, just pick up the handset and drop it back down to end programming.
Carl
Apr 22, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
63 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
