Question about Canon imagePROGRAF W7250 InkJet Printer
How do you change the ink tanks in a canon image prograf w7250?
    President:
  • 2,692 Answers
The website does nnot show the 7250 but does show two other w models. Maybe the manual for one of those wil show how to change the tanks.(see guides and manuals).
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=260&modelid=11264#DownloadDetailAct
Posted on Jan 22, 2009
Hardware error 03130031-2618
Mario, Re POST , make, model #, and complete question so we can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 04, 2016 | Canon Office Equipment & Supplies
Cleaning kit print head canon Image prograf 710
I have always cleaned prinheads leaving them on a saucer with warm water for some time. Preferably, deionized water if it is a problematic printhead. I expect the cleaning kit is something of the sort. But Canon ipf 710 seems to have a fixed use time, having the printer rejecting the printhead after exacly one year use even if it is in perfect conditions. Try to make print test in service mode before you use up all your ink in useless cleanings.
Jul 01, 2014 | Canon imagePROGRAF IPF710 Printer
My Canon Image Prograf iPF700 keeps running out of color ink even through all setings are on Black and White (Monochrome). Any suggestions, getting sick of paying for ink im not using.
I you see in the preferences of the printer you have 2 kinds of monocrome( check de advanced option) one uses the all the colors to print in black if you use the second monocrome when you print its not black its more like brown. but this way you dont use de colors inks
Apr 19, 2010 | Canon iPF700 InkJet Printer
No ink is getting to printhead in imagePROGRAF w7250
Your printheads are indeed clogged. (Note: all ij printers should be powered off when not in use! This retracts & seals your printheads.) Now, on to your problem. In your printer software, there should be a maintenance section. In there, you need to clean the printheads - this may have to be done *many* times - like 10-ish to clear (if still possible) clogged ink.
Hope this helps.
Cheers,
gurutim
Mar 19, 2009 | Canon imagePROGRAF W7250 InkJet Printer
I did not see that there was a response on Apple's support site that adds to the previous post I mentioned. Combing the steps from the two posts, I was able to get our W7250 to print from Mac OS X 10.5 Leopard.
Here are the steps I took to get a networked Canon imagePROGRAF 7250 to work with a Mac running Leopard :
1. Download garo34 print driver from Canon's support site here.
2. Download the iPF610/iP710 Leopard print driver from Canon here.
3. Double-click on the garo34_osx.hqx file that you downloaded.
4. A folder named Driver is created; open it and double click on "GARO Installer for X".
5. Enter a name and password of an administrator account on your Mac and click OK.
6. When the GARO Installer for X window appears, click on Continue.
7. Click Continue.
8. Click Continue.
9. Click Agree.
10. Click Install.
11. When the installation is complete, click on the Restart button.
12. When your system has restarted, double-click on the iPF610_710_Driver_OSX_10.5_Ver1.10.hqx file you downloaded.
13. A folder named iPF610_710_Driver_OSX_10.5_Ver1.10 is created; open it and double-click on "iPF Driver Installer X".
14. Enter a name and password of an administrator account on your Mac and click OK.
15. When the iPF Installer X window appears, click on Continue.
16. Click Agree.
17. Click Install.
18. When the installation is complete, click on the Restart button.
19. When your system has restarted, click on the System Preferences icon on your Dock or select System Preferences from the Apple pull-down menu.
20. When the System Preferences window appears, click on the Print & Fax icon.
21. Click on the + Button underneath the Printers column.
22. Another window will appear; click on the "More Printers" icon.
23. A drop-down window appears; select Canon IP (GARO) from the pull-down menu if not already selected.
24. In the "Printer's Address:" field, enter the IP address of your Canon W7250 printer (e.g. 192.168.1.2).
25.In the "Queue Name:" field, enter a name for your printer (e.g. W7250).
26. Click on Add.
27. The W7250 is now your default printer. If you want another printer to be the default, change it in the Print & Fax preference pane.
Voila!
I hope this solves your problem and you found the instructions helful.
Mark
Jan 09, 2009 | Canon imagePROGRAF W7250 InkJet Printer
Canon W7250 keeps prompting to change cartridge
First make sure you are using a genuine Canon cartridge. Use the printer utilty to clean the cartridges; it's found in your printer software program under utilities or maintenance..Hope this helps...
Mike
Nov 18, 2008 | Office Equipment & Supplies
Upgraded to Leopard and now need to update my printer driver
Canon will not be coming out with a Leopard print driver for the W7250.
However, here are the steps I took to get a networked Canon imagePROGRAF 7250 to work with a Mac running Leopard:
7. Click Continue.
8. Click Continue.
9. Click Agree.
10. Click Install.
16. Click Agree.
17. Click Install.
26. Click on Add.
Voila!
I hope this solves your problem and you found the instructions helpful.
Mark
Sep 11, 2008 | Canon imagePROGRAF W7250 InkJet Printer
Switching Off Ink Level Detection
Turn off the machine.Put a new one cartridge without doing anything else and turn on again
Jan 14, 2008 | Canon imagePROGRAF W7250 InkJet Printer
Canon imagePROGRAF W7250 InkJet Printer Logo
97 people viewed this question
old marine
old marine
