Question about Kenwood KAC-5201 Car Audio Amplifier
Instalation Is it possible to get wiring instructions for kac 5201 as I bought one from e-bay had everything except how to wire it in thank you
  • boomdogg0702 Feb 14, 2009
    what gage wire to use to hook up to battery
  • 432 Answers
Everything is possible around here! http://www.kenwoodusa.com/support/simple.aspx?men=2&M2=69 http://www.jigsawmanual.com/manuals/mfg/kenwood/kenwood_kac_kac5201.html Good luck :)
Posted on Jul 03, 2007
Need Wiring diagram for Kenwood amp #KAC-501
Installation instructions begin on page 9 of the manual.
Oct 16, 2012 | Kenwood Car Audio & Video
Ive just installed two 12in kicker cvr's and i bought the kenwood kac 7205, and ive hooked up everything right and used a digital multimeter to check that the current is coming throught but the amp...
So you check the remote wire to make sure there is 0.5amps running through it, right? Check the fuses of the amp? Checked your ground? Hope this helps
Aug 22, 2011 | Car Audio & Video
How do i get this amp to workin an Oldsmobile Intrigue with a factory radio?
you need a hi-lo adapter and that hooks up to the right or left rear speaker then the remote wire needs to go behind the deck to the ignition wire. if the system is pre amp then you have to bypass the amp system
Aug 03, 2010 | Kenwood KAC-5201 Car Audio Amplifier
How to switch on Dell PS-5201-7D
Just ground to grey wire and power is on.
Oct 12, 2009 | Dell - PS-5201-7D (PS52017D) Power Supply
Where do i connect the power control wire to ? I have a kenwood amp kac 7202, I'm connecting it to a stock cd receiver in toyota corolla 2004
Hello sophnettliss,
Most stock receivers do not have a dedicated amp remote lead and your 2004 Corolla is no exception.
The amp remote can be connected to any switched and fused 12V + source including the OEM receiver accessory wire which is the gray wire in your receiver harness.
Hope this helps.
Oct 02, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Wiring for kac-622 car audio amplifier
http://www.retrevo.com/support/Kenwood-KAC-622-Amps-manual/id/479bh233/t/2/
Jun 12, 2009 | Kenwood KAC-749S Car Audio Amplifier
A red light is flashing
On the top? is it your power protection light?
May 26, 2009 | Kenwood KAC-5201 Car Audio Amplifier
Kenwood kac-5201 amp
12 VOLT FROM THE BATTERY SOURCE GOES TO 12VOLT BATT CONNECTION.12 VOLT GROUND RETURN MUST BE FIXED TO THE FRAME OF THE VEHICLE.SOME VEHICLES HAVE FACTORY GROUNDS UP HIGH ON THE SIDES OF MOST VEHICLES, U CAN USE THIS GROUND LOCATION. IF CONNECT REMOTE WIRE FROM THE RADIOS REMOTE TURN ON LEAD WHICH IS A BLUE/WHITE WIRE OR A STANDARD BLUE IF ITS JUST ONE BLUE WIRE. CONNECT THIS LEAD TO THE REMOTE TURN ON CONNECTION ON THE AMP , SOME KENWOODS HAVE TWO ,INPUT AND OUTPUT LEADS.U ALSO NEED A TEST LIGHT, OR U CAN USE A SPEAKER TO TEST FOR POWER AT UR CONNECTION.IF U USE A TEST LIGHT , CLAMP THE END U WOULD GROUND TO THE VEHICLE, TO THE AMPS GROUND, THEN TOUCH THE PROBE END OF THE TEST LIGHT TO UR WIRED CONNECTION TO VERIFY U HAVE POWER AND GROUND TO YOUR CONNECTION.IF TEST LIGHT DOESN'T WORK ,CHECK UR FUSE AND REMOTE TURN OR LEADS.
Sep 02, 2008 | Kenwood KAC-5201 Car Audio Amplifier
Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Apr 03, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Kac 7285 kenwood amp
Hi Steve,
Do you have wiring harnesses for the amp? If so write me and I'll instruct you in the proper wiring color codes for each souce.
Ed
NC Electronic
Mills, Wyoming
Jan 29, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood KAC-5201 Car Audio Amplifier Logo
116 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
