Question about Dryers
I need a door seal for creda debonair compact reversair tumble dryer
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: No hot air from my tumble dryer
Hi.
You do not state whether it is a condenser or vented dryer.
the most obvious reasn for no heat is element and/or stats..
The only way to confirm which it is-- is to meter them out with a multi meter..
If you have one then set it on the ohms range and test the components for continuity, you should get full scale deflection if they are o/k.
You must disconnect the wires to the components, or you will get a false reading, and needless to say, have the m/c unplugged.
If all test o/k then the problem could be with the timer and or control unit, or the heater relay if it has one.Unknown to me as I do not know your model number.
If it is a condenser dryer, make sure all filters are clear, air intake and outlet vents clear, water container empty .
Plz rate my solution
Thanks
Posted on Dec 29, 2008
  • 491 Answers
SOURCE: creda tumble dryer T632CW is not heating up. Any
SOUNDS LIKE YOU NEED NEW HEATING ELEMENTS.
Posted on Oct 18, 2009
  • 3600 Answers
SOURCE: My creda reversair dryer no.37642 doesn't rotate,
Most likely the drum belt is broken or the tensioner is broken this is not to expensive to fix and the belt can be bought at any applince store.
Posted on Mar 10, 2010
  • 3074 Answers
SOURCE: creda compact 3 37301 tumble dryer pull down door.
I would suspect thermal fuse, easiest way to test is to tape wires together and start dryer. Safety note if left like this it will start a fire. It is located on the back of the dryer and has two wires connected to it. Here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Usually, failure of a thermal switch is caused by extreme heat: meaning that the dryer is not venting properly, clean dryer of lint inside and outside as well as the vent tube. Good Luck Tim
Posted on Dec 17, 2010
IS A cREDA SENSADRY COMPACT TUMBLE DRYER A RISK LIKE THOSE IN THE NEWS, PLEASE/
the creda web site gives a list of all affected dryers........cheers
Oct 14, 2016 | Dryers
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
Hi the door catch for my Creda T522VA Simplicity dryer has broken - where can I get a replacement?
http://www.espares.co.uk/parts/tumble-dryers/doors/creda/t522vw/p/1580/720/0/423760
hope it helps
Jul 05, 2010 | Dryers
I changed the belt on my Creda tumble dryer. Now its making noise
You may have to change the Guide wheel that the drum needs to rotate on
Sep 06, 2017 | Dryers
My creda reversair dryer no.37642 doesn't rotate, although there is heat in the drum. What could be wrong with it?
Mar 10, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Creda debonair spin dryer lid not opening.
The lid had been fixed for delivery.Now it is opening OK thanks.
May 01, 2009 | Washing Machines
Hi.
Thanks
Dec 29, 2008 | Dryers
Creda Reversair Sensa Dry Tumble Dryer produces no heat.
There is only 1 heater element, and normally one thermostat.
they are located at the rear of the m/c, behind a removable panel.
If you are not sure whether it is the element or stat, join the two
wires togeher that go to the stat, if the heater then works, replace stat. if no heat, replace heater.
plz leave feed back for this solution.
Thanks.
Dec 17, 2008 | Dryers
Dryers Logo
Top Dryers Experts
