Question about Roper MHE14XKB Microwave Oven
Loud fan when microwave model MHE14XMQ is in use
I am wondering if there is a setting or a jumper that changes the fan speed on the model MHE14XMQ microwave. The fan runs like it is on very high speed when the microwave is in use. I am sure this is not normal.
  • Roper Master
  • 19,396 Answers
The fan is controlled by control board behind keypad. Replace fan motor first, if that does not help replace control board.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
What is the loud noise?
What kind of noise? Is it high speed fan? or rotating motor? Please describe!
May 02, 2014 | General Electric Ge SCB2000F 950 Watts...
Whirlpool microwave fan not working
I would unplug the oven for 2 minutes to do a hard reset and try it again, just in cause there was a glitch.
Without knowing your full model number from the tag on the oven, I would wonder if it has a separate internal cooling fan from the hood vent exhaust fan. It could be an unrelated issue.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | Microwave Ovens
I've purchased the Whirlpool Model #: WMH73L20AS microwave and the venting fan not working (well). The intake under the microwave into the filter can be barely felt, but on the top part of the microwave...
I just returned mine.... I had 7 (SEVEN) service calls coming out for it.. and they tried everything to stop it from overheating...and shutting off... and finally after 4wks we called it quitts. its a venting design problem... inside the unit...
Aug 17, 2013 | Whirlpool Microwave Ovens
The fans on this microwave will automatically turn on when I have more than one burner on the gas range going. The fan is horrendously loud and will not allow me to shut off for 2-3 minutes regardless if I...
That's typically normal operation. The microwave has a thermostat which turns on the hood vent exhaust fan at a certain temperature to protect the controller.
Your owner's manual will cover vent fan operation.
If for some reason you don't have yours, you can download Whirlpool owner's manuals and installation instructions here.
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If - above and beyond this - the fan has a problem, that could make it excessively loud. Some are just loud though, it's hard to judge without actually hearing it.
You can contact Whirlpool customer service with your model number via that link above and ask them about the loudness. They may be able to tell by listening over the phone if it's abnormally loud.
Apr 28, 2011 | Whirlpool MH7130XE Microwave Oven
Model:MHE14XMQ-3 light not working even with new bulb. Is there a fuse?
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 02, 2010 | Roper MHE14XKB Microwave Oven
How do I remove the wall whirlpool combination of their microwave and oven?
Whirlpool customer service is here and you can enter your model number on that page to download your owner's manual, installation instructions, etc.
The installation instructions will show you how it went up and that will help when you remove it.
Nov 25, 2008 | Microwave Ovens
F6 error... microwave not working
is the microwave itself working? because same thing happened to us apparently the guy who changed the bulb didnt unplugg the thing first and well it burned a part of the circut board cost us about 90 dollars to fix it.....
Oct 05, 2008 | Roper MHE14XKB Microwave Oven
Roper Microwave (mhe14xmq dec. 2003) trips breaker...
you might have to reset your your power settings on the micro.
Sep 21, 2008 | Roper MHE14XKB Microwave Oven
Microwave makes a loud noise while using.
Could you describe the noise?
It may be a noisy fan motor or a failing magnetron or high-voltage transformer.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 13, 2007 | Microwave Ovens
Roper MHE14XKB Microwave Oven Logo
134 people viewed this question
Top Roper Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Roper Microwave Oven Expert? Answer questions, earn points and help others
