I need to move from field to field using trackball or right side of keyboard.
SOURCE: TrackMan Marble FX MouseWare
I have the mouseware 7.0 and 8.2, (i forgot that was the original), but own 2 trackman marble Fx and love it but like everybody else cannot use the 4 buttons as before and window Xp refuse the application version 7
SOURCE: mouse won't work 'cause program is not installing
First you can go to the www.microsoft.com website and type in "keyboard al shortcuts and hotkeys". You will get a listing of all the things that you can do with the keyboard that you could that you were able to do with the mouse. Then take the mouse back since it is not compatible with your operating system and exchange it for one that is compatible. That information is usually on the package.
Don't forget to rate this solution before you log out.
SOURCE: Logitech marble trackball slips
try taking a slightly moist rag and cleaning the ball. that should take care of it.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: Where can I order a replacement marble for a logitech marble trac
Contact Logitech directly, nobody else will provide spare parts for it but them.
SOURCE: Logitech Marble Mouse driver/setpoint messed up my synaptics touchpad on my laptop...can't fix this!
Please uninstall any logitech software version present on your OS (if available) -
Then please proceed to clean boot.
( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 )
-> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if
possible rather than a cordless device.
-> Go to device manager
-> Delete all the USB HOST CONTROLLER -- All of them --
-> The host controller might reinstall them itslef, let the computer handle the reinstallation
-> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for
new hardware " ( The computer with magnifier icon )
-> Once reinstalled, clean boot
-> Reinstall the software if available and/or plug the hardware when needed.
-> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect
the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware
failures are covered by warranty terms
US/Canada support:
http://www.logitech.com/en-us/contact
European support:
http://www.logitech.com/en-gb/contact
Thanks and have a nice day !
J -
Program it to do what?
