49.4c01 error hp4345 - Office Equipment & Supplies
2 Suggested Answers
  • 300 Answers
SOURCE: Fuser error 50.2 HP4345
You will have to replace the fuser assembly (the error refer to the fuser warm up temperature)
Posted on Aug 11, 2008
Config page on hp4345 without menu button
You would need to log into the embedded webserver to view the configuration page. From there you could screen capture it as I do not believe that the print config page was added until later models.
Oct 31, 2014 | HP LaserJet 4345mfp Printer
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Hp4345 51.10 error i have replaced the laser unit, dc controler board, engin power supply and the pfc power supply, the 2 cables from the llaser to the dc controler
It's still a laser beam detect error, you need to make sure the safety shutter is opening when the door is closed. It blocks the beam from your eyes and also the beam detect sensor. If all is good, you could have gotten a defective laser.
Nov 09, 2009 | HP LaserJet 4350 Printer
HP4345 MFP printer and the print quality is fuzzy. I put in a new toner cartridge and that didn't work and i also created a cleaning page and that didn't help. what next? just had the tech out here last...
Fuzzy print is mostly related to 3 items in your printer. 1 the toner cart. 2 fuser. 3 transfer roller. A fuser replacement is a normal fix for this problem. Check your PM kit status by printing a supplies status page. A PM kit will have a fuser, transfer roller and feed rollers. If the PM level is low ,order and replace kit. If not you may want to get a new fuser
Sep 23, 2009 | HP LaserJet 4345mfp Printer
Modem fail errors between hp 4345 and savin mfp device
On fax settings set ECM to ON, JBIG to OFF, MAX BAUD RATE to 14.4, V34 to OFF then upgrade to latest firmware and make sure phone line is a 2-line phone line (look plug end of line and there should only be 2 metal strips on connector)
Mar 26, 2009 | HP LaserJet 4345mfp Printer
Aug 11, 2008 | HP Color LaserJet 3500 Printer
Offline
Hi There,
I think this may be something Win 2K is doing.
However, rather than power cycling the printer, simply removing the USB connection then replacing it should be enough to 'wake it up' (and save on dye film).
Check the power saving settings for your USB Root Hub;(Hardware/Device Manager/USB Controllers/ USB Root Hub/Properties/Power Management). Make sure the 'Allow the computer to turn off this device to save power' option is NOT ticked.
Check also under 'Settings' / 'Printers', right-click on 'Magicard Printer Series', you should NOT see either 'Resume Printing' (printer is paused), or, 'Use Printer Online' (printer is offline).
Also, make sure you have the latest drivers installed. The Rio 2 / Tango 2 driver V6.01 is compatible with the 'older' Rio / Tango printer (even the non 'NP' models). You can download this here;
Make sure though that you select 'update driver files' and NOT 'add a printer' when prompted (restart is required). Port name should be 'NUSB01' when you see the list of available ports.
I hope this helps.
Regards,
MC.
Mar 11, 2008 | Magicard Rio Card Printer
61 people viewed this question
k24674
jasbo
jasbo
