Question about Jura Capresso CoffeeTEAM GS 46405
Capresso 464 will not heat and pump the water
I can grind the beans alright but then the water does not heat and pump thru the grounds.
  • 123 Answers
SOURCE: jura capresso E8
Did it work before this?
Sometimes hard water can build up and cause blockages.
Try mixing hot water and white vinegar (50/50 mix) and try running it through the machine. If this works, run it through a few more times than run cold water through a couple times to get rid of the vinegar.
Good Luck.
Posted on Apr 10, 2008
  • 14 Answers
SOURCE: unable to make coffee automatically using whole beans
The rivets in the back of the Jura Capresso units are actually oval security screws. The bit that removes these screws are made of a very hard metal and cost me over $50.00 two years ago. Also many people who attempt there own repairs tear off the little plastic tabs that keep everything together nice and tight. We repair Jura Capresso Krups Bosh etc. www.hotncold.com
Posted on Aug 03, 2008
z34aga
  • 137 Answers
SOURCE: Water in the drip tray of coffee machine
take out the mecanism and clean it how is instructed in manual, than get it back carefuly. Pay attention on position of mecanizm.
Posted on Mar 28, 2009
  • 13 Answers
SOURCE: Where can I find an Jura Capresso Impressa F9 replacement lid
The only sources I have been able to find are in Europe. They do not always wish to ship to the US however. In the US the dealers always want the repair, but seldome wish to sell parts outright. Try this website for parts.
Mike
www.juraprofi.de
Posted on Jul 05, 2009
news775
  • 699 Answers
SOURCE: RE: F9 Upon startup the unit
Hi Bill
What happens when you do a tea ? (hot water only, NOT the steam button) do you also get little water ?
The fact that you are getting steam is good as there are 2 heating systems in the unit.
Have you ran the descaling recently (if you do not use filter ) ?
If you have or use a filter the problem is likely to be at the rear of the machine, however the back contents all the power and you will need to be happy to do some stripping down of the machine,
In the back you have the pump, valves, heater etc.
I am just about to draw up a flow chart of the water system inside the machine and have it published online (couple of days).
Are you happy to strip machine down ?
Please dont forget to vote if you liked my answer
thanks
Posted on Feb 12, 2011
Why does ground coffee not go thru shoot
If using Beans; it is set to fine and due to static it sticks - OR you have a blockage..
If you are putting ground coffee into a grinder; the static will be a bigger issue and in addition there is no weight from the beans to press the grinds into the burrs. A bean grinder is not ment to grind beans that have already been ground.
Get a better grinder and do not buy supermarket beans.
May 31, 2014 | Capresso 560.01 Infinity Burr Grinder,...
The lights come on but the water does not come out
2 things descale the unit as per user book or make the grind coarser. this is done in or near the coffee beans container. turn the knob in the direction of the larger dot or bean symbols
Feb 25, 2014 | Jura Capresso Impressa E8 Espresso/Coffee...
I have a Capresso CoffeTEAM GS # 464. I decalcified the machine in the last several weeks with Durgol and replaced the water filter - have done this every 6-8 weeks for the life of the machine. I had...
Hi
Probably an internal Element has gone open circuit.
Machine is smart & senses not heating up so don't let water through.
Mine did the same thing. So I pulled it apart (with photos)
Found the heater element (Open). Found a replacement element after 6 weeks and replaced it in 2 hours.
Back to getting great coffee.. Ahhh
Aug 14, 2011 | Jura Capresso CoffeeTEAM GS 46405
RE: F9 Upon startup the unit goes thru the normal cycles for making an expresso but, after the beans grind, little to nothiing is dispensed. The unit stops and the message is to fill water portion. I push...
Hi Bill
thanks
Feb 12, 2011 | Jura Capresso Impressa F9 Espresso Machine
It grinds the beans, but just a trace amount of coffee is brewed and drips out.
My F9 started with the "Fill Beans" routine even though there were plenty. The grinder started making a high-pitched noise, which Capresso's customer service told me was indicative of something being stuck in the grinder (like the stones mentioned in the manual).
Their suggestions ranged from vacuuming out the grinder to blowing compressed air into it, to "burping" the machine -- which they describe as hitting it mildly while grinding. Kind of a Heimlich maneuver on the thing.
Still no success, but I did turn the unit upside down a few times and shook out a *lot* of coffee grounds. This led me to believe that the grinder was still working, but something was blocking it down low. So I ran the cleaning cycle twice, and voila, coffee again.
An interesting aside was that the first dump from the first cleaning delivered the usual grounds but also some more pasty-like remains, and pretty dirty water. The dump water from the second cycle was very clear. This is a testimonial to the efficacy of the cleaning process. If you don't do this when the machine requests it, you are running the risk of gumming it up. I know (now); I had been ignoring the request to clean it for about a week and a half...
Dec 26, 2009 | Jura Capresso Impressa F9 Espresso Machine
The machine says FILL BEANS but beans are in it...yes, we did run out of beans but now it won't recognize beans. we cleaned it out, grinded , etc...but it still says fill beans. We also rinsed many times,...
Hi
Oily beans (shiny) can some times stick together after grinding with a fine setting. Try opening the grinder setting to the very coarsest setting and see if it will clear the passage. If you have pushed the brew button an lot of times you may have packed the grounds in the passage which will have to cleaned manually.
Once you have the grinder working again, open it to the coarsest setting to clean the burrs. 1 time is enough. To turn the grind setting back down to your setting make sure that the grinder is running at that time. You can open to a coarse setting any time but it has to be running to finer.
Oct 25, 2009 | Jura Capresso Impressa S9 Coffee...
Mar 27, 2009 | Jura Capresso Coffee Makers & Espresso...
Beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Unable to make coffee automatically using whole beans
One thought is to call Capresso for the recall to fix electrical cord. They will pay shipping both ways and fix any problems for free as part of the recall. Worked for me, might be too late now but worth trying.
Nov 17, 2007 | Jura Capresso C1000 Espresso & Coffee...
Jura Capresso CoffeeTEAM GS 46405 Logo
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
