Question about Philips CDD 522 1X External SCSI-II CD Recorder (CDD522) (CDD522) Burner
CDD 522 Windows XP - Philips CDD 522 1X External SCSI-II CD Recorder (CDD522) (CDD522) Burner
Why won't the hard drive activate on my acer aspire one 522, the bios can see it.
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time. http://www.fixya.com/support/r4482455-repair_windows_xp
Apr 05, 2013 | Computers & Internet
Ordinal 522 could not found
You probably have the S.M.A.R.T. virus. Bring it to a PC shop that specializes in virus/malware removal for a set price. This virus infestation is serious trouble.
However if you feel you can fix it on your own. Check for viruses and malware. But be warned the S.M.A.R.T. virus is extremely difficult to completely remove and you'll need to restore all your icons as well.
Boot your computer into "safe mode with networking" by pressing F8 several times at startup until the boot screen comes up. Then select "safe mode with networking".
Once you're up and running: You can get good FREE anti-virus and anti-malware apps from here:
http://majorgeeks.com/
Jun 10, 2012 | Microsoft Windows XP Professional With...
How to set up wireless printer on windows 7 net book
I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home > Printer Wi-Fi Setup Setting up a Printer Wi-Fi Network Using the Control Panel Using the Wi-Fi Setup Wizard with LCD panel WPS setup You can set up a Wi-Fi network for your printer by using the printer's control panel. Using the Wi-Fi Setup Wizard with LCD panel If your printer has an LCD panel, you can use the Wi-Fi Setup Wizard to simplify manual setup. mark_no.gifNote: This setting is not available for all printers or may not be enabled. Make sure that the Wi-Fi is enabled on your computer in advance. Check the SSID and password for your network as these are required during Wi-Fi setup. If you do not know the SSID and password, check with your network administrator. For step by step information on setting up a Wi-Fi connection using the Wi-Fi Setup Wizard, click the following link. This feature is not available for all printers or may not be enabled.
exlink.gif../p_body/panel/wizard/manual_01.htm
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
May 30, 2012 | Computers & Internet
Please help!! my dell latitude d620 fails to boot displaying: YVFXP is compressed press Ctrl+Alt+Del to restart. When i do this it jus does the same thing.
Ifyou have compressed the hard disk drive using the Compress drive to save disk space option under the Propertiesmenu for your hard disk drive and have performed a non-destructive recovery ora system recovery, the following error message may appear: NTLDR is compressed. Press CRTL-ALT-DEL to restart. This error message is resolved byfollowing these steps: 1. Insert the Windows XP CD drive onthe computer and restart the computer. 2. Press F12 when the computer firststarts, then select CD-ROM, click any key to boot into windows startup. 3. When you get to the install windowsXP screen: 4. Press Rto repair the Windows XP installation using Recovery Console. 5. Enter the appropriate number for theWINDOWS installation, for example, the WINDOWS installation could be listed as 3:C:\WINDOWS or 3: D:\WINDOWS . 6. If prompted, enter yourAdministrator password and press Enter . If there is no password, justpress Enter . 7. At the prompt, if the WINDOWSinstallation you selected in Step 4 was C:\WINDOWS, type: cdc:\ Or, if theWINDOWS installation you selected in Step 4 was D:\WINDOWS, type: cdd:\ 8. At the prompt, type: attrib-c ntldr and thenpress Enter . 9. At the prompt, type: exit 10.Press the Enter key and immediately remove all discs or diskettes from thecomputer to allow the computer to restart.
Mar 05, 2011 | Dell Latitude D620 Notebook
I replaced the 30 G toshiba HDD that was not functioning on my LE1600 Motion tablet with a 60 G toshiba HDD and tried to install windows xp from an external CDD. It formated the drive and installed the...
Tried the same thing and got the same result using the motion computing DVD/CD external reader/burner.
Has anyone found an answer to this problem of trying to switch to a larger hard drive on the 1600 with format/installing? The new hard drive was not able to read the recovery disk with OS on it.
Thanks.
Dec 14, 2010 | Motion Computing LE1600 Tablet PC
I installed xp in my samsung r 522 but i loses thr drivers so i want an help
go to the samsung website ,,they have the drivers for you,,to download ,,get xp drivers for your make and model,,
Nov 20, 2010 | Samsung Computers & Internet
Installing cd burner and have no cd
You shouldn't need a cd. If you are using XP or vista and hooked up to the internet windows will take care of the driver for you with all but the most obscure cd drives.
Jun 28, 2008 | Philips CDD 4801 CD-RW Burner
Computers & Internet Logo
27 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
