Question about Samsung ASSY-DRUM LIFTER;B MO - DC97-13901A
Broken drum lifter on samsung washer - Samsung ASSY-DRUM LIFTER;B MO - DC97-13901A
Dirt devil breeze bagless height adjustment mafunction
Hi there! If your vacuum is suddenly hard to push your roller lifter assembly, which controls the automatic height adjustment, may be damaged or broken. Check your roller lifter assembly located underneath your unit for damages. Also, your brushes help to maneuver through carpet, check that your brushes are still spinning. If not, replace the belt on your vacuum. I have included a link where you may visit to purchase a replacement belt for your vacuum. Hope this helps!
Style 4
Aug 08, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How to replace handy zip belt ?
Hello! Below are step by step instructions to replacing the belt on your hand vac. I have also included a link to the instruction manual which has pictures as well as instructions. Really hope this helps!
1. Lift the black plug on the face of the cleaner.
NOTE: BLACK PLUG MUST BE ON WHEN ATTACHMENTS ARE NOT IN USE.
2. Use belt lifter.
3. Center and raise the Hand Vac with your left hand as shown. Using your right hand, dip the belt lifter in and hook the belt around the lip of the belt lifter. Slip the belt onto the motor shaft until the belt lifter base meets the shaft.
4. To insure proper belt placement, gently turn belt lifter counterclockwise and remove. Make sure belt is pushed back on shaft.
NOTE: THE BELT WILL COME OFF IF NOT PROPERLY INSTALLED.
6. To remove the belt, hold belt lifter. Hook the belt on the left side of the motor shaft, turn clockwise and pull the belt towards you to release.
http://pim.ttifc.net/document/1239/
Jun 26, 2014 | Dirt Devil Classic M08100 Bagged Handheld...
How to change belt on dirt devil handy zip
2. Use belt lifter.
I have a broken plug on my Bissel Spt lifter. I know how much the part costs but I don'twant to pay a high shipping fee. Can you tell me how much it would be for Brighton, Co.?
if it is just the plug itself, just go to your local hardware store, or home depot and get a new plug for the unit. they should be about 4-7$ tops.
Good luck.
Nov 14, 2010 | Bissell SpotLifter 1716 Bagless Handheld...
I have a Bissell Power Lifter Shampoo Machine but no instructions
I have a bissell power lifter shampoo machine and no instructions.
Oct 01, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Kirby g4 belt replacement
Facing vacuum,turn belt lifter knob counterclockwise till it stops.Lift headlight hood,and unlatch brushead,and remove.Looking thru the hole in back,turn belt lifter knob clockwise to release belt.Remove bottom plate,and bend one end of bracket to remove end of brush roll.Slip new belt on and replace brushroll back into bracket,and replace bottom rug plate.Looking thru hole in back,turn belt lifter knob until the hook inside picks up belt.Replace brushead,and again,turn belt lifter knob clockwise to drop belt onto shaft.
Dec 18, 2008 | Vacuums
Turning of front part that indicates that the belt is on does not get the belt to turn and therefore the vacuum is not "sucking up" the dirt and debree.
Raise the height adj. all the way up.Turn the beltlifter knob counter clockwise,and unlatch the head from the machine.Look thru the opening in the back to see if the belt is broken.If not,then,look thru the back to make sure the belt lifter picked up the belt.If not, then turn the belt lifter clock wise to position the hook to pick up the belt.Then,turning the knob again counterclockwise will pick up the belt.Reinstall the brushead onto the machine,and turn the beltlifter to drop the belt onto the shaft.If the belt slips off again,replace the belt shaft,as it could be wore down.
Oct 23, 2008 | Kirby Vacuums
Kirby Belt Lifter Assembly
I have tried to get a parts breakdown for your vacuum cleaner with no success. The way that then washers should go is the flat smotth metal washer on the inside followed by the fibre washer and the wavy washer on the outside. The waves are used to bite into the plastic so it cannot work loose.
Oct 28, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Samsung ASSY-DRUM LIFTER;B MO - DC97-13901A Logo
19 people viewed this question
Top Samsung Vacuums Experts
woodzowl307
ray gallant
GARY HIVELY
Level 1 Expert
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
