Question about Refrigerators
Compressor or Relay?
I have a Amana SSD25TL Refrigerator it is about 11 years old. Problem it is not cold on either side but the fan in back is working. Researched online and think might be the compressor or the relay. Is there a way to check if it is the compressor or the relay?
Thanks
  • Anonymous May 02, 2009
    refg run but dont get cold
    Problem Solver:
  • 8 Answers
If you have no refrigeration you can't here the compressor starting than the problem might be able to be resolved if the compressor is not seized. there is a current relay on the compressor than when not working properly will not drop the start winding out on the compressor and it will trip on the overload. That's the poping sound you might hear as it tries to start. I could tell you how to check the windings out on the compressor but your best to replace the starting components hence the current relay and overload and capacitor(might not have one). Or if your don't want to mess around go to the wholesalers and pick up a 3 in 1 it is a capacitor,relay and overload all in one. Its solid state and if it doesn't start the compressor nothing will. If your no good at wiring and cannot determine the start common run winding on the compressor than let a professional do it. Another possibility is if the compresssor is running it might be out of refrigerant
Posted on Jan 22, 2009
I have an amana side by side ars2364aw thet suddenly stopped cooling both sides.The compressor and compressor fan opperate, but the evaporator fan by the coils inside doesn't. I tried replacing both...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | Refrigerators
Fridge and freezer not cold enough. fan seems to blow. no motor noises can be heard. only about 4 years old.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101 ..
Oct 30, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Refrigerator compressor never kicks on.
If the compressor "never kicks in," I don't see how you have having any cooling at all.
It could be a relay, or it could be the compressor. If you're lucky, it's a relay. These are cheap. In any event, it will take a diagnosis that is probably beyond the capability of a do-it-yourselfer.
Oct 15, 2009 | Amana 25.9 cu. ft. Side-by-Side...
I have an Amana SxS (model DRS2663B) that is about 8 years old. About a week ago, it started making a sound - kind of a buzz coming from the compressor area (or the little box I identified as a...
You may have a bad relay/overload part number 12555902 runs about $15 but if the compressor is going bad it may not work.If you take the relay/overload off  turn it into your hand and shake it if you it sprinkles out like a pepper shaker go with the OEM part afore mentioned,but if it sounds solid and nothing comes out go with a hard start(SUPCO RC0410 also about $15) it will buy you at least another couple years in which to shop around for a replacement or save the money for a new compressor.You can call Amana to check on the warranty but most only had five years on sealed system.
Sep 27, 2009 | Amana DRS2663B Side by Side Refrigerator
Amana side by side fridge and freezer not cold.The model #ASD2624HES I have done some research and I think it might be the relay switch or the compresser.If anyone had has this problem with this model...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Part 4 on this diagram is your relay. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2624HES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATION&diagramPageId=00013&componentDescription=COMPRESSOR&documentId=M0608085&backToLink=Return%20to%20subcomponent%20list Here's how you can check it. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 22, 2009 | Amana 26 cu. ft. Side-By-Side...
Amana BX21VW cool but not cold, compressor not working
How to check stuff>
Sep 13, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kenmore Top Freezer not getting cold (freezer or refrigerator), fan works. Occasional click down by compressor? Any advice appreciated. Trying to fix cheap as this is an 8 year old 2nd frigerator we keep...
Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
Sep 12, 2009 | Frigidaire FRS26R4A Side by Side...
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana refrigerator
Sounds like it has either a bad compressor relay or if the brand name of the compressor is Tecumseh, it will need to be retrofit to a more reliable longer lasting Embraco compressor.
Jan 10, 2008 | Amana ARB8057CSL Bottom Freezer...
Amana Side by Side Refrigerator not getting cold
amana is having some problems with their compressors locking up. if the compressor is manuactured by tecumseh then tthe compressor is mostlikely locked up and will need replacing. good news is your refrig is most likely less than years old and should be in warranty to amana..
Dec 15, 2007 | Amana ARSE66MB Side by Side Refrigerator
Refrigerators Logo
247 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
