Question about Xerox Phaser 8500N Printer
Unavailable: PostScript Initializing - Xerox Phaser 8500N Printer
2 Suggested Answers
  • 2072 Answers
SOURCE: PostScript Initializing
Frequently you can clear that code by disconnecting and reconnecting the plugs to the document feeder/scanner and processor.
Mostly the molex connector that runs from the scanner to the side of the machine by the power cord. Mounted sideways.
If that doesn't cure your problem then most likely you have a electronics module problem. If you don't have a maintenance agreement, you can buy a printer cheaper then you can replace that module.
Posted on Aug 05, 2008
Error - unavailable: postscript initalizing
can you give a little more detail?
are you getting an error number? is this happening when you turn it on or send a file to it? try using another program and see if it stilldoes it
try updating your printer drivers, update the printers firmware
and see if it continues
May 03, 2015 | Xerox Phaser 8500/DN Printer
I am unavailable to connect via network
Most likely paper size is wrong. Push the cont. button on printer.
Adjust paper size on trays correctly. Make sure document size is same as paper size esp for PDF and postscript documents
Jul 08, 2014 | Edimax Computers & Internet
How do I get the key code for postscript on the sharp arm315
There should be a card included with the postscript kit. The dealer should have submitted the registration code with the machine's serial number in order to obtain a product key which they are then supposed to write down on the card, make a copy for themselves, and send you the card in the PK1 box.
Aug 26, 2013 | Sharp Postscript Level 3 Expansion kit...
A sheet prints sometimes with this: ERROR: syntaxerror OFFENDING COMMAND STACK: In one flow we get this error and in other flow it works fine. Any help on this will be greatly appreciated.
This is a Postscript error. You may be using a Postscript driver on the printer. Or else you are printing PDFs which are not true Postscript. likely made by a postscript "compatible" software.
Try loading a PCL driver for the printer. This will work just as well if not better than a postscript driver. You may find it faster.
Check lexmark website under support andd downloads for an alternative driver for the printer, also considering your operating system.
If you are printing PDFs or postscript files, the PCL driver may help there also.
May 23, 2011 | Lexmark T644 Laser Printer
After power on, display is blank unavailable:postscript inizializing
first check ram then display card then take out the ram and run PC, if you don't hear peeps then i think you have a mother board problem
Jun 04, 2009 | Xerox Phaser 8500/DN Printer
System not initializing
Does the machine have a network box on back? Frequently on that product the boards in the network controller come lose, and simply need reset.
You can unplug all accessories and see if it powers up then, then connect them back one by one and see which one causes the failure.
Feb 10, 2009 | Xerox WorkCentre M-24 Color Copier
Mac laptop hooked up to HP laserjet 4 plus gets error message:
This printer will not work with a Mac - it has no postscript.
The only laserjet 4's that work with Macs all have an "M" in their name - 4M, 4M Plus etc.
You might be able to get a Postscript personality module for the printer to effectively upgrade it to the "M" version.
Feb 05, 2009 | HP LaserJet 4 plus Printer
Aug 05, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Error occurred while initializing U3 Launchpad
Your SanDisk Cruzer® Micro SDCZ6-2048 (2 GB) USB 2.0" may be giving problem due to the internal errors.
Therefore 2 GB card may be scaned through anti virus, if problem repeats then format ur card from the computer.
Jan 23, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Mobile not working on p.c
uninstall then reinstall the cd software for the mobile on to the pc then install usb drivers....hopefully you are working with a winxp pc and not vista...vista is to problematic.
Dec 31, 2007 | Motorola Mobility RAZR V3
Xerox Phaser 8500N Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
