Sharp printer ar-m256 error code f2-02 problem solution
5 Suggested Answers
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
SOURCE: Sharp AR-162 Laser Unit
searching for solve problem L6 error in the machine sharp m 160
Posted on Mar 19, 2009
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
My Sharp AR-M256 is displaying Code H2-00, how can i remove this?
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Jun 07, 2016 | Sharp Office Equipment & Supplies
My Sharp copier machine AR-M256 is showing F9-99 if plug the stepling side please is there any solution for me to solve it out thanks
Check connections between circuit boards might also need to re flash the copier firmware
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 07, 2015 | Sharp Office Equipment & Supplies
Sharp photocopy AR-M256 showing F2-58
if you are using third party toner and drum cartridge replace them with OEM
May 13, 2015 | Sharp Office Equipment & Supplies
I have a sharp AR M256 we were getting an error toner replenishment in progress. CAll FOR SERVICE. CODE H4-21
sir
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Mar 09, 2015 | Sharp Office Equipment & Supplies
Sharp ar-m256 driver
Manufacturer: SHARP Hardware: SHARP AR-M256 Software name: SPLC Printer Driver Version: 0702a File Size: 5.82Mb (6103906 bytes) Released: 14 Mar 2007 Uploaded: 10 Apr 2010 Views: 319 Downloads: 58 System: Windows NT Description: SPLC Printer Driver for SHARP AR-M256
Oct 03, 2010 | Office Equipment & Supplies
Hi have a ar-m256 displaying error code u2-40 how do i fix please?
enter code (# interrupt C interrupt) then give 16 then press copy.
Jun 17, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharpe ar-163 with error code u-240
Hello sir; The error code you display is CRUM communication error.
Feb 05, 2010 | Sharp AR 163 Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
I HAVE AN ERROR CODE L6 ON A SHARP AR-163 PDIGITAL IMAGER. WHAT IS CAUSING THIS ERROR AND CAN IT BE REPAIRED IN-HOUSE?
Apr 18, 2008 | Sharp AR-M160 Laser Printer
360 people viewed this question
k24674
jasbo
jasbo
