Question about Cell Phones
My Motorola BC50 won't turn on. I've had it on charge since the battery died but the backlight won't turn on to confirm it's charging, and it won't turn on even though I charged it overnight. please help!
SOURCE: Samsung SGH-T219 Turns off even though it says fully charged.
my phone is 1 week old and it does the same thing
Posted on Dec 26, 2007
  • 4102 Answers
SOURCE: Battery not charging
Hi this problem is going to ba faulty battery i had the same problem after replacing the battery it was fine.
The problem was a couple of bad cells inside the battery but what your supposed to do to prolong the life of the battery is to let it go totally flat once a month i mean totally flat so it wont even light phone up then do full charge this keeps the cells good in the battery so remember to do this often should keep the battery lasting ages let me know if you need further assistance
Posted on Jan 22, 2008
SOURCE: Samsung j700 died overnight screen wont turn on, but will charge
change the flexi cable bro
Posted on May 14, 2010
  • 195 Answers
SOURCE: I've changed my battery just last November. I did
Well, if the Batt don't hold charge then check the regulator on the bike with an Ohmmeter you can buy one at an Auto parts shop....motor running you should see 14.5 V if not then the Reg is out!!!
Posted on May 24, 2011
  • 159 Answers
SOURCE: My Motorola V9 says invalid battery even though
These are smart batteries. They have a circuit board that communicates with the phone. If the same battery worked fine before, then the circuit board in the battery is probably faulty. The battery should charge the same, but it may not report all the information back to the phone that it needs. If it becomes a problem with the battery then you should consider replacing it.
Posted on Jun 15, 2011
Motorola bc50 mobile charging solution?
Abhishek-
Are you asking for a portable battery only charging dock for your BC50 battery or are you wanting to charge your phone?
Mark
Motorola Support
Feb 10, 2015 | Motorola Mobility (BC50 SNN5779A SNN5779)...
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
Battery life on my droid x2
Replace the battery since it is worn - or get a new phone.
Sep 02, 2017 | Motorola Mobility DROID X2 Smartphone
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
I just bought the eclipse cld and it won't turn on after charging for hours
Sep 30, 2012 | Eclipse Audio Players & Recorders
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
My literati ereader will not charge. i kept plugging it in to charge and it would never connect and now the battery has completely died and the reader won't turn on.
If you've got any wiggle in the connector on the device, it's broken lose. If not, you've got bigger issues. Either way, it's a trip to the shop, or replacement time.
Jul 06, 2011 | Audio Players & Recorders
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
