Question about Hitachi 12v 3/8" Driver Drill Kit with Flashlight DS12DVF3
Drill battery charger doesn't work
I have a new Hitachi portable drill that employs a lithium ion battery. The drill works fine, but the charger, that I have only used once with no trouble, no longer works. The red light went on went I plugged it in, and it stayed on, as it should of, when I put in the battery, but then soon mysteriously went off. There doesn't seem to be any power getting to the charger. I, of course, checked the outlet, in order to see if that were where the problem lay, but the outlet works fine with other electronic items. I also tried plugging the charger into a different outlet, but that too had no positive effect. Any advice that you might offer me regarding what might be wrong here, and how I might fix it, would be greatly appreciated.
  • 1 more comment
  • Anonymous Feb 14, 2009
    i have pulled my charger apart and have tested the fuse and the wires to the charger all seem to be ok also i have inspected the circuit board and tere doesnt seem to be any burn marks on it
  • ddraig Feb 14, 2009
    I have the same problem, with my 18vdrill modle number DV 18DL. The light comes on the charger, you put your battery in and the charger stops working. I have taken the charger apart.the fuse is fine,there are no scorch marks on the board, the transformer or any thing else.Seems to be a common fault. can anyone(some from hitachi would be nice) help.
  • Sondra Winters
    Sondra Winters Oct 25, 2016
    Harvey's answer is right on the money if your battery has discharged too far. If you don't know AC from DC electricity and understand what he means about polarity, find a friend who does or risk shocking yourself or blowing up the battery.
  • 12 Answers
Hi Firemedic13; Most chargers like yours have a fuse inside them. Remove the screws that hold the charger together. The fuse will be on the low voltage side of the transformer. Un-solder and replace it with one of the same value. If the charger is not held together with screws (doubtfull) you will have to carefully cut along the seam where they were glued together. A dremmel tool works good for this. After repairing use some ABS pipe glue to re-seal them together. If the fuse is not blown then the unit will require testing by someone that is proficient with a multimeter. Most times it is the transformer that has fried a wire. If the sides of the transformer have any burnt spots on it then it will be the culprit. Hope this has helped. Best regards; HELP2DIY Please dont forget to rate my answer.
Posted on Jul 10, 2007
  • brid_plumber Jun 27, 2011
    on the hv side of the transformer there is a thermal cut out fuse, get a replacement one from maplin or rs replace this and all should work again fine
    New Friend:
If you store the battery for extended periods (i.e. months), it spontaneously self-discharges. If the voltage of the overall pack drops too much, its electronics places the pack in "safe" mode and will not allow a charge. Try opening the battery pack and use a voltmeter to verify polarity. Then use a car battery charger (or another 12-18V battery) to charge the battery for 5-10 mins, bypassing the electronic charge regulation circuit. This should raise the battery pack voltage above the "safe" threshhold. Do NOT OVERCHARGE--limit this bypass charge to a few minutes. Then reassemble the battery pack and use the regular ("regulated") charger.
Posted on Jun 15, 2013
  • Sondra Winters
    Awesome advice, this worked great! 5 minutes was more than enough on an 18V charger. Thank you Harvey!
I need a charger for a 12v battery pack Model# 2CBOO-MCB for a MasterCraft Cordless Drill Driver. Where can you purchase this part?
Posted on Jan 22, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
Quick Charger 2.0 2port QC2.0+4port USB Charger 5V 9V 12V 60W USB Fast Charger for Mobile Phone Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
Posted on Dec 30, 2016
  • Hitachi Master
  • 2,010 Answers
I know Hitachi has for dealers a special service if there are some machines have long been in the warehouse and there happens to someone so one machine can be that the battery is no longer accepted in the charger, but the cells are certainly not degenerate because they get to Hitachi special boost with a Cadex charger to the deep discharge protection voltage returns to work up through a special circuit, often they are not li ion cell problems but quickly decline of some species li ion batteries, the 10.8-volt consumed quickly has little cell capacity and that is why I know , the service is free of charge at Hitachi for dealers.Take utmost Li-ion batteries in the charger, including batteries with more capacity swap them round and round off as the cells remain active, the greater Li ion batteries have a special circuit which is designed with a lot of information charging cycles the cells and much more even purchase date and the corresponding machine number codes contained in it, even when the loose batteries purchased betreffend.Li-ion is significantly better at capacity, but the strength and warmth and the tool motor that often suffers holding it usually shorter than the BatterySometimes people think that the battery has no power, but it turns out that the engine of both Panasonic and Milwaukee in 80% of cases the complaint.The engines have significantly less power and make a screeching noise and consume quickly caarbon brushes and if replace a armature its most not expensive but then better do that then buy new batteries.
Posted on May 12, 2016
    New Friend:
    Problem Solver:
  • 5 Answers
Just find a plug with the same voltage output and splice it in
Posted on Feb 16, 2010
    New Friend:
What changes are required for a battery charger for Hitachi drill (lithium ion battery) designed for 110 v ac input to be on 230 volt ac input. Switched power supply.
Posted on Jan 20, 2010
    New Friend:
Where do I get a 18V battery charger for a workforce drill?
Russ
Posted on Jun 09, 2010
SOURCE:
18 v lithium-ion battery will not charge
The batteries were discharged too low. A lithium battery should be recharged as soon as you see a loss of power.
Jan 12, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
NEED BATTERY CHARGER 732751OR732745
New chargers for the WH18DL4 are available item is UC18YRL
Dec 31, 2012 | Hitachi WH18DLP4 18Volt Lithium Ion...
What Ryobi batteries p103 or p104 will a battery charger that came with my p100 batteries charge? Or will the charger work with these batteries?
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Jan 11, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Two brand new Hitachi BSL1815X Lithium Batteries won't recharge (UC18YGSL charger and DS 18DSAL drill)
These batteries have big problems that Hitachi doesn't address very well. Unlike NiCad batteries, Lith-Ion ones must be periodically used and recharged to retain their battery functions, i.e. if they have been sitting on the shelf at a store for an extended period of time, chances are they will be dead when bought and will not accept a charge. If they go dead i.e. no little red light on the charger when you plug the battery unit in...it's basically junk.
If you can return them or exercise the warranty do so. If / when you get new ones DO NOT completely discharge them like you would NiCads. Lith-Ion batteries do not have the "battery memory" issues that NiCads have which means you don't lose running time if you don't fully discharge the battery unit prior to recharge. Completely discharging before recharge will ultimately kill them. Use the 1815X till almost dead and then charge it. It is also recommended Lith-Ion batteries not be stored fully charged i.e. charge the 1815X fully, drive a couple bolts or screws, remove the battery unit and then put it away. Do not leave battery unit plugged into the tool when you put the tool away. This will discharge and kill the battery unit.
There are non-Hitachi substitute batteries now on the market. I'm guessing the same precautions apply but I don't own one of the replacements so I don't truly know.
The actual batteries in the Hitachi BSL 1815X are Sanyo UR18650SAX lithium ion batteries. Lithium Ion cells aren't all that easy to get commercially because of handling & safety requirements. Not certain if you can take apart the 1815X and swap out the bad Sanyo cells.
Jan 07, 2011 | Hitachi Koki Usa WH18DL Lithium Ion...
I bought the two pack Ryobi Lithium-Ino Batteries along with the six battery Ryobi One + Charger. When I use it on my P201 Ryobi 1/2 Drill and the drill encounters any type of a torque situation the...
I would not say they are not defected, but I think they are not getting fully charged. I have the same problem with my battery once I have used it all day and the red light comes on from the fuel gauge. I have the P104 battery. I would return your charger and try to charge them on the new one first. If you have the same trouble, then return the batteries for new ones.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Will a nicd charger work to charge lithium-ion batteries?
no, I would not try this. You can charge a nicd battery on a lithium-ion charger but not the other way around.
Nov 25, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
My hitachi drill is working funny
hi
try to charge the battery at full level and see what happens then.
regards savumihai71
Dec 13, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
Battery wont charge green light and orange light come on but no charging happens, i have 3 other of the same batteries and they charge and work fine.
Is this an old battery? Batteries can fail and not charge after a lot of use. If it's new, run it all the way dead, then try to recharge .
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 03, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
I'm trying to find out if the new 19.2v C3 Cordless drills batteries are interchangable with the original 19.2v cordless battery. Also the new ion lithium batteries, Can the be used in old 19.2v drill?
I "m 99% sure Milwalkee is the only company that is interchangable..lithium ion and Ni cad ......... the new Milwalkee Lithiom ion chargers will chare both lithium and nicad, but the ni cad chargers will not charge lithium ion. Thanks Hope this is helpful!
Dec 10, 2008 | Drills
Hitachi 12v 3/8" Driver Drill Kit with Flashlight DS12DVF3 Logo
14,372 people viewed this question
Top Hitachi Drills Experts
John Trevino
jasbo
jasbo
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
