Question about Dell 966 All-In-One InkJet Printer
Print cartarage pully wheel
The print cartarage wheel came off its in side on the right the spring that holds it tight also came off.... My question is where does the spring attach to the printer????
  • 2,120 Answers
There should be a detent on the frame.
Posted on Jan 22, 2009
How to thread pull cord on my Talon rotary mower
remove THE COVER THAT HOUSE THE PULL CORD pully. TURN THE WHEEL IN THE direction THAT IT GOES WHEN cord is pulled ( THIS TIGHTENS THE RETURN SPRING) hold this wheel tight..every turm it could spin back rapidly. turn wheel 6 complete turns. align the hole in the housing with the cord hole in the pully wheel. thread cord through both tie a double knot . slowly release now install cover. try it if too loose pull out to max , hold pully, remove knot , cord and turn 2 or 3 more turns, replace cord, double knots , slowly release. replace cover, crank it and cut that grass.
Dec 04, 2011 | Talon Rotary Lawn Mower
Will not print black only.
take a STRONG, THICK sponge and cut it to the size of the hole that you put the color ink cartrege.Dampened the sponge in hot water (better into microwave oven for 1 min) Got to be dampened HOT but not drupey wet and place into hold of printer for 1 min. rub sround inside. If color comes out on sponge (that is good) you have loosened the clogged inkjet holes. Your ink still good? on the same HOT, DAMPED sponge placed the cartarage head down on the sponge and rub like you mean it. BE CAREFUL of the metal contacts & ribbons running up the front of cartarage.
Sep 01, 2011 | Brother DCP-110C All-In-One InkJet Printer
There is no ink in this machine. Try changing the paper. If that doesn't work, then you need to either a)replace the spring that holds the paper cover closed so that the paper is pressed tightly against the print head or b) replace the print head. You can also try using a rubber band to hold the paper cover closed more tightly. If the spring is the problem, a rubber band will do the same thing.
Jun 29, 2011 | VeriFone (M19755014US1) Magnetic Card...
Why the colour print is not best quality
hey you need to clean your ink cartarage by the printer properties first click on printer properties or help tab you can see there printer properties after click on print cartarege there is a option clean print cartarage .this is the simple or fast way to clean or make best quality if it works plz reply or vote i hope it will work
Oct 29, 2009 | HP PSC 1315 All-In-One InkJet Printer
I have aTroy Built Super Bronco MD 60TG in the operators Man page 44 part #26 Spring Ext .94Dia, 6.74 fell off can not find where to reinstall can you send a diagram or tell me. Pat
The spring is connect to a stud on the front side of the deck in front of the right pully as you look at the mower. The rear of the spring is connected to an brace at the back of the deck behind the same pully. This spring assit in keeping the V-Belt tight when the blades are engaged. Fault stud broke needed replacement.
Sep 15, 2009 | Garden
Only half of incoming faxes are printed.
Is this a machine that uses a big, black roll of thermal donor film? The Fax 1250 and several other models have a common problem where the left side prints perfectly, but fades to blank on the right (or the opposite). When you replace that donor film cartridge, you open the top and push a blue lever back on each side to raise the print element assembly.If one of those levers cracks, it will still hold down the head and look normal, but it won't hold it tightly enough the paper to to print on that side.
For models Fax-1150/1250M/1350M/1450MC/1550MC
the parts are
Left (as viewed from the front):UF6085001
Right: UF6087001
One or two screws hold the metal plate on top, then the levers are held on by the springs.
Aug 05, 2009 | Brother Office Equipment & Supplies
Right-side cover will not close, springs are disconnected.
Normally the right cover hooks break off and causes the door not to close.There is square holes in front and back of the right cover that you can use to hook the spings again.
Apr 27, 2009 | Canon PC-920 Black and White Copier
Ink problem
Sometimes it's cheeper to get a printer on sale than buying cartarages,
However remove the ink cartarages and clean the print heads off, sometimes this works.
Verify thay have ink.
and to save a little money get a referb cart off ebay I have had good luck getting cheep ink there
Apr 25, 2009 | HP DeskJet F4280 All In One Printer InkJet
Removal of cartarage of hp psc1410 all-in-one inkjet printer
Step1: Make sure the HP is on and paper is loaded in the tray.
Step2: Gently lower the print carriage access door at the front of the unit. Do not force it.
Step3: Press down on the print cartridge gently to release it. Pull it towards you and remove.
Step4: Gently clean the cartridge with a slightly moist paper towel and then pat dry
Step5: Slide the print cartridge into the empty slot, and gently push forward until it clicks into place. If it does not click, do not force it. Remove it, and try again.
Close the print carriage access door. An alignment sheet will print to make sure everything is lining up.
Hope this helps & happy holidays!
Dec 15, 2008 | HP PSC 1410 All-In-One InkJet Printer
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Dell 966 All-In-One InkJet Printer Logo
47 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
