Question about Fisher and Paykel Fisher & Paykel Washer
Smartdrive 601 leaking
I have to turn the tap off when the machine is not being used as it leaks all the time
    Sergeant:
  • 291 Answers
If the tap is leaking replace the washer in hose end. It's a common garden hose washer. If you mean there is water in the tub your inlet water valve needs likely needs replaced.
Posted on Jan 11, 2013
  • 125 Answers
SOURCE: Leaking taps
Check first if leaking from hoses or under the machine.
Undo your taps, check that the hoses rubber seals haven't worn out. Replace rubber seals, most hardware plumbing sections have them. Also if the actual tap is leaking at the wall, you will have to change the tappets. You will need to close your main water at the timer, then undo the actual knobs, depending on the tap. Once opened take out tappets and replace with copper ones rather than plastic. Then put all back together and switch water on and check if leaking. In case it is the washing machine, try to replace hose or the connector on the back of machine. Make sure also all rubber seals are replaced with new ones. If under machine you will need a plumber. See how you go!
Posted on Aug 02, 2008
  • 17 Answers
SOURCE: fisher paykel smartdrive 601
Most likely a blocked pump
Posted on Apr 19, 2009
  • 4 Answers
SOURCE: Fisher & Paykel smart drive
The small leak may have been enough to blow the fuse under the control panel.
I had the same trouble with my F&P smartdrive 701.
Take off the control panel by undoing 2 screws and you will see the blue plastic control box in the tray on the machine (not the other blue circuit board box under the push buttons). Open the control box (1 screw and click open) to see an ordinary fuse. Hopefully this is blown and the new fuse, a clean up of leaking water, and some plumber's thread tape on the hose connector to stop future leaks, and you should be up and running.
Good luck.
If it works - give a small donation to your favourite charity!
DIY Eddie.
Posted on Sep 15, 2008
TheMobilian
  • 8220 Answers
SOURCE: I have a smartdrive 601 that will not fill start
hot and cold hoses connected backwards
Posted on Mar 22, 2010
  • 10 Answers
SOURCE: Fisher&Paykel Laundry: Fisher&Paykel Washer: smartdrive 058 leaking by the pump...
Hi if you can see the water leaking from the base of the pump pump needs replacement better to do now than later when pump fails and takes out main board :)
Posted on Jul 11, 2010
My F&P Smartdrive 9 Excellence 5.5 GW509R will not start water fill.
no power to turn on the tap solenoid
could be a problem water lever control or program board
call in a technician for a proper diagnosis and quote
Aug 14, 2016 | Washing Machines
601 Ford Tractor fuel shutoff leaks. Is there an o-ring or gasket inside that I can replace? If not, how can I fix!
if it is the old slide across to shut off tap used on petrol engines there is an o ring that can be replaced
if not ,any turn fuel tap will fit in it's place
Dec 22, 2015 | Ford Cars & Trucks
My Bosch washing machine is leaking from the bottom of the right hand side of machine when not in use.
g'day, sounds like the leak is coming from the hose - this is because the leak is occurring when its off. Check seals on hose at the back of machine. You can always find old sets of hoses as well (or buy them), so you can try swapping them over. Keep in mind, with washing machine hoses (like gardening hoses), the seal is at the rubber washers not the thread on the tap... so plumbers tap will not stop a leak, it will hinder the seal.
An alternative solution is simply turn tap's off between washes...
Aug 07, 2011 | GE WWSR3090TWW
I have a f&p Smartdrive 708 washer that is leaking water underneath the machine. It is only a small leak at the moment. Could the seals be worn out?
Hi you need to identify where the water is coming from three main places are 1: pump seal 2: a hole in the drain hose 3: Main bowl seal my advice is turn it off at the wall lean it over and have a look underneath and clean floor area. does the base of the main motor look clean if yes its probably not the main bowl seal. So its down to the last two if your models got the plastic removable cover on the front its easy to remove it and watch where the water is leaking from my "guess" is a pump seal you will see it drip/ splash of the pump fan during drain/ spin cycle Be very careful to turn off at wall as there is voltage around these things even when power is off at the machine panel
Jul 02, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hi. My smartdrive 6.5 kg top load washer pushes cold water up the hot water line while it is filling up. I don't use hot water. thank you
on your machine when you select cold, the hot water valve will open automatically letting cold water thru it.can you connect the hot hose up to a tap to stop the water leaking out? or you can buy a screw on plug from a hardware shop that will cap off the valve at the machine or the hose. sometimes to save a customer money i connect their hot hose to the hot valve then fold the hot hose in half and tape it in that position . this stops the water. hope this helps. please reply for further help if you need it
May 26, 2010 | Fisher and Paykel Washing Machines
May 18, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher paykel smartdrive 601
I can talk you through diagnostics if you want to go on live chat cheers
Mar 13, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel smart drive topload has lost power. It stopped half way through a cycle. Took the clothes out and tested the power point but it won't turn back on. There was a slight leak at times...
Good luck.
DIY Eddie.
Aug 28, 2008 | Fisher and Paykel Washing Machines
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
