Question about D-Link DFM 562E (dfm-562e) Modem
How do i acess.. d-link... modem config ftp... address??? or something eles.. what the dafault adim @ password thanks tom
  • 34 Answers
User name is : admin
Password is : admin (or it could be blank, as in no password)
To configure the D-Link router, you will need to open a web browser and type http://www.192.168.0.1
Posted on Jan 21, 2009
How do i connect to the internet using my network
In order for you to have internet access please note of the following:
1. You have Internet service provider
2. Have the modem box provided by your ISP plugged in to the wall jack with the telephone cord came with the box.
3. Connect your modem to your computer with the yellow cord came with the box.
4. Make sure to have your username and password given to you by your ISP in order for you to configure your modem.
5. Check the light status of the box make sure that dsl light is steady green, lan light steady green, internet light might be in steady red or off since its not uet configured.
6. Access configuration of your modem from you computer using the IP address. You can find the IP address at the bottom part of the modem. If you cant locate Ip Address perform this: from your computer go to start menu then go to run then type CMD and press enter. A black window will come up and from that window type in ipconfig then press enter. It will provide you the IP address that looks like this 192.168.1.1 or 192.168.1.0. Get that IP address and type in to the Inrnet explorer address bar and hit enter.
7. It will ask you to login from there type in the username and password normally the default config of the modem is the credential like username is admin and the password is either admin also.
8. From the modem config page run through the steps and that's it... if you have questions or concern please send me message for me to assist you further.
Oct 19, 2013 | Lands Phones
Dear sirs, I need to re-config my Asus PORTABLE WIIRELESS ACESS POINT WL-330gE and is not possible to get the web page. I need to have a repeater and is impossible. I have a new modem NETGEAR wireless N...
You can reset all settings to their factory defaults manually by pushing the "Reset" button of the ASUS 802.11g AP while it is ON. Push the "Reset" button with a pen or a paper clip for about 5 seconds or until the power LED starts blinking.
Default
IP address: 192.168.1.220
username: admin
password: admin
May 07, 2011 | ASUS WL-330GE 802.11b/g Wireless Access...
HOW DO I ENABLE PORT FORWARDING ON MY NETGEAR N150 ROUTER
First you have to get onto your router's config page. Your router should be located at http://192.168.1.1 OR http://192.168.0.1
When asked for login info, the Username is admin. The password it either "admin" or "password", minus the quotes, assuming you havnt changed the default.
When on the config page, go to the firewall. Create a new rule. Use an Inbound rule. Thats the same as port forwarding. Select the service(port) you want to forward to the LAN Server(your system running the port you want stuff forwarded to). Then click apply. If you need more info later, the manual can be found at the following address: ftp://downloads.netgear.com/files/DGN1000_UM_19Jan10.pdf
Mar 08, 2011 | Computers & Internet
How do I change channels on the 4 Port Wireless Router, ADSL2/2+. Need to change from channel 9 to channel 1.
Manual for DSL-2640B:
ftp://ftp.dlink.co.uk/dsl_routers_modems/dsl-2640b/DSL-2640B_Manual_v1.pdf
How to change channels see page 27.
For manual channel setting "Enable Auto Channel Scan" needs to be
disabled / not selected.
Note: default login user and password for the router is both admin.
Login opening Internet Explorer entering http://192.168.1.1 as address page.
Sep 01, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Still cant solve it.
The default address to get to the web interface is 192.168.1.1
The default password is 1234 (No username required)
If that doesn't work, you can restore it to the factory default by pressing the reset button on the back and holding it in for 10 seconds. Be aware that doing this will erase all existing configuration information.
Here's a link to the quick start guide:
ftp://ftp.zyxel.com/P-320W/quick_start_guide/P-320W_1.pdf
Here's a link to the Users Guide:
ftp://ftp.zyxel.com/P-320W/user_guide/P-320W_1.pdf
Jun 27, 2009 | Zyxel Prestige 320W Wireless Firewall...
Lost user name and password for configuration manager
If you forgot your password, you must reset your modem.
Note: This process will change all your settings back to the factory defaults.
To reset the modem:
Step 1 Locate the Reset button on the rear panel of the unit.
Step 2 With the modem powered on, use a paperclip to hold the button down for 10 seconds.
Step 3 Release the button and the modem will go through its reboot process.
Step 4 Wait about 30 seconds to access the modem.
After restart the modem you can use default username and password (admin/admin)
For further help you can check the link below
ftp://ftp.dlink.com/Broadband/dsl2640B/Manual/dsl2640B_Manual_100.zip
Mar 22, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
IHow to install my 2Wire modem without the the installation CD
hi,
it doest matter if you have the disk or not. Access the command prompt window, type in "ipconfig" press enter. Make a note of the default gateway. type the same set of no.s in the address bar of the interent explorer, you will acess the modem's Graphical User Interface. If it asks you to enter the user name and password type in user: admin in password: admin or leave it blank.
Try to enter the uid and the password from ISP, you should be connected.
Run Speed Test @ http://primustel.blogspot.com
Dec 05, 2008 | Computers & Internet
Not able to hook this router up
on the right track
connect modem to router WAN port
connect pc to modem LAN port by cable
DO NOT use wireless to configure router
http://192.168.0.1 is the address of the router
the admin name is 'admin' no quotes
the password is blank, not the word 'blank' a blank screen.. unless your sister changed it
read the online help
set an admin password
set a WEP encryption password
after config router can use wireless if prefer
NEVER make config changes by wireless
Oct 30, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting 2 computer thru DI-514
Well I believe wat ya need to do is simply obtain a NEW "Account" with NEW Logon & Password with a NEW Internet Service Provider. Then you set up the modem to connect to the new ISP, at the NEW ISP's address, with the NEW Password & Logon. When you got the modem ya should have got a "Setup" CD that should walk ya thru the connection routine... Below is a link for a "Users Manual" that should help you get connected. ftp://ftp.dlink.de/di/di-514/documentation/DI-514_qig_en_Quick-Install.pdf
Aug 15, 2007 | D-Link DI 514 Wireless Router (DI-514)
Cisco cva 122
PAT/NAT has to be configured to forward port 21 to your PC's IP address.
Have you had a look in the config/management page? If it supports this, it'll be there...
Feb 01, 2007 | Cisco CVA 122 (CVA122-SINGLE-1P) Modem
D-Link DFM 562E (dfm-562e) Modem Logo
175 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
