Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint aquarius 1200 washer dryer wd64
Hi, this washer dryer works fine enough but the power does not always switch on at all. it has been dropped a little before but has worked several times perfectly. will it be affected by only having one water hose connected? what would you do about the power? thanks roy gordon
    President:
  • 1,462 Answers
Operation will be affected by having only one hose connected - when water from the disconnected hose is demanded then machine will not continue. i assume hot hose not connected. easiest way to deal with this is to connect both hoses to a ~"y" piece. easily available and costs about £3
Posted on Jul 04, 2007
SOURCE:
I got a Hotpoint Aquarius Extra Washer Dryer WD64 GB 1200, it worked before and suddenly did not work yesterday, when i supply the power and close the door properly and start the programme, the light is...
most common reason for what you are describing is a faulty door lock part no. 1602390.
easily fitted by undoing door seal retainer, removing two screws holding on door lock and then just change over wire for wire.(only 3 wires).
this should get you going
Jul 07, 2011 | Washing Machines
Hotpoint Aquarius Extra washer dryer WD64 will not drain water. Spin works ok.
Was it working before? You may have a blocked outlet hose. Try taking it off under the sink to look for a blockage. You could also try getting some water in from that end with another hose to see if it comes out into the machine. If it is not a blocked hose, then the pump may be faulty.
Dec 09, 2010 | Hotpoint Aquarius WD640 Front Load...
How does the powder tray come out for cleaning on a Hotpoint aquarius WD64 washer dryer please ?
there is a tab in the mid section between the two sections for the softener. You need to push the tab down at the back you should feel it go down then gentle push in slightly then pull out.
Hopr this helps
Sep 05, 2010 | Hotpoint Aquarius WD640 Front Load...
I have water leaking from the dispensing tray, only on the pre wash filling..any suggestions I have a hotpoint washer dryer wd64
Check the level of the machine, may be leaning slightly forward allowing water to leak on that one fill cycle. Lift the front a little by using the adjustable feet and see if it stops.
Feb 16, 2010 | Hotpoint Aquarius WD640 Front Load...
Hinges changed on door now has no power
If you have power to the washer, but nothing is working, then the usual cause is a faulty door interlock.
to prove if it is the door lock, disconnect it, and join the two thick wires on the lock together, if it is faulty, the washer will now work.
If it does not, then you have another problem, it will be a process of elimination.
Only do the foregoing if you are competent to do so, and know what you are doing with electrics.
Good luck.
Jan 16, 2010 | Hotpoint Aquarius WD640 Front Load...
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Washer dryer WD64 Not Heating Wash Water
hi pw82,
its seems you're doing your home work. that cylindrical part is the thermostat itself. it should have a resistance in the range of kilo ohms. around 10 kohm to 25 kohms. you can try to change the range of your testing equipment so that you could be sure that te thermostat is really open circuit.
if there is no resistance, then that is the problem. if there is resitance in the kilo ohms range then it could still be ok and you need todo some further testing.
you can check for voltage presence at the terminlas of the heater. if there is no voltage then it could be the relay on the power board that supply voltage to the heater.
or the board itself.
i hope i was able to help..please rate me..tnx
drcool299
Jul 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Cold feed only
i don't see why not, you only be able to wash in cold water and i hope u have a drain and power in that room.
Dec 03, 2007 | Hotpoint Aquarius WD640 Front Load...
MY WD64 does not spin
First see if there is power in your wall socket; then check your washer plug, or plug fuse, wires.......
Sep 30, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
142 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
