Question about Kodak EASYSHARE G610 Thermal Printer
No color in pictures
I have a g610 printer dock and i try to print
pictures and they come out blank with just
images no color in pictures at all.
thank you
We had a similar problem and found out that we put in regular photo paper by mistake. You must use the paper that came with the cartridge because the printer dock uses a thermal heat to produce photos. After using that paper the photos were great.
Posted on Feb 03, 2009
My printer is only printing half the picture, one half comes out great and the other half has nothing
  1. Remove the power cable from the printer.
  2. Remove the paper tray from the printer.
  3. Remove the paper from the paper tray.
  4. Verify that the paper you're using has KODAK XTRALIFE Paper
  5. Insert the paper tray into the printer.
  6. Open the color cartridge door, then remove the color cartridge.
  7. If the color cartridge ribbon is torn or damaged, replace it with a new cartridge.
  8. Install the color cartridge, and verify that it is fully engaged.
  9. Close the color cartridge door.
  10. Connect the power cable to the printer.
  11. Wait for the printer to initialize (the paper may eject automatically).
    NOTE: For the Photo Printer 500 and the G600 or G610 Printer Docks only, press the power button in addition to plugging in the power cable.
The printer's lights turn on. And after a few seconds, most or all of the printer's lights turn off. The printer will make noises while cycling. If a paper is stuck in the printer, while the printer is making the noises, pull gently on the paper to try and remove it.
If the problem persists cal 1800 2356325 > for a repair
Oct 26, 2009 | Kodak EASYSHARE CD33 & Printer Dock Series...
Computer can't find driver to communicate with printer
can you check if you have the CD that came along with the Kodak Printer? You would need that to install the printer on your computer. Once thats done, you should be able to print the pics
Hope this helps
Thanks
Ranjit
Aug 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
Can't remove used ink cartridge from G600 Printer dock???
Hold the transfer button down then hold the left arrow. Make sure the printer is on. Should here some clicking noise. When it completes then remove the ink cartridge.
Jan 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
Kodak G610 printer dock won's communicate with computer
You know I had this same problem for a while as well. The only solution I found was that I HAD to use the Kodak Easyshare software in order to print anything with it. (That was the case with my XP desktop and my Mac laptop...). But sometimes it still would not spool properly and would require unplugging the printer and plugging it back in to reset.
Printing pictures on Kodak Printer dock G610 from Kodak Easy Share on the computer
keeps giving me message "printing error" (prints ok from camera) i have probably messed up every setting by now
Oct 20, 2008 | Kodak EASYSHARE G610 Thermal Printer
Kodak easy share g610 printer / charging dock with zd710 camera
Consult the Kodak company or Go to a nearby gadget technicians. I hope it could help you....
May 13, 2017 | Kodak EASYSHARE G610 Thermal Printer
Kodak G610 prints from docked camera, but not from the computer
it is advisable to use a recomended usb cable for your printer dock. you can try also to uninstall and reinstall the printer driver on your computer. just simply follow this steps:
Remove the drivers that your operating system automatically installed on your computer:
-- On your desktop, select Start > Settings > Control Panel > Printers & Faxes.
-- Remove all Kodak printers.
Right-click the printer icon.
Select Delete.
-- On your desktop, right-click My Computer, then select Properties.
-- Select the Hardware tab.
-- Click Device Manager.
-- In the Universal Serial Bus controllers list, right-click USB Composite Device, then select Uninstall.
note: make sure that the only device connected to your computer usb port is your G610 printer dock to make sure that the USB Composite Device that you uninstall is for your G610, most of the devices connected to you usb port has USB Composite Device also.
-- In the Imaging devices list, if any Kodak printers appear, right-click the Kodak device, then select Uninstall.
-- Disconnect the USB cable from your printer.
-- Restart the computer
-- Power Cycle the printer
-- once your computer is ready connect the G610 to your computer
-- check if you have a pop up window display on your computer informing you that your computer found a hardware device
-- you can go to printer and faxes and check if the G610 printer icon is on the list
-- try to make a test print
Verify that your computer is communicating with your printer:
-- Check that your printer is on.
-- verify if the USB cable meets your printer specifications.
-- Check that the USB cable and the power cord are securely connected to your printer and your computer.
Mar 27, 2008 | Kodak EasyShare Color Photo Printer Dock
Kodak EASYSHARE G610 Thermal Printer Logo
137 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
