Question about HP LaserJet 3600 Printer
10.10.01 memory error in hp 3600 - HP LaserJet 3600 Printer
Error code 5418 priter hp 3600
54.18 - An error has occurred with one of the tonerlevel sensors Black - 1. Make sure that connector J1020 on the DC controller is seated correctly. 2. Replace the memory-controller PCA. 3. Replace the DC controller.
May 25, 2015 | HP LaserJet 3600n Printer
HP jet printer 3600 displays error 54.17
Non HP cartridges is not the issue. Maybe you have a defective cartridge. The error is caused by changing the cartridges so you have a clue now. Which cartridge you changed that produced that error, you need to replace that cartridge.
Mar 26, 2013 | HP LaserJet 3600 Printer
Fuser error on hp 3600 printer
Hi guys, i also had an Hp 3600 that gave me 50.4 fuser error after replacing with a new one. The solution I found after troubleshooting for hours was to replace the low voltage PSU. Worked like a wonder!
May 02, 2012 | HP LaserJet 3600n Printer
I have an HP Color Laserjet 3600n with error 10.10.03
Thank you for contacting FixYa with your printer issue.
www.hp.com Support Document (110993)
10.XX.YY SUPPLY MEMORY ERROR Description The printer cannot read or write to at least one print cartridge memory tag, or at least one memory tag is missing. Action
  1. Open and close the front door.
  2. Remove the print cartridges, and then reinstall them.
  3. Close the front door.
  4. Turn the printer off and then on.
  5. If the error persists, contact HP Support.
Helpful CLJ 3600 Error Message Tables:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478&prodTypeId=18972&prodSeriesId=501044
Hope this helps helps. Please keep us updated and remember to rate this answer.
Jan 22, 2011 | HP LaserJet 3600n Printer
HP Laser Jet 3600 it has a 51.23 error I
Try replacing interconnecting cables - flat ones
Jan 31, 2010 | HP LaserJet 3600n Printer
HP Laserjet 3600 error 493007
Critical error. Try printing from a different application. If problem goes away, then you may have a software problem. If problem is still there, remove the memory DIMMs. You may have to replace the formatter.
Nov 24, 2009 | HP Hewlett Packard LaserJet 3600dn Printer
Error 51.23 on HP 3600 color laserjet printer
Aug 12, 2008 | HP LaserJet 3600n Printer
Memory error
You are probably entering the equation wrong. Dont do this: 3600=x(2+2) You have to enter the equation 3600=x*(2+2)
May 28, 2008 | Texas Instruments TI-89 Calculator
HP LaserJet 3600 Printer Logo
Seeker5211
Seeker5211
