Question about GE Refrigerators
I have a ge refrigerator gsh22jftabb not cooling food compartment or freezer pls help
  • 52 Answers
SOURCE: GE top freezer refrigerator
The air flow vents must be blocked. The refrigerator cools from the freezer through those vents, it does not cool independently. They may be clogged in the case with ice. Turn the fridge off and leave doors open for a few hours to let it thaw and it will probably start working.
Posted on Mar 20, 2008
  • 52 Answers
SOURCE: top freezer GE refrigerator GTS17KBSERWW
Check to see if the vents between the refrigerator and freezer are blocked. Or check to see if the fan is running (the evap fan motor in the back of the freezer) You may have a defrost problem if the vents aren't plugged.
SOURCE: MY GE GSH22JFTABB WONT GET COLD
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
  • 10 Answers
SOURCE: GE ARCTICA Refrigerator, M/N PSS26PSTA - poor cooling
possibly low on gas
Posted on Sep 13, 2009
heatman101
  • 43501 Answers
SOURCE: 48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Posted on Sep 29, 2010
What else can I check - my fresh food side of fridge is still too warm, freezer fine.
GE refrigerators use a board to control cooling and defrost functions. The fresh food compartment also utilizes a motorized damper, and some models even have a fresh food fan. Air enters the fresh food compartment at the top left corner, and the return air is also in the left wall down near the crispers. Both paths must be clear.
Jul 21, 2014 | GE Refrigerators
My GE 2008 side by side , the freezer is working but the food storage is not help ?
one of 2 things can be wrong,#1) if theres a heavy frost buildup on the rear inside wall of the freezer compartment then its a defrost issue,which will block air flow to the refrigerator side,take off back panel and test defrost heater and thermostat both on evaporator coil for continuity,thermostat has to be below 32 degrees to test good,most of the time its the hearter on G.E.. #2)if no frost buildup,then check the damper vent door between the freezer and refrigerator compartments and make sure its not stuck or broken shut and can no longer open and close to keep temperatures in refrigerator cold
Sep 29, 2012 | GE GSL22JFR Side by Side Refrigerator
Food compartment not cooling adequately, door gasket loose
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 27, 2011 | GE PDS18SBM Bottom Freezer Refrigerator
Frost build up in freezer. Causing warming in fresh food compartment. Having to reset unit one to two times a month.
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Nov 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer temperature working fine fresh food
I need you to confirm that your model number is ZICS360NR and I will help you, Sea Breeze
Nov 13, 2009 | GE Monogram ZICS360NR Bottom Freezer...
Sep 09, 2009 | GE GSS25LGM Side by Side Refrigerator
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Top refrigerator not cooling--freezer icy
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Jul 28, 2009 | Refrigerators
Mar 19, 2008 | Refrigerators
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
