Question about Sony CLIE PEG-T615C Handheld
Installing this PDA on Windows Vista Home Premium laptop
I have recently bought a new laptop with Vista installed but now find that this PDA is incompatible as there are no Sony drivers available (and never likely to be!) Can you advise if there is a Palm or other manufacturer who has produced compatible drivers please. It worked OK on my old computer which ran on XP Thanks
  • Stuart Mitchell Jul 04, 2007
    I have tried to use Windows mobile device centre settings as you have advised but still no joy. Thanks very much but it is still trying to find a driver and there isn't one!
There is actually an easy solution. Run the program in XP compatibility mode. First install the palm desktop cd that came with CLIE. Go to "Start"> All Programs> Sony Handheld
1. Right click "HotSync Manager" and click "Properties" click Compatibility tab and and check "Run this program in compatibility mode for: Windows XP (Service Pack 2).
2. Then HotSync your CLIE it should work.
Other Issues if it doesn't work:
1. While installing software from cd, open cd and rightclick setup.exe and check xp compatibility, and while installing if a pop-up appears for drivers, Just Click use old drivers anyway.
2. In "Start"> All Programs> Sony Handheld
you can rightclick all the shortcuts like "Palm desktop for clie", "Install tool", "Hotsync manager" and set it to run in xp compatibility mode.
Voila... it works and its easy and don't throw away your CLIE yet.
Posted on Jul 22, 2008
  • 3 Answers
I suggest that you install the Palm Desktop Operating System 6.0 or higher  from the Palm Zone to make the CLIE compatible with the Windows Vista Operating System.
Also you can download all the original Sony Software for the CLIE from the link below:-
http://www.sonyclie.org/
Regards
Chris
Posted on May 15, 2008
    President:
  • 2,961 Answers
You shouldnt need a device driver for your pda to work along side with Vista, as Vista has it's own Windows mobile device centre which should run as soon as you connect your pda to a usb port. If it doesnt run, then open up windows mobile device centre in programmes and check the mobile device settings as to whether usb is set to connect to the centre.
Posted on Jul 03, 2007
SOURCE:
Installing windows
How can I help with Installing Windows? and waht version of Windows is it Vista, XP, Windows 7 and what versions? is it Home basic, Home Premium, Enterprise so on....
Aug 29, 2011 | Sylvania G-Netbook
I lost my laptop log-in running Vista Home Premium
http://technofriends.in/2008/11/17/how-to-track-a-stolen-laptop/
Plese check if something could help, if you have another desktop or a laptop that you can track the laptop that you have lost by installing the sofware and run it and check if you can retrieve it.
Jun 11, 2010 | Microsoft Windows Vista Home Premium with...
I recently formatted my Acer Aspire 4732Z laptop and now im attempting to install Vista on it. As it came pre-configured with Windows Vista Home Premium, will the product key found at the bottom of my...
IF it came with a Vista Install,and you are installing the exact same Vista,then YES, The "Key" on the bottom, is the right one and it will absolutely work. These units have a BIOS that has a special Activation Code inside. The Windows install "Sees" that "Code" and Activates Vista. You DO need to user an ACER Version though, this can be downloaded from the "net though, as an ISO,burn that to DVD, and you can use that.
Apr 11, 2010 | Computers & Internet
I have bought lenovo 3000 y410 and install window7.but no any audio driver support by this operating system only on lenovo.
You may try installing the audio driver for Windows Vista but of the same bit. For example, if you've installed
Windows 7 Home Premium 32-Bit then try installing the Driver for Windows Vista 32- Bit.
Nov 07, 2009 | Computers & Internet
Have trouble installing Vista Service Pack 2. It
check the disk if its not scrached in anyway if your disk is new the it might be your dvd writer,s problem.so the best thing u can do is to transfer your vista into a flash disk probaly a 4G or something then install ur vista through USB.good lucky
Nov 03, 2009 | Microsoft Windows Vista Home Premium with...
INF error with crystal eye webcam on vista premium.
you're crazy installing vista on that netbook. acer doesn't have vista drivers for that model.
Apr 26, 2009 | Acer Aspire One PC Notebook
HP Pavilion dv6000 OS(s)
The product key on the label on the bottom of the laptop will only work for the version of Windows that was installed on that laptop.
You can purchase an upgrade Windows Vista Ultimate and to use in conjunction with the existing Vista Home Premium.
Mar 30, 2009 | HP Computers & Internet
PROBLEMS WITH VISTA
yes you can install windows xp on the system but that would cancell the warrantty on the laptop provided by HP so better contact HP before you do that
Dec 13, 2008 | Microsoft Windows Vista Home Premium with...
Xp Drivers needed for Satellite U400-138 to downgrade from Vista Home premium
Yes you can downgrade it to windows xp. go to toshiba website www.toshiba.com and from there you can download the drivers for Windows XP. befor installing Windows XP please download the Network driver and save it on a CD or any other driver. Then install Windows XP. Install the network drivers, connect to the internet and install the other drivers required.
Thanks
Oct 24, 2008 | Computers & Internet
AutoCad LT 2006 incompatible with Windows Vista
some of the older versions of autocad does'nt tend to work in vista.try installing autocad 2008 or 2009.it is recently released and well compatible with vista.REMEMBER, if u r using it for architectural purposes,try downloading autocad architecture 2008.it is especially made for architects.try downloading it on torrentz.com
Jun 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Sony CLIE PEG-T615C Handheld Logo
470 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
