Whirlpool duet steam tumble fresh 4.4 energy star wfw9550wwoo, my washer will not start, it acts like its going to the for locks and nothing
4 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 1075 Answers
SOURCE: What do the numbers stand
when the person put pencil to paper he comes up with the next model and so it becomes your model and also tell the dealers if you are looking a part what model you have.adrian,,,,
Posted on Dec 31, 2010
wpcustomer
  • 408 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: How can I turn off the control lock for whirlpool duet steam model #WFW9550WWOO
    Press and hold CONTROLS LOCK/UNLOCK for 3 seconds until the status light turns off
    Posted on Feb 28, 2017
    Feb 28, 2017 | Whirlpool Washing Machines
    We have a whirpool stackable..washer isn't getting much water
    Make sure hoses to washer are not trapped and that isolator valves are fully open. Isolators are located normmaly at the end of the copper pipe before the flexi hose to washer, they are often a small red or blue plastic tab that must be in line with the pipes to let water through
    Mar 14, 2015 | Whirlpool WFW72HEDW WFW72HEDW 4.2 Cu. Ft....
    Hardley any water going into washer...keeps tumbling with hardley any water
    Low water? This washer uses very little water to provide good cleaning results. You will see little or no water splashing in this washer. This is normal.
    http://www.whirlpool.com/digitalassets/WFW9250WW/Use%20and%20Care_EN.pdf
    Mar 14, 2015 | Whirlpool Duet 3.5 cu ft Stackable...
    Why does Model # WFW9750WLO1 has error F25?
    Drive motor tachometer error the main control cannot detect motor speed from the motor control unit there are a bunch of test involved but usually it is the Motor control unit located under the tub assembly. there is a technical sheet located on the machine sometimes under the top lid or down below why Whirlpool moves them around I don't know anyway it will provide the wiring diagram and explain how to ohm out the tachometer
    Sep 05, 2014 | Whirlpool Duet Steam WFW9750WL 27" Front...
    Whirlpool WFW9600T Washer - How do I run diagnostic mode?
    Actually, on my particular whirlpool steam duet model, I had to press the deep clean button four times to make it go into diagnostic mode.
    Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    66 people viewed this question
    Top Washing Machines Experts
