Question about Refrigerators
Serial number for ice king fridge freezer - Refrigerators
  • 833 Answers
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Posted on Mar 09, 2008
SOURCE: fridge doesnt work both freezer and refrigerator part not making ice
TRY REPLACING OVERLOAD RELAY..PARTS #67005560....IT COST TO ORDER AT THE INTERNET AT $27.45..........REPAIR SERVICE WILL CHARGE YOU , AS WHAT THEY DID TO ME $69.43 PLUS $120.00 FOR LABOR....IT SUCKS.....FROM ALEX ESMENA ..NORTH LAS VEGAS NEVADA
Posted on Nov 09, 2008
Sea Breeze
  • 4654 Answers
SOURCE: fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Posted on Mar 29, 2009
carputers
  • 255 Answers
SOURCE: whirlpool fridge serial numberEH1228713 model
replace the defrost timmer pcb
Posted on Sep 07, 2009
heatman101
  • 43501 Answers
SOURCE: Freezer and Fridge are both not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhsg
Posted on Sep 29, 2010
Hi I have a siemens fridge freezer and ice maker is leeking water and it come out of despencer serial number is ke07ze26690373 can you help
sounds to me that the water control valve is leaking on the back of refrigerator and causing water to overfill the ice maker. Need model number not the serial number should talk to someone about replacement parts
APPLIANCE 911
Jan 01, 2016 | Siemens Refrigerators
How do I find out the model number of my Kenmore elite Fridge
Since the freezer is icing up there could be many different problems a blockage or a problem with the defrost or timer of the unit if u greeting unit number is should be on inside of the door or back by the condenser best bet from what I see is get a tech to fix it they will find all those numbers that u need
Dec 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Model # - CTX16CPCR LF752813 - Serial number Its leaking water from the freezer into the fridge...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | GE PTS22SCRBS Top Freezer Refrigerator...
The freezer works well but the fridgedoes not get cold enough
all the fridge does is blow cold air from the freezer down into the fridge section so if the freezer is working then either the evap fan isn't working or the air ducts are frozen up.first thing open the freezer door,you should hear the fan blowing,if not the fan motor could be bad,if it is blowing,touch the back inside wall of the freezer,is there any ice or like snow on it,if so you have a defrost problem,one more thing to check,open the fridge door,look under the bottom draws,is there any water there? or any water dripping into the fridge section from the freezer,if so you have a blocked drain and the air ducts are frozen.let me know what you find,send the model number off of the fridge,open the fridge door and look on the left side up near the ceiling,you should see a tag with the model and serial numbers just send the model
Jun 05, 2011 | Kenmore 21.7 cu. ft. Top Mount...
My refrigerator side is not maintaining a cool temperature, and the green temperature light is off (the freezer side works fine)
the problem is in the freezer side,all it does is blow clod air from the freezer to the fridge side so if the fridge is warm the freezer side is either iced up or the fan isn't blowing,open the freezer door,do you hear the fan blowing,if not you could have a bad evap fan motor,also check the back inside wall of the freezer,you might have to pull the second from the bottom bin out and touch the wall and see if it's iced up or if there's frost on it,if so you have a defrost problem,let me know what you find and send the model number ,open the fridge door,on the right side up near the ceiling you'll see a tag with the model and serial number,i just need the model number and i'll be glad to help you
Oct 31, 2010 | Kenmore 57066 Side by Side Refrigerator
I have a Maytag MSD2758GE side by side refrigerator/freezer whose thermostat/defrost assembly has gone bad. Obviously the freezer has iced up and isn't working properly, but would that effect the...
sounds like you need to replace the adaptive defrost assembly. and yes, it will effect the performance of the fridge. the part number is 12002104 if the first 2 numbers of your serial # is 22; or 61003990 if the 1st 2 numbers of your serial # is 10; or 61005988 if the 1st 2 numbers of your serial # is 17. here is a breakdown showing the location it is # 13 in the picture. hope this helps.250
Nov 07, 2009 | Maytag MSD2758GEB Side by Side...
Fridge not cooling
your defroster seems to be out. This is located in the space between your freezer and fridge where your temp. control is. This defroster can be purchased at an appliance parts supply take model number and serial number with you in order to get the correct part. Once part is obtained follow instructions and unplugg unit before servicingf
Jul 13, 2009 | KitchenAid KSCS25FKSS Side by Side...
Freezer not getting cold
Call local Repair shop, No Fix possible, leak in the coils, can't repair.
buying new fridge.
Mar 22, 2009 | KitchenAid Architect® Series II KBRS22KT...
Refrigerators Logo
271 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
