Question about Behringer Pmp3000 16 Channel Audio Mixer
Behringer v-ampire lx112 amplifier
I want to know the way to do the settings and have each one stay in position when i change a-e how do i set my 17 -32? i can't seem to understand the user's manual. what do you suggest is the best setting to a gretech guitar g5120 model? i just can't seem to get the amplifier to do what i want and stay set. thank you bob hopkins
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: No sound out of amplifier
check the fuse
Posted on Dec 25, 2008
  • 5603 Answers
SOURCE: i cant find a user manual for a behringer
Only thing online is the spec sheet. Normally one using this device would know how to use it and the controls are really simple.
A user manual would NOT say very much as the use would vary so much. I would recommend searching for "noise gate usage" or similar GENERAL information. The controls are so few and simple anything you find will usually apply. You might search for a manual for another brand that might give information you need. The concept of these devices is simple and user manual will have a lot of commonality.
Posted on Jul 28, 2009
  • 5603 Answers
SOURCE: We are having problems with a Behringer PMP5000
It is NOT clear what configuration you have set up and what you consider the MONO output is, whether it is the power amp MONO side output or the line level MONO 1/4 inch jack on the top of the unit (this jack is NOT speaker output). If you can run normal stereo speakers using both sides of the power amp in the AB mode, the problems you are having is pilot error.
REMEMBER the main out 1/4 inch jacks are BALANCED TRS jacks... DO NOT put mono plugs into these.
A WARNING: If you use Speakon to 1/4 inch speaker cables, remember that the BARREL of side A is HOT, not the tip!!! You can fry the amp if you inadvertently ground that barrel someplace. (Side B has the barrel grounded) This information is NOT readily available in the manual and results in many a blown amp. They do this to implement the "Bridged" mode easily.
I have schematics and can unravel most any problem you are having.
Posted on Aug 20, 2010
Testimonial: "I can tell he knows what he is talking about."
  • 5603 Answers
SOURCE: I've recently purchased the NI
If you get beyond the 32/64 issue, check the audio setup for your audio device in your windows control panel. If your USB interface both recieves from your guitar and sends audio to your external amp, make sure BOTH the input and output to the USB are listed as the in and out in the "VOICE" tab when you go to the control panel and "Sounds and Audio device properties".:
Posted on Nov 23, 2010
SOURCE: Need Behringer V-Amp Pro repaired or find diagram & parts
my euro2442 is not prperli runing so plese send me your service center in india
Posted on Jan 04, 2011
What is the bias setting for the bxr1800h
Its the internal Voltage settings on the input gain.
Balancing it with current power setting sis a must.
Dec 13, 2014 | Behringer BXR1800H Ultra Compact 180 Watt...
What number on each channel on behringer ep2500 to set for behringer vp1220 speakers
It is best to start with the mark on the ep2500 directly up (12 o'clock position). Gradually increase the output on your mixing board (MAIN MIX) to get desired volume. I you find that you're getting close to -10 to 0 dB, then start increasing the volume knobs on the ep2500. Watch for clipping on the amp.
Oct 11, 2012 | Behringer Ep2500
As soon as I turn the volume over approximately 40W, the speaker keeps moving while making an awful sound at the same rhythm. I believe the speak may be burned. Is there a way I can fix it or I have to...
How do you know you are at 40 WATTS? This takes electronic test equipment to measure.
Tests to run. Observe the speaker cone with power off. Now turn it on... did it displace and stay there? If so you have a failure of the amplifier itself. Next, If you can place finger on the cone, move it gently in and out feeling for any roughness. If you feel roughness, the voice coil is fried and you be buying new speaker. A lot of the Ultra bass Behringer's use LM3886 power amp chips... sometimes in parallel, and a failure of one could cause this.
Aug 23, 2011 | Behringer Ultrabass Bxl3000
I have a V-ampire combo and it keeps ;loosing the factory settings when it is unplugged form the mains can you help please
You need to make sure the decimal point in the display is NOT blinking and then press the IN/OUT key for over two seconds to save the preset before turning the power off. Refer to page 9 of your user manual for this information.
Jul 31, 2011 | Behringer V Tone GMX212 2X60 Watt Stereo...
The input jack on the back of my behringer cabinet and the active input jack in the front of head have both cracked and separated. The Quarter inch cords for each respective input jack do not stay in. What...
The jacks have to be replaced. If you are not adept at repair, best to take it to a shop for the repair. Do NOT use the unit till repaired. If the jack shorts you may damage your amplifier.
Jul 31, 2011 | Behringer Ultrabass Bb410 1200w 4x10 Bass...
When I plug in my XLR microphone to my Behringer PMP3000 it only works on the Main/Mon function not the Main L/R function, and when it is working it only amplifies through one speaker. WHY???
Check if the PAN control for that channel is set at 12 o'clock position.
You can "pan" the mic to either L or R speaker or anything between.
On the Main/Mon setting, the level sent to the Mon side is controlled ONLY by the Mon level pot for that channel.
Oct 04, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
How do i hook up my new behringer pmp 5000 mixer to my fast track pro audio interface for home recording? I also want to be able to use 2 passive loud speakers. Any help most appreciated. Yep, im a newbie.
Passive loudspeakers are connected to the two "Speakon" connectors on the back of the unit. BUY GOOD cables for your speakers!!!! Whatever you do don't have a speaker line come loose while driving audio out !!! You will arc- out the rear-most power amp... I know, I repaired two of these now with the problem.
Connect the recording device to either the "tape OUT" RCA jacks or either of the pairs of MAIN out TRS jacks.
Set the slide switch for the MAIN L/MAIN R (upper position) leave this in this position unless you understand what the other positions are for to avoid damage. You will NOT need the other positions.
Further: Power ALL interconnect devices from the SAME receptacle source to avoid ground loops and possible damage.
YOUR passive speakers should be rated at least 300 Watts RMS continuos power handling or 600 Watts peaks.
Drive consumer stereo speakers with this and you will smoke the speakers and MAYBE blow the amp. This is a powerful amplifier and if you don't have at least 15 inch speakers you MUST really hold down the volume lest you blow the speakers.
Above all read the manual... yes, it is a bit hard to understand...
If you have a problem you can contact me by email for a bit of help. I have wo of these I have been using at venues now.
Apr 24, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
How do I connect my behringer mixer desk to
The first thing to do is to swap teh L & R INPUTS to the amplifier. Did the speaker that works change?
If som the problem is with the setting of the mixer deck. If it did not change, then the problem is with your speaker wiring of the dead speaker, the speaker itself, or that side of the amp.
If the working speaker did swap, that means problem is with the mixer. The question then becomes how are you connecting to the mixer. You should be using TRS 1/4 inch connectors or preferably XLR from the MAIN outputs. These are balanced outputs connections.
If the inputs are from one of the mono inputs, the PAN control for that channel will control how much goes to each speaker... If at center, both will get same signal.
There are so many possibilities that I can't evaluate them until you try the test to find if it is problem of the amp or the mixer that I have given you to try.
Dec 28, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer PMP5000. The Powered Output B dead
Make sure the three position slide switch is set correctly for the stereo usage, that is NOT the bridged OR the Mon mode.
MAKE SURE the pan pots are set to middle as they control the spit of the audio to the two channels.
This is a class "D" amplifier (switching) and there really isn't any fuse for a single channel.
MAKE SURE your speakon connections are good by swapping your speaker cables.
I repaired my unit and had to do that without schematics... Behringer will not give them out. Mine had a severe arc-over on one side power amp taking out about ten transistors and diodes and one swithcing regulator chip. Had to cut out the "cancer" of the burned board.
This unit uses a complementary output stage that is made up of one transistor on one side and a pair in parallel on the other. This drives the inductor/capacitor filter... I think the switching frequency is between 100KHz and 1 MHz as I recall. All those transistors were gonzo. It also fried the main power switching transistors in the power supply, several smaller transistors, diodes, and the switching regulator chip.
Also two 10 ohm power resistors were fried. They soft start this unit by charging the main caps via two resistors that limit the inrush current.
A small switching supply has to come up first before the main supply which sends the DC to the amp section.
Nov 23, 2009 | Behringer Music
I have a behringer pmp3000 how do i select the setting to allow me to have mains on one side of the out and monitor on the other? I know the selector switch must be in a certain position, but which one,...
You want the mon1/mono setting. The center position of the slide switch to use each half of the power amp seperately. Then fiddle with the controls BOTH in the strips and the faders to get desired result.
May 15, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer Pmp3000 16 Channel Audio Mixer Logo
178 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
