Question about Stihl Bg 86c Handheld Blower Cylinder Bg86c
Bg86c wont shut off - Stihl Bg 86c Handheld Blower Cylinder Bg86c
How to change flywheel on bg86c stihl blower
  1. Remove fan housing
  2. Remove spark plug and install piston stop.
  3. Remove flywheel nut.
  4. If flywheel is struck on use a puller. Stihl uses a knocker type puller that screw on the crankshaft and tapped by a hammer. Be carefully not the damage the crankshaft stud or the bearing.
  5. To install reverse the above skipping item 4. Just make the flywheel engages the slot in the crankshalf. The flywheel nut is torque to 17 nM or 150 in lbs. Don't over torque the nut or damage will occur to the flywheel.
Dec 16, 2014 | Stihl Garden
Security alarm wont shut off
Make sure all doors are closed, Key out for 3 minutes.
If that doesn't fix it, Try a battery disconnect for 3 minutes.
let me know what happens.
Mar 15, 2014 | 2000 GMC Jimmy
Bg86c spark plug change
the tool you got with the unit for changing other parts
usually is a T shape and has two hex socket at the top of the T and the stem has a torx 10 or similar on it
is also used to change the spark plug
Nov 16, 2013 | Stihl Bg 86c Handheld Blower Cylinder...
Stihl bg86c blower. Quit running after abt twenty mins of good strong blowing. Didn't sputter or anything, just dead quit. Not getting fuel to cylinder. Checked filter,gas lines, took apart cleaned and put...
take it in for a carby rebuild
the rest is perfectly fine
if you have been using e-mix fuels , don't as it damages the delicate diaphragms in the carby
Jul 08, 2017 | Garden
Bg86c stihl blower no spark new spark plug new coil gapped right take ground wire off still nothing
Sounds like a tricky one. Have you checked the magetism/functioning of the flywheel.? Tracking back the problem by having a new spark plug and coil would next point you to the flywheel. Coil to flywheel gap should be 0.25 feeler guage.
Hope this proves useful. :)
Mar 15, 2013 | Stihl Bg 86c Handheld Blower Cylinder...
Br 400 spewing oil out the back
The only oil in the machine is that which is mixed with the fuel. If the machine is still running well with plenty of compression then i doubt it would be the piston rings. With the limited information i would say to check the exhaust gasket between the exhaust port and the exhaust itself. Sometimes these can degrade and dirty liquid can be blown out of the gap.
Jan 11, 2013 | Stihl Bg 86c Handheld Blower Cylinder...
Will not prime-new bulb-new primer base have rebuilt carb
Maybe a problem with the 'connector' (item 4) as its the only way for fuel to pass in and out the fuel tank. Obviously assuming none of the pipes are leaking. Also check the fuel tank vent (item 2), these have valves in and can often perrish and leak to atmosphire. 3_2_2013_11_33_39_pm.jpg
Dec 19, 2012 | Stihl Bg 86c Handheld Blower Cylinder...
BG86C muffler Stihl Blower
Hi roberthoh288
Go to the following webpage and order your parts.
Please take time to rate me
Bud
http://www.jackssmallengines.com/
Sep 28, 2012 | Stihl Bg 86c Handheld Blower Cylinder...
Stihl Leaf Blower no top speed model BG86C
If there is a spark arrester in the muffler outlet check this is not blocked with carbon.
Jun 09, 2012 | Stihl Bg 86c Handheld Blower Cylinder...
Stihl Leaf Blower BG86c no top speed
take off the muffler and run it the screen inside it might be plugged and you can clean it off by opening the muffler
Stihl Bg 86c Handheld Blower Cylinder Bg86c Logo
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
