Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
DELL DIMENSION 5150 WON'T STAY ON
TRYING TO SOLVE FOR A FRIEND. THIS UNIT, 3.5 YRS OLD, WILL NOT BOOT. IF I START FROM A COLD MACHINE, SOMETIMES I CAN GET WINDOWS UP THEN IT GOES DOWN, WITH IN 30 SECONDS. THE POWER SWITCH GOES ORANGE. AFTER A COUPLE OF MINUTES THE HIGH SPEED CPU FAN COMES ON, RUNS FOR 30 SECONDS AND GOES OFF. THE POWER LIGHT WILL GO OFF, ALSO. HOWEVER, THE LOWSPEED CPU COOLING FAN WILL REMAIN RUNNING. AFTER A COUPLE OF MINUTES THE CYCLE STARTS OVER. ANY SUGGESTIONS?
THE ONLY UNIQUE THING ABOUT THIS MACHINE IS THE VIDEO CARD WHICH IS A POST-PURCHASE ADD-ON, WITH BOTH VGA AND DVI OUTPUT.
I HAVE NO WAY OF TESTING THIS VIDEO CARD. THE POWER SUPPLY FAN WORKS SO I AM ASSUMING THAT IT IS O.K.
  • fre0943 Jan 22, 2009
    Don't think it's the operating system. This definitely acts like a hardware problem.
  • 11,896 Answers
Even thought the fans are running, the power supply or the board has a problem
Posted on Jan 21, 2009
  • 1 more comment
  • Nate Stansfield
    Nate Stansfield Jan 24, 2009
    Your power supply is not sending the correct voltage to the cpu and therefore the cpu shuts down by default
  • Nate Stansfield
    I STAND CORRECTED. AFTER REVIEWING THE REPAIR MANUAL IT TURNS OUT TO ACTUALLY BE YOUR OPEATING SYSTEM IS CRASHING THE COMPUTER. YOU WILL NEED TO BOOT FROM DISK. IF YOUR COMPUTER IS NOT SET UP TO DO THIS YOU WILL HAVE TO PRESS F2 EXACTLY BEFORE THE WINDOWS SCREEN POPS UP. CHANCE BOOT OPTONS AND SELECT CD DRIVE.
    YOU THAT CAN BOOT YOUR CPU FROM THE CD DRIVE AND THEN DO A SYSTEM RESTORE TO A PRIOR DATE BEFORE YOU WERE HAVING THIS PROBLEM.
  • Nate Stansfield
    Nate Stansfield Jan 29, 2009
    There is a either a problem with one of the capacitors on your power supply or the voltage switch in the back is not on 110
    President:
  • 1,990 Answers
Welcome to Fixya! You will need to Reinstall your Version of Windows. You have a Corrupt Install that is Forcing Restarts.
Dimension E310 6 beep
if the beep pattern and led light pattern it's a memory problem, try reseating the RAM. Problem and solution is described multiple times here
Dimension E310 won boot up 6 beeps
21.June.2015
Apr 18, 2014 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Hi, I have downloaded from DELL website the Dell Dimension 5150 BIOS to upgrade the BIOS. I followed all the steps successfully and restarted the system but it just showed incompatible BIOS on start-up....
first to get a properly bios you need to get the whole description and download it to an floppy disk if it does if not try to boot from a cd...theres a hirens boot cd tools to fix since you already flashed wrong i assume you have some experience use the key tag of yor dell to get properly drivers...
May 27, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 wont boot past post. I've tried afew things but nothing works. can you help? thanks
If it won't go past POST then there is a hardware error. Try removing the hard drive and RAM. The mother board should complain at power on giving messages. If it does, try fitting the RAM module by module, then the hard drive.
Apr 17, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I've got a Dell Dimension 5150. After connecting to the mains the power light is blinking amber for some time, it then disappears and only then the computer can be booted. Unfortunately this delay is...
Check POST Boot messages for a flat Battery; Check Front control panel circuit over (remove); Check other USB connectors; Try a replacement Power Supply Unit.
Sep 12, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
My Dell Desktop Dimension 5150 does not start sometimes
loose connect or mother board problem (is your os & HDD is OK ?)
Jun 24, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not start!
This is related to Hardware.
There might be a lose Ram of data cable connection on Motherboard.
This type of issue is also seen when the there is dust accumulation on Process Fan and CPU fan resulting in over heating.
This might also be due to malfunction of a motherboard.
The third reason could be that SMPS his not working.
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 Boot Problems!
You can probably try two things here.
1) Go to the BIOS and reset the defaults.
2) Clear NVRAM from your Dell computer. Here is how you do it.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=4C1BF720A3E78F92E040A68F5A2811BE&journalid=7788D9829DCAA7C8E040AE0AB6E12FA2&Query=bnZyYW0=&SystemID=DIMENSION+5150/E510&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
PC was rebooting itself. I tried vacuuming out dust from inside box. Now it won't boot up at all. Numbers on front panel 3 & 4 stay lit and monitor only shows scrambled colours PC is a DELL Dimension...
Try manual cleaning the graphics card and the RAM by removing from the slot and rub the pins with pencil eraser as shown in the images.
And re-attach them to the motherboard, also clean the graphics card's fan with small paint brush. Works for me, hope same goes with you.
Sep 24, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
15 people viewed this question
Alun Cox
