New brother MFC J6910DW has error code 5A? - Office Equipment & Supplies
Joed911
  • 4338 Answers
SOURCE: Error code print unable 5A
On most printers that are manufactured today have an error chip built onto the motherboard of the printer. If your printer experiences an error. It will register it on on the chip. You will continue getting the error because it needs to be cancelled. To cancel this error follow the instructions below:
1) Turn print on
2) Unplug the printer from the power
3) Wait at least 70 seconds
4) Plug it back in
The error should be cancelled
From Brother's website:
Print Unable ##:
Turn off the printer. Wait a few seconds, then turn it on again. If this does not clear the
problem, call your dealer or a Brother Customer Service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe Diaz
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 10, 2009
komguy
  • 2306 Answers
SOURCE: Brother MFC-9440CN error 5A print unable
Error 5A unable to print is a problem with the high voltage power supply PCB, or with the engine PCB. A shop could tell you which one after some testing. Expensive repairs...
Posted on Jun 29, 2009
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Posted on Mar 02, 2010
How to reset ink absorber full Brother MFC - J6910DW . Please explain
This link has all the guides and manuals for your printer...free. The basic and advanced guides explain the error and also have a section on how to reset the machine.
Manuals MFC J6910DW United States Brother
Jan 15, 2015 | Brother MFC-J6910DW Multifunction Printer...
Tip
Brother MFC-J6910DW Review Printer
The professional series MFC-J6910dw will help your company develop with the versatility of duplex printing, copying and also scanning. Make two-sided documents approximately 11 inches x 17 inches house. Easy to arrangement wireless (802.11 b/g/n) or Ethernet network cable televisions with embedded assistance web link to others on the network. 3.3-inch touch screen different colors LCD display menu navigation attributes are interactive and easy to use. Dual paper trays (up to 250 sheets each) supplies an overall capability of 500 sheets. Utilizing Super High Yield (XXL collection) replacement ink cartridge around 2400 web page black and also colour 1200 pages. Neglected tight Fax, copy or scan with up to 35 web page ADF. 3 year minimal guarantee gives peace of mind.
Brother MFC-J6910DW Along with way over the typical paper handling, MFC-J6910DW offers all the standard features of any type of Office supplies, and much more. For a beginning, can print, check, and also Fax over a network and work as a standalone copier, facsimile machine, and also email of the sender. It can likewise check in tabloid dimension, utilizing the automated paper feeder web page 35 (ADF) or flatbed.
Duplex scanning lets you Fax records conveniently duplex, duplex printing as well as mixes while duplex scan additionally allows you duplicate both Simplex (one-sided) as well as duplex record to your liked copy simplex or duplex. Keep in mind, nevertheless, that duplexing for scanning is restricted to an optimal legal size web pages, although the ADF can take care of tabloid dimension web pages to scan Simplex.
The common setup. The printer offers Ethernet and WiFi assistance. For the tests I attached to a wired network and installed it on a Windows View system. Not incredibly, offered the similarity between the printer, MFC-J6910DW the outcomes are basically the very same, documents by file, the MFC-J6710DW, as well as the Bro MFC-J6510DW ($ 250, 4 stars), basically the budget variation of the very same ink-jet printer, with just one paper tray.
I clocked up all 3 printers on our business applications suite (making use of QualityLogic's hardware and software for the time) in 4.1 reliable pages per min (ppm), making them is bound to be a tabloid-capable inkjet asserts the fastest we've checked to this day.
Brother MFC-J6910DW
Amongst the single-function inkjets, editor options Canon Pixma iX7000 Inkjet business Ink-jet printer ($ 399.99 straight, 4 stars) are primarily slower, ppm 1.7. And also between inkjet MFP, HP Officejet options editor formerly 7500A Wide Layout e-all-in-one ($ 299.99 direct, 4 celebrities), can be found in at 3.4 ppm.
The quality of output and also other troubles
Generally, the top quality of the outcome of the MFC-J6910DW equal to or far better than many inkjets across the Board, and also the lid fits MFC-J6710DW MFC-and J6510DW. This text agrees with for a lot of company applications, as long as you do not have an uncommon demand for small fonts, as well as the photo output on picture paper are roughly matched to prints of **** stores, making it greater than adequate for a lot of business requirements.
Different colors in the graphics are slightly dulled down yet also within affordable variety. Right here once again, the quality is conveniently adequate for a lot of business needs, including, as an example, PowerPoint handouts. I see some allure in the default mode, yet it relies on how much of a perfectionist, you can take into consideration a sufficient graphics for outcome will certainly be essential clients or clients.
Dued to the fact that the MFC-J6910DW provides every one of the very same capacities that make MFC J6710DW-editor choices, including the capability to copy, fax, print as well as scan in tabloid dimension, and also print in duplex, extremely easy to suggest. Certainly, if you ever before have to scan a two-sided paper, you're far better off conserving a couple of bucks and purchase a MFC-J6710DW instead. Yet if the duplex Scanning is something that you need or believe you could need, Brother MFC-J6910DW is the apparent option, and also it is still cheap.
All in One Multi Function Brother MFC-J6910DW
on Mar 29, 2016 | Office Equipment & Supplies
How to solve ink absorber full brother mfc-j6910dw
You cannot change the ink absorbers as the machine requires a full strip down as they are located in the base. You will have to give it to a dealer for repair.
Jan 30, 2014 | Brother MFC J6910DW - Multifunction fax /...
MFC-J435w when trying to print I get error 5A Help?????
buy a new one. there is no repair for print heads. and don't use refill inks.
not good for print heads
Aug 01, 2017 | Brother MFC-465CN InkJet Printer
How to scan to an external hard drive from brother printer
Can't get the Brother MFC-240C printer to print. I have everything connected.
Oct 29, 2012 | Brother MFC J6910DW - Multifunction fax /...
Mfc j691dw unable to init AF what does it mean
I cant get rid of 'unable to init.42' from my new mfc j6910dw. Anybody know what does it mean & how to remove the mssge?
Oct 14, 2012 | Brother Mfc-j6910dw Inkjet Multifunction...
Brother mfc-j6910dw error 76 printer code
thank you everyone for your suggestions I will try each one until fixed, or I run out of suggestions :-)
Apr 28, 2012 | Brother MFC 9600 All-In-One Laser Printer
Brother mfc 210 c
defective main circuit board. Must be replaced! (Cost more than a new mfc at sale!)
Jan 07, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
148 people viewed this question
k24674
jasbo
jasbo
