Question about Mitsubishi VS-60803 60" Rear Projection Television
Menu won't turn off
In setting up the channel portion of the menu to DVD, I select menu and try and go back to the picture and it goes blank and the on screen menu comes back up and I have to go back in and change the input option to DVD. I can't seem to get the on screen menu to close. Also, when I try and shut off the unit, it will not stay off. It will power back on with the menu displaying. Any suggestions?
  • Rsanders Nov 11, 2007
    I'm having problems with my Mitsubishi VS-60803. It will come on when I plug it in. Comes on with the menu screen on. When I set channels and hit menu to go out of the menu, the set will turn off and then turn on by it self. When it comes back on its with the menu screen up. After awhile the set will power off and on by it self. If I hit the power off button, it will turn off and then come on by it self. Please help me.
To reset the whole tv press menu 1 2 3 enter
Posted on Jul 04, 2007
SOURCE:
I had DVD player hooked up to watch movies, I was trying to set a universal remote because I do not have one already. When I couldn't get the remote to work I pushed Menu on the front of the tv, chose...
Perhaps your dvd player output is set for channel 3 so you have to select that channel for the dvd player to play on your tv. Some older analog tvs have a separate input for dvd on the back or front. In that case you have to select that setting from the tv menu
Sep 17, 2013 | Televison & Video
Game mode won't turn off
simply change the channel and it sets it back to TV mode
Aug 17, 2012 | Toshiba 23HLV87 23 in. LCD Television
I have a Dynex TV thats about two years old. Model DX-L150A11 It does not repeat the picture size when channels are switched. I have to use the zoom feature to get the correct size picture. I tried all...
Do one thing Go to the menu of the tv. Select Picture setting and then select Advanced video and select Zoom mode. In zoom mode select Wide. If you hve already done this ,
Then select the Overscan option in the same menu page and select it as ON .
Next one select Auto zoom in the same menu page and select it as OFF.
OK
Sep 04, 2011 | Televison & Video
Sound problem
when you mail me,i have an service manual for you
[email protected]
Apr 02, 2010 | Philips 20DV6942 20 in. TV/DVD Combo
Blank Blue Screen
If you go to menu do you get that on the screen?
Nov 21, 2017 | Samsung CXN2085TP 20 in. TV/VCR/DVD Combo
Leaves blank TV screen when Return button operated
It sounds as though the unit is actually recording a DVD, but is getting no incoming signal to record. What is your recording source? Satellite and receiver? Antenna? Cable box? In the set-up menu, be sure you have chosen the proper input source; i.e., recording from where? You may be able to access that menu through the Function button on the remote, AFter setting that menu, be sure to press Return to restore the recorder to the ready mode. If you are using the RF input for recording, be sure that is selected as well, as opposed to L1 or L2. The input channel must match the output channel on your receiver, usually channel 3 or four. What is the model number?
Dec 02, 2008 | Sony RDR-GX300 DVD Recorder
Multimedia issue with the Razr V3
While you have already compared settings on the phones, check out these settings that are often overlooked regarding the Internet connection, and not just the messaging portion.
Run through the list, and if it all matches, you should be all set.
From the standby screen, press the Menu Key.
Scroll to "Settings," press Select.
Scroll to "WebAccess," press Select.
Scroll to "Web Sessions," press Select.
Scroll to "Cingular MMS" press Menu.
(if not there select "new")
Scroll to "Edit," press Select.
Validate the following parameters:
Homepage: http://mmsc.cingular.com
Service Type 1: HTTP
Gateway IP: 66.209.11.32
Port 1: 9201
Domain 1: leave blank
Service Type 2: WAP
Gateway IP 2: 0.0.0.0
Port 2: 0
Domain 2: leave blank
DNS 1: 0.0.0.0
DNS 2: 0.0.0.0
Time out: 5 minutes
CSD no 1: leave blank
Username: 1: leave blank
Password 1: leave blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: leave blank
User Name 2: leave blank
Password 2 leave blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: wap.cingular
User Name: [email protected]
Password: CINGULAR1
Press Done.
Press Exit.
Press Back
Press Back.
Scroll to "Messaging," press Select.
Press the Menu key.
Scroll to "Inbox Setup," press Select.
Scroll to "MMS Message Setup," press Change.
Scroll to "Server Info," press Change.
Scroll to "MMS", press Menu key.
Scroll to and select "Edit".
Validate the following settings:
Service Name: MMS
Server Name: http://mmsc.cingular.com
Web Session Name: MMS
Dec 13, 2007 | Motorola Mobility RAZR V3
No picture
Had the same problem ourselves.
Press set up on remote control.
Press the down button on remote control 5 times then press select.
Press the down button 2 times and press select.
Press select again.After 5 to 10 seconds the machine will switch itself off.
Turn off at the mains and then turn back on again and the dvd goes into preparing mode.
Go to AV channel and go through initial set up as you have just reset to factory conditions.Don't worry about any programmes on the hard drive they will still be there.Worked for us.
Nov 22, 2007 | Wharfedale DVD-M3 DVD Player
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
Ilo DVDR05
To change from p-scan back to i-scan with no video picture, mu1 model: 1.turn dvd on with no disc, wait 10 sec. 2.press "setup" 3.press "down arrow"(selects audio/video) 4.press "enter" (selects audio/video menu) 5.press "down arrow" 4 times (selects scan mode) 6.press "right arrow" (selects scan menu) 7.press "up arrow" (selects interlace mode) 8.press "enter" (should see picture) Or find a tv with p-scan capability.
Nov 30, 2006 | iLO DVDR05 DVD Recorder
Televison & Video Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
