Water continues to flow into my whirlpool top loader serial #2dwtw4740yq0
    Sergeant:
  • 291 Answers
Your inlet water valve likely needs replaced. The water supply hoses behind the machine attach to the the water valve on the machine. You will need full model number usually found around inner door to find correct valve.
Posted on Jan 11, 2013
ginko
  • 19396 Answers
SOURCE: Whirlpool AWG 354: Water flowing can not stop
Thet happens because either the water level switch/membrane switch is faulty, or because the water inlet valve is defective and stuck on open. See also : It's overfilling
Posted on Dec 19, 2008
  • 28 Answers
SOURCE: Whirlpool top-loader LSQ9200LQ0
Im no expert, just pretty handy with all things mechanical...hope this helps:
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Washing-Machine-Parts/Whirlpool-Parts-LSQ9200LQ0/Whirlpool-Parts-82574.cfm
Posted on Jan 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: Intermittent Overfill on Start of Cycle and/or Rinse Cycle
Replace the water valve.
Problem solved.
Posted on Mar 11, 2009
Testimonial: "Right answer, first time. Thanks very much. Great job!!"
SOURCE: whirlpool top load Model #WTW5500SQ0 water
If the water continues to run when you unplug the washer - replace the water valve. Part# 8578343
If it stops when you unplug the washer - problem is likely in the water level switch or silicone tubing coming to it. If the tubing is attached to both the tub and the water level switch and there is no holes/cracks in it - replace the water level switch. Part numbers: switch 8577844, tubing 3347780
Posted on Jan 12, 2010
Testimonial: "Thank you so much for the fast response. My husband will be forever grateful!! "
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
Model and serial number
If this is a Whirlpool manufactured TOP LOADER (such as the one you posted this question under), the model number and serial number are located on a nameplate along the wash tub rim under the lid.
If this is a FRONT LOADER, the model number and serial number will be located along the door facing as you open the door.
If you have questions, please post back and let me know. I hope this helps you.
May 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washing Machine, Product- F65, model7234,water overflow
top loader?usually its because your water valve is not closing because minerals have gotten into the water valve.but water would come into washer even when unpluged.another thing can be if when over flowing and u unplug it and it stops fillig/over flowing.your presure switch hose will have come off the water level switch or a mouse chewed a hole in it.its a clear tube thats running from your water level switch.i hope that helps god bless,tom
Jan 01, 2009 | Washing Machines
Dec 19, 2008 | Washing Machines
Water is not flowing into the machine
There are a couple of possibilities:
  1. Are the hot and cold valves open?
  2. If there are filter screens in the lines, are they clogged?
  3. If set to warm, does any water flow at all?
  4. If there is no water flow, first check the water level switch to see if it is working...this is located on the bottom of the machine...it is generally round and has a tube running to the tub and two or more wires.  It should have closed contacts to let the water valve work.
  5. If there is some water flow, the valve is likely bad or the supply is clogged.
  6. If the switch is continuous, the problem may be the timer.
  7. Is the water temp switch good?...unlikely.
Dec 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Whirlpool top loader 9 kg - I can't see any serial no.
There are no lint filters on this machine. The lint is pumped out with the water. There may be a restriction in the drain line starting where it connects to the tub or the small drain holes in the inner tub may be clogged.
Jan 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
