Question about Sloan M-101526-F Flushmate?® Complete Replacement System for 501-B Series
Hissing sound after flushing a flushmate
After flushing toilet a hissing or sizzling sound comes from it for about 1/2 hour.
  • Carol Feb 07, 2013
    Where is it? Can it be fixed easily by a novice?
  • Bill Dickerson
    Bill Dickerson Feb 07, 2013
    Holds the water. It is essentially the part that keeps everything moving or still.
  • 979 Answers
The washer that shuts the water off is failing. It shut stop incoming water completely when the tank is full.
Posted on Feb 04, 2013
5 Suggested Answers
  • 22 Answers
SOURCE: FLUSHMATE TOILET BOWL WON'T HOLD WATER
The Flushmate system won't cause or contribute to water draining or leaking from the bowl.
Negative back-pressure in your drain/waste/vent piping could be siphoning the water out or you may have a crack in the bottom of the bowl or trapway that's allowing the water to leak out.
If the floor under the toilet (actually underneath it) or around the edge where it's caulked to the floor is wet, your bowl may be cracked. If not, your plumbing system may be siphoning the water.
Either way, you can exclude the Flushmate from the equation and focus on the porcelain fixture and your drain/waste/vent system.
Hope this helps.
Posted on Jun 07, 2010
  • 22 Answers
SOURCE: flushmate 503 - loud squeaky scary noises
Have you tried the "800" number on the tank label or visited the Flushmate Web site?
Could be related to the plumbing or the Flushmate. Technical support should be able to help you pinpoint the cause and, if it's Flushmate-related and under warranty, provide a resolution.
Posted on Sep 24, 2009
  • 22 Answers
SOURCE: My sloan flushmate toil I think is backiing up.
You may have a leak in the discharge extension, lower supply, or drain valve. I suggest you call Flushmate's tech support line (on the Flushmate label) and see if they can help you out.
Good luck
bearsfan7538
  • 119 Answers
SOURCE: problem with flushmate m-101526-fnoe enough water
Did you replace the cylinder cartridge?
Posted on Dec 08, 2009
How do I lower the water level in the toilet bowl of a Slone Flushmate? It keeps getting higher, little by little after each flush.
The flush valve may be defective but some tinkering with the refill level setting may work.
Jun 24, 2017 | Home
My flushmate toilet got clogged. I have unstopped the clog, but it won't flush. The flushing process works, but the water isn't pushed down the drain.
My flushmate toilet was stopped up after a bm.
Because I could not get to it right away, I let it
sit for several days. Tried calling the Flushmate
800 number. They don\'t work on weekends and
it was Saturday. What to do? Read the info on
the internet but could not find solution. However
first I shut off intake water valve required for any service
performed. Did that. Got a large plastic spoon.
Fashioned a container out of supermarket paper
bag cut in half. Used bottom half and inserted it
inside double Safeway plastic bags. Scooped out
the toilet paper and feces into bag. Found most
of feces had disintegrated in the toilet coloring
water dark brown. That was a good sign. Less
solid matter to flush. Tossed bag into garbage.
Flushed the toilet and it worked perfectly. This
method works for stopped toilet only. If problem
is in the sewer line, you need another method.
Oct 19, 2011 | Sloan M-101526-F42 Flushmate?® Complete...
Flushmate 503 sprays water out of top of tank, apparently coming for under the flushmate system. The valve doesn't seem to leak. Iahve pressure tested it.
Turn off the water supply at the wall, flush the toilet to relieve the pressure inside the Flushmate, and call Flushmate Consumer Services at 800-533-3460 M-F, 8:00 - 4:30 ET.
They'll need to know the serial number and approximate date of installation of the Flushmate.
You could alos fill out a confidential "contact" form on the contact page of the Web site, www.flushmate.com.
If yu need to use the toilet in the meantime, you can "bucket flush" it by pouring 2 to 3 gallons of water into the bowl. This will generate a standard siphonic flush and won't give you the pressureized extractiopn but it will keep the toilet usable until a Flushmate support tech can diagnose the issue and provide a resolution.
Aug 17, 2011 | Sloan M-101526-F31 Flushmate?® Complete...
Just hooked up new pressure asist tank & bowl,turned on water to it,and it want flush.what i mean about want flush, is it will flush but water does'nt go down,as if it's not staying open long enough.
Sounds like you have a clogged drainline or vent-stack. Fill a large bucket with about three gallons of water and dump it quickly into the bowl. If the drainline/vent is clear, the toilet will "flush" like a gravity toilet and the water will drain from the bowl almost as fast as you can pour it in.
If the water level in the bowl slowly rises (as if it's about to overflow) and then slowly drains, you have a clog somewhere.
All toilets, regardless of their flushing mechanism, require a clear, unoibstructed drain/waste/vent system to extract waste.
If the toilet "flushes" with the bucket of water, you may want to call Flushmate tech support (the number is on top of the tank) or check out the installation and troubleshooting videos at howto.flushmate.com.
Hope this helps.
Aug 18, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
We have 4 flushmates & one of them does not shutoff after flush'g & fills up our septic tank ----how do i ajust it to stop
there is no adjustments for the flush mate. only adjustment is for the handle. if your flushmate is not shutting off after flushing, you need to replace the flush valve.
Aug 09, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
Sloan Flushmate M-101526-F3-Constant Filling
There is a lifetime warranty on the tank and a ten year warranty on parts. Call flushmate and ask. they will not tell you otherwise.
If you use any chemicals in the tank it will void the warranty.
Sep 25, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
Flushmate 503 - loud squeaky scary noises
Sep 21, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
How do i repair an automatic toilet flushing valve ?
It really depends on the nature and cause of the problem. You can view helpful videos at howto.flushmate.com or download owner's manuals at flushmate.com.
Hope this helps.
Aug 26, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
My sloan flushmate toil I think is backiing up. When I take the lid off and flush the toilet water shoots out the front side of the flushmate. What could the problem be or is it broken.
Good luck
Apr 14, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
Sloan M-101526-F Flushmate?® Complete Replacement System for 501-B Series Logo
544 people viewed this question
Top Sloan Home Experts
richochet
Andrew Taylor
Andrew Taylor
frankdanfelt
Are you a Sloan Home Expert? Answer questions, earn points and help others
