Question about Vizio GV42L 42 in. LCD Television
VIZIO GV4VL cuts off the bottom of screen
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The TVs picture looks great but it cuts off words at the bottom of the screen I have tried to adjust the vertical and horizontal settings but this doesn’t help.
  • 54 Answers
On the tv's remote you have a button which says one of a couple things. 1) pic size 2) ratio 3) zoom 4) aspect. using that button push it a couple of times until you get to either 16x9 or full depending on the brand of tv you have
Posted on Jan 22, 2009
Picture is cut off on both top and bottom. adjusting aspect ratio doesn't fix the problem
Sounds like a power supply problem. You could just change the board , that the easiest way. If you have some knowledge of components you could look at the capacitors on the Power Supply board and if you find some leaking (brown liquid), or bulging I would change those out.
Apr 09, 2013 | Vizio P50HDTV10A 50 in. Plasma HDTV
Picture seems to big for TV.cant read bottom words on screen and words are cut off on side also. Cant see scrores on any sports or read peoples names on bottom of the screen
Using the menu or settings button on your remote, access the TV's menu and find the area for picture settings and zoom. You're likely set to a zoom mode, so cycle through the options until you find the zoom setting that sizes to your TV best. (On most widescreens, the best picture is often on the setting 'panarama.'
Mar 12, 2011 | Vizio L37 Television
On my Apex TV screen, some of the picture is cut out. How can i adjust the TV resolution?
You cannot adjust the resolution in CRT TVs. Its not like a monitor that is compatible with a number of resolutions from a computer for example. CRT TVs resolution's dont work like that.They take an input usually from a composite, Svideo or coaxial source and display it on the screen.
When you say the picture is cut out is there a black bar on top/bottom/middle of the screen? In older CRT TVs that usually means a problem with the TV itself and would need to be taken in for repairs or replaced.
Mar 05, 2011 | Apex Digital AT2708S 27" TV
My Vizio LCD HDTV 32in. doesn't seem to "center" the picture on sports programs so when they have a score box in the upper left corner most of it is cut off and can't be seen. Doesn't matter how I adjust...
This is a common complaint. To be frank I don't have the exact term for your Vizio, but most recent LCD and plasma TVs have the ability to "zoom" or adjust "picture format" (those are two commonly used terms) depending on the signal source and format.
it has to do with the fact that currently there are both classic style format 4:3 signal sources as well as new HD 16:9 signal sources and on top of that it may happen that a 4:3 signal source is distributing adjusted image from a 16:9 or other signal source. Think cinema adjusted to run on classic TV - remember the vertical strip of image with two huge black areas below and above it?
Well the ZOOM or PICTURE FORMAT allows to adjust such an image so that you cut the "void" are by scalling (enlarging) the visible area to fit the whole screen.
A problem then appears when the signal source is normal and showing full screen. Then, because of the enlargement, you start missing some of the picture. Before there was nothing there because it was showing adjusted wide (cinema) format to the TV box format, but when the new TV box format gets enlarged it sure starts missing around the edges.
That's what you're seeing.
More and more TVs do not have the ability to adjust that through the TV itself. Don't ask me why, but they can only do it through the remote.
So if you have an original remote there MUST be a button there that's called ZOOM or FORMAT.
It does the trick.
Hope this helps. If it does do not forget to rate it.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Vizio L32 32 in. LCD HDTV
Images enlarging on edges of screen
has to be adjusted by a tech.some tvs do stretch at the edges this should also happen when there is writing coming across at the bottom of the screen.there is a few things i look at before buying tvs,past experence.
Apr 25, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
I am having trouble adjusting the picture on my vizio LCD TV. The heads are cut off and any of the words that should appear at the bottom of the screen are cut off. What can I do?
It could be a format issue. Look for a button on your remote labeled format or aspect ratio. Press it until it looks right.
Dec 29, 2009 | Televison & Video
Projector Adjustment for Magnavox 51mp392h/17
this requires secret codes not given to the public.call a tech.to repair your tv
the plublic can not repair tvs.this web site is a joke.
Jul 19, 2009 | Philips Televison & Video
Heads cut off on the screen
Ocean's Eleven. Best remake movie, I think.
I believe your TV is in "ZOOM" mode for the screen. This will make a 4x3 picture come up closer to fill in the 16x9 screen, but this cuts off the top and the bottom.
Keep pressing the WIDE button on your remote until the picture looks best.
If you have HD channels, the screen mode should be on NORMAL. HD channels will have the 16x9 screen format.
The non-HD channels will have 4x3 screen format. When the screen mode is on NORMAL, you will have the cut off picture on the sides because the 4x3 format will not fill in a 16x9 screen.
May 30, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Picture cut off
No adjustment needed on these LCD projection. Your problem is in your setup menu. Your default is now is set ZOOM. That is why the bottom of the picture is cutting off. Go to Menu, setup and screen size or something close to that.
Best regards
Circuitcity
Jul 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Bottom of picture is cut off
Usually when the vertical starts shrinking slowly, it is due to capicators getting out of tolerance in the vertical output section of the chassis. If it can be adjusted out through a service menu, you'll probably need a tech with the right equipment to perform it.
Jan 01, 2007 | RCA F27440 27" TV
Vizio GV42L 42 in. LCD Television Logo
513 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
