Computer doesn't start - Computers & Internet
  • Jason May 11, 2010
    Can you clarify what your problem is? Just saying it doesn't start could mean quite a few things...
    Scholar:
  • 170 Answers
Lets start with the obivious, is it plugged in? Is it hooked up properly? Did it ever start? Does the monitor work? What kind of computer is it? Need more help? Let me know. Good Luck!
Posted on Jan 22, 2009
Computer doesn't reboot after turning off.
You could have a power supply problem. Start up is ******* a ps until it is fully up an running. You may have bulged caps in the power so that takes awhile to full charge up. I would start there. No other reason for it to do that because it runs fine after it gets started.
Jul 21, 2017 | Computers & Internet
Hp compaq 6200 not starting
A few things can go wrong when you are performing a computer upgrade of any kind, because during an upgrade, you remove and install parts, and it's easy for something to come loose, which may prevent the computer from starting.
Open the computer case, unscrew the video card and lift it out.
Make sure you move any release tabs before getting the video card out.
Put the video card back in place.
Check the nearby components, and make sure everything, especially the memory, is securely in place.
Close the cover and try to start the computer.
If it still doesn't start, replace the new card with the old card and check again.
If the computer starts with the old card, the new card is likely bad.
If it doesn't start with the old card, you may have shorted out the power supply and need to replace the power supply, but this is rare.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
Make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error.
Hope this helps
Nov 13, 2012 | HP Compaq 6200 Pro - Micro tower - 1 x...
Memory upgrade on gx280 beeps on boot but doesn't start. memory beeps 1 234 5 6
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer. The other issue is if that model supports 4 gig memory.
Aug 30, 2012 | Dell Computers & Internet
Start cmos setup on Acer net book
to start cmos in most computers start your computer from complete shut down and immediately tap tap tap f/2. If this doesn't work look at the bottom of the screen to see boot options.
luck
cwynnj@yahoo.com the Computer guy
Dec 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
When i power my moniter it shuts itself off in ten second by itself
Either your computer is sending a signal it doesn't support (too high resolution or refresh rate), or the monitor has power issues. Try starting the computer and going into the setup screen. If the monitor stays on, it's a resolution/refresh issue in the OS. If it doesn't stay on, it'll be cheaper to get a new monitor.
Jul 06, 2011 | HP Computers & Internet
I accidentally plugged the router out and now my Internet connection doesn't work. The local network connection is displayed as working and responding nevertheless. The second and fourth (starting...
Power down your router and computer. Wait 15 seconds, then turn on the router first, then the computer. If this doesn't work, you can also try rebooting the modem as well. You will then need to power all three down, then start with the modem and wait a minute as it boots up and runs its auto-tests, then the router, then the computer.
Jun 20, 2011 | D-Link DIR-300 Wireless Router
My msi u100 starts up but then the battery light goes red and shuts down how can i fix it
HI Cws666, try to charge your computer for a full 3 - 5 hours without interruptingit, than try again.
If that doesn't work, try buying a new battery.
If that doesn't work send it to computer's brand labs.
Jun 08, 2011 | MSI Wind U100-280US Netbook
Computer doesn"t start keep rebooting
Try moving the card to a different slot.
Swap slots with another card if all the slots are full.
If this doesn't work, post a reply / add a comment to this post and I'll dig deeper for more options, but in most cases like this, using a different slot or swapping slots with another card will most often fix the issue.
Jun 04, 2011 | D-Link DWA-552 (ASKU56185) Wireless...
My system is automatically restarting
Please make sure that all memory modules inside of the comouter are seated tightly.
If everything inside the computer seems intact and the computer still reboots try to go to safe mode and check if will do the same.
From shutdown, turn your computer on and start tapping the F8 key (F5 for some computers) when the menu appears choose either safe mode or safe mode with networking. check if the computer would still restart in that mode.
If it doesn't: press and hold the windows key on your keyboard then press the letter R, when the Run box comes up type in msconfig go to the services tab, tick Hide all Microsoft services and the click Disable All. Go back up to the tabs and click start up click Disable all then restart the computer.
If it still restarts in normal mode check if it's giving out a Blue Screen error.
If it still restarts in safe mode, shut the computer down and go to the BIOS.
From shutdown turn the computer on and start tapping F2 or Delete Key on your keyboard if both doesn't work check what key does your computer say to go to setup.
See wether if it will restart in the BIOS.
If it does, You may want to have the hardware parts of your computer checked.
If it doesn't my recommendation would be to reinstall yout operating system.
Hope you find these steps helpful!
Apr 30, 2011 | Intel Motherboard
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
