A few things here one with no water coming in the water solonoid could be blocked or is fualty,check to ensure the filter in the soloniod is clean do this by removeing the inlet pipe from the conection at the back of the machine and in the solonoid is a small filter remove it and clean ,reconnect the water and try again,if no water is taken the chances are that the solonoid is gone replace it after you have checked the following ,second if water is taken then see if the timer moves if it does not then look at replaceing the timer again after going through all the possibilities,the motor running is part of the process the motor is meant to run to drain exsess water before takeing new water .the only other thing is that the pressure switch has not released normally from an obstuction in the pressure pipe worst case the switch itself has packed up to test is easy locate the pressure switch and blow into it and if you hear a click and another click when you stop blowing it should be ok if not replace it.
will not wash- not sure if it is the same model, but i turn it on to wash, and it doesnt start a...
(More)
will not wash- not sure if it is the same model, but i turn it on to wash, and it doesnt start a cycle. it will fill with water, but not engage in washing...
when i turn the dishwasher on the water comes in and it sounds like it is washing but when i open...
(More)
WHEN I TURN THE DISHWASHER ON THE WATER COMES IN AND IT SOUNDS LIKE IT IS WASHING BUT WHEN I OPEN THE DOOR THE DISHES ON THE TOP RACK ARE NOT WATER. IT SEEMS LIKE THE ARM IS NOT THROWING THE WATER UP THERE WHAT DO I NEED TO FIX IT.
