Question about Abit VP6 Motherboard
POST/Boot up problem
I have just tried to get this machine running which I've had stored for some time. I'm sure it was working before I stored it away. Anyway, the motherboard won't boot. Everything powers up but I get a blank screen. I get a number lock and scroll lock light on my keyboard come up, and after fiddling with the machine only the scroll lock comes up now. I have reset the cmos many times. I have tested it with different sticks of memory and vga cards. Since its a dual CPU motherboard, I have also tested both CPU's, I get the same problem whatever combination I've used. Any ideas what might be the problem? I suspect the CPU's have both bitten the dust but not sure how likely it is for both to go at the same time?
  • 3 more comments
  • Harpinder Sanghera Jul 03, 2007
    No I can't get to cmos or boot, It's just a blank screen with scroll lock light on Keyboard lighting up.
    I've tried that. I've had it completely stripped down and have used another mouse, keyboard and VGA card, still nothing on screen.
  • Harpinder Sanghera Jul 04, 2007
    I have tried using one cpu in the first socket, then in the second socket, i did the same thing for the second cpu. They're both 133FSB PIII coppermines, same voltage, same speed, same stepping, same FSB. I've tried 2 agp vga cards and 2 PCI cards all which work in my other systems and have used them in this machine in the past. I've tried two different power supplies.
    All these components that I've used on this motherboard used to work in the past.
    I've got 2 PIII 1GHZ CPU's coming in a few days so will test them out on this machine. Hopefully it will work. I'll let you know how it goes.
    Thanks.
  • Anonymous Oct 14, 2008
    My problem is, it shows the first screen with bios version and scanning system but won't go to bios setup nor does it shows the HDD and CDROM on the scanning progress..
Look at the caps on your vp6.any bulged/leaking?
Posted on Jul 12, 2008
  • 97 Answers
Use only 1 CPU in the first socket. Check the bus speed on the CPU's. If they are not the same clock or frequency (800mhz@133FSB for example) it will not work. If an AGP slot is available, try it for video first. Most MOBO's default the AGP slot, if not try the PCI next. You should have a 300watt power supply at least. This board is 133FSB and a PIII CPU at 100mhz FSB will not work. VIA chipsets can be flakes to some CPU's.
Posted on Jul 03, 2007
  • 432 Answers
So what your saying is, it DOES boot and you can get to the cmos setup, correct?
  • 2 more comments
  • Raymond Scott
    Raymond Scott Jul 03, 2007
    View of advanced setup
  • Raymond Scott
    View of chip setup
  • Raymond Scott
    Unplug all the devices from the motherboard, floppy drive, hard drive, cd-rom, speaker cable, the ribbon cables going the the hard drive, floppy and cd-rom. Take out the modem. We just want to work with a bare minimum setup to get it the splash screen. If you don't have the manual, you can download it here:http://www.vp6-board.com/_public/VP6_Eng...
    Try another ,mouse, keyboard, and vga card again.
  • Raymond Scott
    Well shoot, I guess you solved your own problem. CPU's could be fryed. If you want to buy another CPU, you can get it on this site for $8.00 http://www.pricewatch.com/cpu/pentium_ii...
    And to think these things use to go for $400.00
Acer Aspire M5201 Boot Problem
i understand you got moore then one drive.are you sure at you boots from windows drive.C:\
Apr 05, 2013 | Computers & Internet
Stihl MM 55 won't run/start
You will have to have extremely clean fuel with stihl carbs. As the orifices are extremely small some are so small you can barely get human hair through them. So make sure you are using correct mixture if it says 50-1 u better make sure you use 50-1. Also make sure the can has no trash of any kind. And main thing make sure the fuel filter is in place and not at all damaged.
Aug 05, 2017 | Stihl Garden
Everytime I copy from the adf top feeder, I get a black line running down the copy. I've cleaned, reset, etc., and I sitll get the black line every time. Help!!!???
CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
  • The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
  • The machine cannot send or receive faxes when the power is turned off.
  • If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
    Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
  1. Open the Document Tray.
  2. Open the Document Feeder Cover.
  3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
  4. After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
  5. Close the Document Tray. speed printer service
    http://www.smoothprinterservice.com/
Dec 18, 2012 | Canon MX882 All-In-One InkJet Printer
. . . overclocking nightmare!!!
Motherboards, processors, and sdram must be timed properly to work together. Seldom have I found an overclocker who understands how timing works.
From your cryptic question it is not possible to offer a solution. Although in the United States, "won't give in," means to stand your ground, to prevail, stubbornness, to be uncooperative, failure to concede, continue to compete while injured, obstinacy in the face sound counsel, but I've never heard it used in reference to a motherboard.
I would suggest you make some reasonable settings in the BIOS setup program (hit del to run setup), and be patient. Microsoft Windows tracks previous boot outcomes, and uses the information to make adjustments in both hardware and software.
So, say your machine started to boot, but it froze or blue-screened. On the next boot Windows will make adjustments to hopefully improve the outcome.
If you make hardware-timing adjustments, Windows will already have planned the next boot, but now the user-configurable hardware settings have changed before Windows even gets hold of the machine!
Motherboards do the same thing. If the computer didn't start at all, but there were no beeps, the motherboard adjusts the timings so the computer can start.
After power-up, the BIOS might require you to run 'setup', but you can just hit 'esc.' As the BIOS turns control over to the operating system, it puts the timings back where you had them set (with exceptions), and Windows might even boot.
The conclusion is: be patient. Don't try to change a setting after every freeze or malfunction, unless you sure it must be changed. If two successive boot-ups fail, you probably need to show some mercy and loosen up on the timings.
Jul 21, 2012 | Computers & Internet
My computer (3.0 GHz Pentium 4 with Asus P4P800-E Deluxe mobo) will boot to the POST screen, and it successfully identifies all of my hardware (memory, hard disk, DVD-ROM drive, etc.), but then won't...
Checked your RAM chips? Remove them and boot up and see if it will beep. If you have another DVD drive, swap it and try again. The board battery rarely goes, and only change it when it is not keeping the date/time etc, it won't help in outputting video.
Sep 10, 2011 | ASUS P4P800-E Deluxe Motherboard
This machine has a G31MX board. It will not boot no matter what order I put the boot order in. I tjust restarts. Pressing tab for post screen or delete for bios it functions normally, but when I try the...
Unplug all drives and USB connections from the board. See if it goes far enough to error out on finding a boot disk. If it does, add items back in one at a time. When you hit the magic one, the problem will return.
If it happens even with nothing connected, you've either got a bad power supply, or the motherboard's shot.
Jul 06, 2011 | Foxconn G31MX-K socket LGA775 motherboard
Windows boot manager failed to start - message - a recent hardware or software change might be the cause. I don't have a repair disc and it will not reboot. Thank You L
sorry to hear about the problem
I've used easyBCD to repair a windows boot manager, you may have to download it in another working machine, then burn it as bootable cd (using nero or similar image burning software), pop it in and when you start your computer make sure you have your cd/dvd drive unit as the first boot option so you go right into the cd ,
try the following instructions here to see if they may help, post back if you have further questions
repairing bootmanager
hope this helps
thank you!
May 16, 2011 | Advent Netbook
Diference between Cold boot and warm boot
A warm boot restarts the mobile computer by closing all running programs. All data that is not saved is lost.
A cold boot also restarts the mobile computer, but erases all stored records and entries from RAM. In addition it returns formats,
preferences, and other settings to the factory default settings.
Apr 07, 2008 | Symbol MC1000 Barcode Scanner
Gateway 7405gx boot failure
Hi Dan -
On this particular Gateway series of laptops, there is actually a bios "chip" you can replace entirely. It's sitting in a cradle right next to where the keyboard connects to the mobo (square black chip, one angled corner). It's very easy to pop out and replace, and is definitely something I would try.
You can do a search on eBay for "gateway bios chip" and you should have some luck.
I hope all goes well.
Nov 22, 2007 | Gateway 7405GX Notebook
Unable to boot past BIOS
Hi Hanjiya, I suspect a hardware failure; I would pull off everything you can to make this as basic a PC as you can. Hardware POST checks, fans and LEDs are good to do very basic tests and elimination but are not definitive tests. If it still doesn?t work I would try using a power supply tester or switch out with a known good, followed by the RAM, processor and video card leaving only the motherboard. If you get this far and the problem is still there then your failure is the motherboard. Look for damaged capacitors with rounded tops or corrosion at the base. I?ve had two 2004-2006 era Dells refuse to complete the POST because of defective capacitors just recently. If still no luck you might try buying a pre-POST diagnostic card ($50 and up). If you don?t want to invest in that you should consider taking your PC to a shop that does have one. I know it runs again most of our personalities to pay a tech but consider this. I?ve run into lots of people who spend weeks and big bucks troubleshooting a problem someone with the right equipment can diagnose cheaply (overall) the first time. Without the test equipment or a similar PC you can use for parts you?re going to have to start buying parts one at a time in a process of elimination. Let us know if you have any more questions or comments and please don?t forget to rate the posting.
Jan 17, 2007 | ASUS P5LD2 Motherboard
Abit VP6 Motherboard Logo
117 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
