Question about Dishwashers
How do you delime the hobart CL44E - Dishwashers
5 Suggested Answers
bigg t
  • 640 Answers
SOURCE: How do you delime the hobart LXi
With the unit off----hold the wash/delime button in and hold the on button in for 5 seconds.the dishwasher will fill and the delime icon will be on,then it will prompt you to add delime,add the delime and hit the wash button.It will run for 5 minutes,fill up twice and drain twice then turns off.
Posted on Mar 02, 2009
  • 10865 Answers
SOURCE: what product to delime the Hobart LXi ?
Ppur a full cup of apple cider vinegar into the empty dishwasher and run it for the full cycle. Then run it again with nothing in it. This will delime your machine beautifully.
Posted on May 01, 2009
  • 109 Answers
SOURCE: the hobart lxih is stuck in delime.
To reset or clear delime message, on control board there are 3 buttons. from power off, drawer open, manget on door switch, door closed, hold PROG on board and press the ON key on keyboard. pressing select moves to next poption, up arrow increases setting. step through select until you see delime, settings for LXi are de for disabled, and 1 through 65= x100 cycles. rg if set at 5, after 500 cycles the message apears. To keep the settings and clear the message a delime sequence needs to be run precisely as described.
DO NOT MIX DELIME ACID, RINSE AGENTS OR OTHER ACID WITH BLEACH PRODUCTS, OR HAZAEDOUS GASES WILL FORM.
With machine off, remove rack , close door, press and hold wash/delime key and press ON. Delime will be lit on display, release wash/delime key, and let machine fill. you should then see ADD and DELIME on the display, open the door and add the delime agent following supplier's instructions precisely. close the door, press wash, delime will flash. After delime is complete power is turned off. Inspect the machine and repeat if necessary.
DO NOT LEAVE THE ACID IN ANY LONGER THAN RECOMMEDED.
Posted on Aug 14, 2009
bigg t
  • 640 Answers
SOURCE: How much delime agent should I use to clean the
Depending on how often you delime the dishwasher use 2 cups.The delime light will come on after 1000 cycles set from factory default.If the delime icon is lit and beeps,turn the unit off.
Push and hold the delime/wash button and on button for 5 seconds and youll be in delime mode.
The unit will fill and heat up and display "add delime".Open the door add the delime and press the wash button.The dishwasher will run for 5 minutes then rinse and drain twice then shut off.When you turn it back on the delime icon will be gone.I'm a hobart tech and repair these dishwasher often,any questions let me know and please rate me,Thanks.
Posted on Nov 24, 2009
Testimonial: "Even more thorough than I asked! Thanks!"
Cl44e Hobart Error power supply fault any one face this problem .
check 12V fuse
Fuse 1Amp
if ok the 12V is off repair power card
Dec 19, 2016 | Hobart Dishwashers
Wiring diagrams for hobart dishwasher model CL44E
Manufacture! possibly ebay, possibly site: thefind.com
Mar 04, 2015 | Hobart Conveyor Dishwasher Right To Left;...
How do I delime a Hobart LXE series dishwasher?
run load empty with a cup off salt in place of detergent
Aug 29, 2014 | LXeC Commercial Undercounter Dishwasher...
Hobart am15 scrolls message drain and de-lime with a constant beeping??
It may have reached the number of cycles to trigger a delime warning. Either follow the procedure in your operator manual to delime, or go into the control board settings and either change or turn off the delime timer
Dec 04, 2013 | Hobart 29 in. AM15-1 Free-Standing...
WE LOST OUR MANUAL AT WORK AND HOBART LXH DISHWASHER KEEPS SHOWING DELIME , HOW CAN GET THIS GO AWAY, THANKS
Use a commercial deliming agent (like Lime Away or LSR). Remove the rack from the dishwasher and close the door. Press Off to power down the machine. Next press and hold Wash (Delime) while pressing ON. Delime should show in the display. The unit will fill with water and then flash Add and Delime. Open the door and add the deliming agent according to the directions. (The sump holds about 3 gallons of water.) Close the door and press Wash (Delime). The machine will start the wash mode for 5 minutes and then do two rinse and drain cycles. Delime symbol will flash while this takes place. When finished, the power to the control will be turned off. Check the interior of the machine for lime deposits. If needed, repeat the delime cycle. If the delime program is interrupted before it is completed, then start the delime process from the beginning.
The manuals and other documents are available to registered users of the Hobart site here: https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FresourcecenterZ2Fdefault.aspx&reason=0&formdir=2 . The direct link is: hobart.co.kr/install_pdf/040.pdf .
The spec sheet is available here: http://www.hobartcorp.com/products/warewashing/undercounters/lxi-undercounter/ .
I hope this helps.
Mar 15, 2011 | Hobart 25 in. LXIH-4 Built-in Dishwasher
How much delime agent should I use to clean the system in a Hobart LXI-H?
Nov 24, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
What product to delime the Hobart LXi ?
May 01, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
How do you delime the hobart LXi. Where can I find the manual online?
Feb 26, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwasher says delime on screen, how do i do this?.
Hold the delime button in and hit the on button for 5 seconds.It will then do a partial fill then it will say add delime,add delime shut the door and press the wash button.Let the machine do the rest it will turn itself off when finished.
Jan 29, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
588 people viewed this question
Top Dishwashers Experts
