Question about Dishwashers
My kenmore dishwasher always display LO code
Since they connect my kenmore dishwasher 3wks ago the LO code is always there. I tried to use once but still thesame..Is it suppose to display the clean code when finished washing? Also do i have to press the dry botton to dry mydishes? I dont have the manual that"s why im asking all these questins.. Serial # KH12913075....MODEL # 587.1541
SOURCE: Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Posted on Feb 08, 2008
  • 188 Answers
SOURCE: Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Feb 20, 2009
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
wolfpackicu
  • 26 Answers
SOURCE: Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Posted on Jul 30, 2009
SOURCE: Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Posted on Sep 11, 2010
Error code f2e2, will not fill, run. How do I reset it and place into diagnostic mode. The paperwork is missing from front kick panel
I am guessing this is a Sears Kenmore Elite Dishwasher were dealing with ?? If so follow below if Not what are we talking about?
The FUNCTION CODE 2 is for a USER INTERFACE issue. The PROBLEM CODE 2 can be:
User Interface cannot communicate with main control Panel. (A).Unplug dishwasher or disconnect power. (B). Check connections of gray wires between LCD display module and P12 connector on the control Panel:
Loose User Interface connection. (A). If connection(s) loose, then reconnect.
Faulty User Interface. (A). Disconnect power and replace LCD display and console.
Always unplug or de-energize electrical equipment before removing covers or attempting service. Be careful and wear appropriate hand protection when working around sharp metal parts.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a technician.
I researched this a little bit and You need to check for any signs of water spray a cheap hose clamp seems to be the cause of a lot of this problems also corrosion some DIY individuals have removed the cable to the main control panel found corrosion and cleaned it up now working fine while control panel has a fault in Communication their is No Diagnostic Mode Available because of lack of communication , hope this helps
May 18, 2016 | Dishwashers
Replacement motor arrived. Slightly different. The old motor had a proprietary kenmore electrical connection.
Sears Appliance - Dishwashers - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Dishwashers
Rating: 1 - ‎80 votes
We have ordered new wheels but the price for plastic wheels seemed a little high ....Hose came loose, water pours out and into my basement, pump slips out of slot ..... I will NOT be buying another Kenmore dishwasher when I do replace it.
Sears Appliance - Dishwashers ' Page 2 - ConsumerAffairs ...
We bought a Kenmore dishwasher from Sears a little over 1 year ago and ....Switchboard being replaced 3 times, motors and wiring being replaced they still will ....Another tech came out and said "Well they didn't program the motherboard" so ...
Kenmore Dishwasher Parts - PartSelect
www.partselect.com/Kenmore-Dishwasher-Parts.htm
Dec 22, 2015 | Kenmore Dishwashers
What this can be?
If your dishwasher is hardwired... not using a plug-in type connection, it could very well be that the polarity of the wires is wrong. The washer will still work, it just won't work as it was designed to. (The plus and minus wires need to be reversed in the hardwiring.) Turn off the circuit breaker and open up the faceplate first. Use a screwdriver lamp circuit tester to determine if the red, black wires are connected to right supply wires. Green is always ground in the USA. The other possibility is that you placed you dishwasher too close to the oven and it's holding too much heat from it. Are you sure, the fuze you replaced is the proper slow-blo type; i.e., proper amps at rated voltage?
Mar 12, 2015 | Kenmore Dishwashers
Our Kenmore dishwasher model number 665.13163K701 display is always showing the heater cycle indicator on. Tried some reset instructions I found online and turned off breaker for a few minutes and still...
please follow the next steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. 87af5b68-272e-404a-951c-cd453d3cd7fe.jpg
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic control
Jul 06, 2013 | Dishwashers
Once dishwasher starts wash cyle, it keeps running wash cyle indefinitely. what do i need to do
Possible that the diswasher control panel is not in order and is a suspect. remove power for some to reset the board. Try with different program and if the same action continues check with the panel board before you can think of swapping to confirm the case.
Jun 28, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Dishwasher only hums after used bleach to clean
Kenmore d/w 363.1407 is made by GE...... sounds to me like the motor is stuck. Unplug d/w and remove access panel... try to free the motor by turning the cooling on the motor shaft. Hope this helps..
Mar 17, 2010 | Kenmore Dishwashers
I replaced the cooling temp sensor 3wks ago and my check engine
Sometimes it is not the sensor's fault, but a wire in the circuit, or a connection at the plug.  Look for damage.   Did you buy an authentic Chevy part? Beware of cheap aftermarket electrical parts, they don't always meet the correct specs---
Jan 18, 2009 | 2001 Chevrolet Impala
Water sitting in the bottom of washer, and will not cycle
Check your vent drain or your Garbage disposer connection and make sure it's not plugged.
Nov 21, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
71 people viewed this question
Top Dishwashers Experts
Owen Barnes
