Question about Kenmore Elite 45986 Front Load Washer
I get an F09 error and when I push the pause button the washer says there is 22 minutes left.  I can push start and the machine will start washing again.  Sometimes it will finish washing and other times I will keep getting the F09 error.
  • 5,911 Answers
"F09" is an Overflow Condition error. The following link explains:
http://www.fixya.com/support/r805532-f09_error_whirlpool_duet_kenmore_elite
The first thing to try is to unplug the washer for at LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). In some cases this is all that it takes to correct momentary glitches with the unit. If the error code reappears, follow the guidance I provided you.
This is one of those challenging errors to identify sometimes. Start with the easy possibilities, first. In addition, your washer should have a tech sheet inside to assist in component identification and troubleshooting. You can access the tech sheet by removing the lower panel under the door. If the its not taped to the back of the lower panel, it will be located along the interior wall of the cabinet.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Jan 22, 2009
Pause error unit will not wash
Hello cvaughn37_cv - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Nov 23, 2012 | Frigidaire ATF6000ES Front Load Washer
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * Epic® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
F35 code
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The code is F09 or FA I can not change it i tried to drain it but still will commence a cycle then F09
try pushing the pause/cancel button twice to clear the display. you may have a foreign object in the pump.
Oct 25, 2009 | Whirlpool AWM8163 Front Load Washer
Error Message
Your owner's manual may give a troubleshooting guide for the error code your machine might give you. Is it possible you have locked out the control panel? I "think" the calypso has a control lockout, usually a start button or cancel button. If you press it in for 3-5 seconds, it can lock or unlock panel. If all else fails, try unplugging it and see it it will drain out the water.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My washer had 1 minute left before the spin cycle was complete.
Push and hold the START button for three seconds if you want it to finish off that last minute.
...or...
Push and hold the PAUSE button for three seconds to stop the cycle.
Peace.
Marco
Jan 31, 2009 | Kenmore Elite 45986 Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
348 people viewed this question
Sal De
fordexpert
Robert Rankin
