Question about Hitachi Televison & Video
Is this tv HD? Hitachi cmpas15ss
CMPAS15SS
My hitachi ultrascan hd tvs color is fading ?
Sounds lamp in TV getting weaker and soon it will be replaced.
When dlp tv start showing darker picture then its time for new lamp to get back vivid picture.
Dec 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
How do I set up model 50v500 hitachi tv to receive hd
You have to have an hd cable box it is different from your run of the mill digital cable box. Most people rent them from their cable provider. This will enable you to get HD channels through them
Apr 01, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Is my Hitachi Tv model 43FDX10B HD ready?
Probably but this hitachi has no reall HD just simulated, called D3VirtualHD by hitachi. Should work, you can always return the blu-ray if it's not what you expected or ask a good salesman if it's worth, you might try it in store...
cheers
Dec 23, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Digital signal capable
It does not. It it "HD Ready" and not 'HD Capable" or whatever they call it
Nov 18, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
No HiDef on projection TV
u need a hd receiver to get hd on this tv. satellite or cable box. the screen blank in and out on hd signal. get use to the blackout.
Nov 15, 2008 | Hitachi 43FDX01B TV
Connection for tv cable to hitachi 42" plasma Tv
there is no cable slot. the monitor is not a receiver. it has no tuner in it. it will need a signal from a tuner box. and that must be fed to the tv with an hdmi cable or a dvid cable for hd to work. see your manual for further information on cables. see your cable supplier for information on hd boxes available in your area. if you do not buy hd service, you will not get an hd signal. so you will see little difference from a non hd device. your dvd player may have hd capabilities, but will also need the same cable to deliver true hd signal.
the good news is that its fixable by using the right equipment.
good luck
mark
Dec 07, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 53SDX89BA
I also have a Hitachi 53SDX89BA and I bought it with the same assumption as you: that it's HD ready. The specs in the manual states the following: "Full 1080i HDTV Capatable with Set-Top Box". I beleive this means that it does not include an HD tuner, but that it is capable of handling up to 1080i resolution. Normal (non-HD) resolution on this TV is 480i.
So here's my problem: Until recently, I wasn't using the HD settings on this TV because I don't have a set top box, nor do I subscribe to any HD content from my cable provider. However, I just purchased an XBox 360 along with an XBox 360 HD-DVD player (it's an XBox peripheral that works with the game console). The Xbox asks you to choose the resolution output (480i, 720i or 1080i) to match your TV's HD capabilities. When I select 1080i output and change my TV's settings to receive an HD signal, the picture quality is amazing. However, the video signal seems to get lost ocassionally (i.e. TV picture gets scrambled) but then it comes right back. This does not happen when I select a 480i output on the Xbox...but of course, the picture isn't as crisp and clear as a 1080i picture.
I don't know if this is a problem with the TV or with the Xbox. Has anybody else had this problem??
Dec 06, 2007 | Hitachi 50UX57B 50" Rear Projection...
Open Questions:
Televison & Video Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
