Question about Jabra BT125 Headset
...suddenly - there is no micro
Hy, until the last 8 month, my jabra bt125 functions all times i need it. suddenly, yesterday morning at 8:25, there is no more micro. so i understand the other people, but couldnt speak to them. first, i thought, it may be an problam with the connection, but now i am very sure, that it could be a) an problem with my handling the blue functionbotton or b) the mic is broken (cabel or so). never the less, i need my earphone. if you have an idea - let me now. thanx an so long - thomas
This happened to my bluetooth also. I am not sure what I actually did that made it start to work again but it did.
I think it had something to do with the volume control. I think that I might have accidently placed the call on hold.
I hit the volume control and also the on off switch and it started working again.
I hope this helps.
Posted on Jan 30, 2009
What kind of charger does the Jabra BT125 take? A micro or mini?
well it is a OEM USB CHARGER DATA CABLE for BT SERIES
May 25, 2011 | Jabra BT125 Headset
How do you pair a jabra bt125 with a blackberry 852 curve
Turn on the bluetooth on your blackberry and turn on your jabra as well. Hold the jabra for 10 seconds until it starts blinking. Go search devices on your blackberry and add the jabra onto it.
Hope this helps!
Mar 03, 2011 | Jabra BT125 Headset
I have a jabra 125 A and I misplaced my instructions it worked fine with my streamer until yesterday and I can't see to get it to pair back up both have full charges.....Hassan
Hassan,
Start with the Jabra is turned off. Then hold down the button for couple of seconds until you see the light flashing.
While the light is flashing, try searching the headset using your phone and use 1234 or 0000 for the Bluetooth pin code.
Hope this helps and good luck!
Jan 02, 2010 | Jabra BT125 Headset
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
1. Put the headset in pairing mode
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
Cant par my jabra bt125
First make sure your bluetooth and your phone are fully charged. Next press the on - off button in the middle of your bluetooth until it is a solid blue color. If it is flashing it is not in the pair mode. Just hold it down until it is a solid blue light.
Then set your phone to the pairing mode following your phones set up bluetooth instructions. Select the discover, search, or add function on your phone. Your phone should find the bluetooth device and ask "do you want to pair with it?" Accept by pressing yes or ok on the phone and entering the passkey or pin # of 0000 or 4 zeros.
Your phone should confirm when pairing is complete.
I discovered that I was not holding the on-off button down long enough for my bluetooth to reach the pairing mode and give me a solid blue light.
I hope this helps as I know how frustrating this can be.
Jan 15, 2009 | Jabra BT125 Headset
Can't pair Jabra BT125 with O2mini
check the bluetooth is in visible mode or not
Jan 07, 2009 | Jabra BT125 Headset
Samsung M300 cellphone is not finding Jabra bt125
ok.. the problem is that it is in on state you need to turn it off then turn it back on but dont release the button until the blue light is solid.. u probly should hold it about 6 seconds.. then add it to devices and when it asks for the pin # put 0000
that should do it
Oct 06, 2008 | Jabra BT125 Headset
How to pair my Jabra BT125...
Instructions for the Jabra BT125 Bluetooth
For people who are having problems pairing their cell phone with their Jabra BR125 Bluetooth, here are a few simple steps:
First, make sure that the Jabra BT is off (the light should be off). If it's on, hold the flashing button until it goes off.
Second, turn your Jabra BT on. Continue holding your Jabra button (EVEN AFTER IT STARTS FLASHING). Hold onto it UNTIL YOU GET A SOLID LIGHT.
Third, as soon as you get a solid light try pairing up with your cell phone.
Fourth add your Jabra to your cell phone's Bluetooth list by having it search for the Jabra.
Fifth, the cell will ask for a passcode. The default passcode is 0000.
Aug 17, 2007 | Jabra BT125 Headset
Jabra BT125 Headset Logo
46 people viewed this question
Top Jabra Radio Communications Experts
Greg Cann
Greg Cann
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
