Question about Acer Aspire 3000 Notebook
Laptop freezes up when battery connected
Spent hours before discovering the problem is related to the battery. Once that was found out i did some online searches to see if this was a common problem. I've found a few cases where other people have experienced the same type of thing. Is it better to run the laptop with no battery or with the microsoft ACPI complience device dissabled? Is this a permanent fix or do i need to order a new battery? If so does anyone know the best place to buy one from?
  • 432 Answers
With ACPI power management, the computer has the ability to function as follows: ? The computer is ready for immediate use when the user turns it on. ? The computer appears to be off when not in use, but it can still respond to wakeup events. Wakeup events can occur when a device receives input, such as a telephone ringing, or when software requests that the computer wake up at a predetermined time (for example, to download e-mail so it is ready in the morning). ? The system can change how software responds when the power state of the computer changes. The operating system and applications work together to operate the computer and deliver effective power management according to the user's current actions. Applications do not keep the computer busy unnecessarily; instead, they proactively participate in shutting down the computer to conserve energy and reduce noise. It is best to turn the ACPI on and buy a new battery. I would shop on the internet. Try; http://www.pricewatch.com
Posted on Jul 03, 2007
SOURCE:
Where do i find the keyboard passcode?
Typically when the keyboard is turned on, the device discovers it. Once the device discovers it, you should be able to press connect on the keyboard and the Bluetooth pairing request with the code should pop up on your device. Then you should be able to enter the code on the keyboard, press enter and connect.
May 27, 2014 | Kensington KeyFolio Bluetooth Keyboard and...
Printer connected to wifi but won't print
check that the driver for the printer is installed and updated as sometimes the driver can disappear from the system
Feb 27, 2014 | HP DeskJet 3520 InkJet Printer
D620 bad battery causing freeze
Original or replacement battery? Replace battery, or, Contact Dell Support, if it's a fault or recall on the specific battery, it would be noted at Dell. There has been battery recalls, in the past, that were fire hazzards. I don't know if your battery applies? This issue COULD be dangerous, if left unattended.
Dec 31, 2012 | Dell Latitude D620 Notebook
Acer aspire 5515 blue screen
hi
yes it may be related to bios setting . Just enter your bios in the laptop (F2)
and for HD change the SATA to ATA or vice-versa. SAVE and retry boot.
(it can also be AHCI to ATA or ATA to AHCI.)
Aug 12, 2012 | Acer Computers & Internet
How do i unlock key board on acer laptop 7540 no keys work at all tried everything
I doubt it if your keybaord is locked, you probably have other issues in your laptop preventing you from using your keyboard. You can check this by connecting a standard USB keyboard from a desktop.
Aug 11, 2010 | Acer NSK8458AN Keyboard
I need help with one thing, and I also have a sepa...
You should buy the replace battery for your laptop.
Discover is great: Replacement laptop battery
May 19, 2010 | Toshiba Satellite L305D-S5881 Notebook
Turned the camera on but screen display says MSDC and can turn not camera off
Make sure the battery is inserted correctly. We spent 5 hours complaining about the camera we bought for our daughter because we couldn't get rid of the MSDC message. We had put the battery back in it upside-down after inserting the memory card; she is the one who discovered our mistake.
Dec 25, 2009 | Vivitar ViviCam 8025 Digital Camera
My GMC sierra side mirror is loose on from the amr. The mirros is fine it is the little swivel that is looses and the mirror constantly moves. I am unable to remove the mirror to get to the problem.
I just spent about 2 hours trying to resolve the same problem, and discovered that there doesn't appear to be any way to repair the mirror without purchasing a whole new one. There a 3 screws you can access by slanting the mirror to the extemes in both the up or down positions. Once they are removed I discovered a 4th screw (once I broke the plastic pieces surrounding the mirror appart) that there is a 4th screw that is impossible to reach without removing the actual mirror part. In any case I discovered that the reason that the mirror was floppy is because there was a funny looking nut that is supposed to lock in the spring mechanism that was completely stipped and non functional. Better luck than me!
Sep 27, 2009 | 2000 GMC Sierra
Sansa MP3 frozen after recharching from laptop
Read a few more blogs and found one with similar prob. To de 'freeze' just hold the 'ON' button for 15 secs and it clears.
Sep 20, 2009 | SanDisk Sansa Clip MP3 Player
Logitech Cordless Keyboard
This could be either hardware or software related. If you could tell us what the exact blue screen is I can be more specific in my answer. The possible causes for this could be virus/malware, corrupted registry(which could be due to failing harddrive), faulty memory, or faulty motherboard.
BTW, the "reload" they did will not fix much, which is why you had the same problem within days.
May 10, 2008 | Computers & Internet
Acer Aspire 3000 Notebook Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
