Question about Xerox WorkCentre 7232 VSE All-In-One Laser Printer
Xerox WorkCentre 7232 is not printing color properly and there is a dark line when you photocopy. What could be causing this? And how do I fix it?
  • 2072 Answers
SOURCE: what are the control codes
that is located in the driver, under properties. You will have a place to select either color or black and white as your default.
Posted on Jun 24, 2008
SOURCE: Xerox 7232 and As400
016-799 is a printer paper conflict error. All you have to do for the AS/400 to print, is to make suree that tray 2 in the printer is set up to do landscape printing. There has to be at least one tray for portrait, and one for landscape in order for the AS/400 to print.
Posted on Sep 17, 2009
SOURCE: Xerox WorkCentre 7232 will not Scan to PC
Did you ever find a solution to this problem. We are having the same problem on our Docucolor 242. The first two "SCAN to PC" jobs work fine, but we get several 016 errors for any jobs after that. This machine had been working fine for 18 months before this started happening a week ago.
Posted on Nov 17, 2009
lbrown1806
  • 488 Answers
SOURCE: I need a list of erro codes and definations for
When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
003-754
003-755 An error occurred in the document scanner. Reset the document, and scan again.
003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
smaller segments.
003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
005-210
005-275
005-280
005-283
005-284
005-285
005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
Posted on Jan 16, 2011
  • 66 Answers
SOURCE: Everything I print on my Xerox WorkCentre 7232 gives me a dark gray line about 1/4 wide down the left side of the page. What can I do to correct this?
Change Toner.
Posted on Jan 02, 2013
How can i resolve error 010-333 for xerox 7232
Fuser unit change problem continue nvm change 744-004 change value 0
Feb 09, 2014 | Xerox WorkCentre 7232 VSE All-In-One Laser...
How to add name in the scan address book in xerorx 7232 mfp printer
Just go to machine information button, then tools tab, and in the right column scroll down until you find Add Address Book... When you edit a entry, the second line is for the Name.
This is in the User Guide. Just go to xerox.com.
If this does not solve, you need to be more specific
Jul 03, 2012 | Xerox WorkCentre 7232 VSE All-In-One Laser...
What are the control codes to turn on colour printing on a workcentre 7232
Jun 24, 2008 | Xerox Office Equipment & Supplies
Xerox WorkCentre 7232 VSE All-In-One Laser Printer Logo
76 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
