Question about Kenmore 63942 Dryer
Kenmore dryer start switch needs to be replaced
I have a kenmore dryer and the starter switch needs to be replaced. I have the new part, but my problem is that I can't get the old switch off... It seems to be 'locked in' please help me. IF you could describe how to get the old switch off, I would appreciate it.
  • tarazimm Jan 24, 2009
    I can get to the back of the console... But I don't know how to get to take the starter switch out... It is 'locked' into place. What do I do in the back of the console to get the starter switch out.?
  • 54 Answers
Depending on age of unit.. there are 2 screws on each side of the console (older unit) on newer unit you have 2 white plastic covers.. pop those out and unscrew the 2 screws and lift up the console.. you have to get to the starter switch from the back of console.. good luck..
Posted on Jan 21, 2009
Replacing start switch on kenmore dryer
If you order the new Switch from sears parts direct.... Then when you replace the switch, make sure you unplug the dryer before you take the front panel off. Replacing the switch is quite easy... 4 screws total.
Jul 17, 2014 | Kenmore Dryers
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
I have a Kenmore dryer model number 110.73932102. Push starter button, runs. Release dryer button dryer stops. Why?
Open the control panel to access the start switch. If it has 3 wires,replace the start switch. It has a defective coil.
Oct 04, 2009 | Kenmore Dryers
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
When I push the start button the dryer will not start
May need to replace the starter swithch behind the control panel. MAKE SURE ALL POWER IS DISCONNECTED. If you still hear a humming sound when you hit the start button then it is not the switch, but the motor and if that is the case you may want to look into your warranty.
Aug 16, 2009 | Kenmore 63942 Dryer
Dryer turns on when botton held down
Motor has a "Run" winding centrifugal switch that may need to be replaced. Start button energizes the starter winding but when the "run" switch fails the motor won't keep running. Switch is easily replaced without taking motor apart.
Aug 12, 2009 | Kenmore Dryers
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer keeps on going and going
The timer is bad. It is located behind the knobs and can be replaced really easily. The price for a new timer is about 35 dollars. If this helped please rate
Feb 12, 2009 | Kenmore 64902 Electric Dryer
Dryer won't start unless I slam the door
Not normal. Check door switch. As a test you can jump it out to see if the dryer works then. if that does not help then , I i would consider replacing the starter switch.
Jan 08, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
562 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
