Question about Kubik Digital Electronics Kubik Roca 8Gb Touchscreen Mp3 And Video Player
Kubik evo Player-user manual - Kubik Digital Electronics Kubik Roca 8Gb Touchscreen Mp3 And Video Player
How do I fix my Kubik Evo 8Gb? The software doesn't work. The screen is black and I can not get access to the menu. My files are ok I can see them when I plug it to my computer. Thank you
Your electronics are ng. U might try to reset unit by doing a hard reset to see if that clears up the anomaly. If not, replacement, not repair, is in order.
Aug 27, 2016 | Kubik Digital Electronics Kubik Evo 8Gb...
Wont turn on when not plugged in. but will turn on if charg plug is plugged in and you turn on the power switch and unplug the charger it will stay on but wont play, keeps coming up format error.
Customer Reviews: Kubik Evo 8GB MP3 Player with Radio ...
www.amazon.com/Kubik-Player.../B0041MMMWW
Amazon.com, Inc.Find helpful customer reviews and review ratings for Kubik Evo 8GB MP3 Player with ... Con's - Wonder if some of these items can be fixed with a firmware update. ... Just push the main button (or any button) and it will turn on and function as usual. ... 2) Play while plugged in charging works with the wall charger, but still NOT ...
Evo won't charge via USB ' Android Forums
androidforums.com > Android Phones > HTC EVO 4G
Jun 29, 2010 - Whenever I plug in my Evo, I select Charge Only (or if I do nothing, it selects Charge. ... If I turn off my Evo it charges from the USB fine. ... Check your computer's stats... what does it say about its USB status when your Evo is plugged in or ... I had a problem a while back where it would charge via USB, but not ...
Dec 29, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
I need the driver for my kubik evo 8g mp3 player. The driver disappeared off my computer and now doesn't recognize my player.
You should not need drivers for this device as it ought to be picked up automatically by your computer (assuming that it's Windows, what version are you running?). If you have an expansion card in the player, then try removing this and then re-connecting the Kubik to your PC to make sure that the expansion card is not faulty.
Another quick test is to check the cable, both in a different USB slot if you have one available and / or by connecting another USB device that uses the same connection (in my case, a digital SLR camera has the same USB adapater so I can use the cable for either). If, doing this, the second device also is not recognised then try swapping the cable for a new one (but again, if possible test the cable and connection to other USB device in another USB slot as well).
One other quick question - does the Kubik device work still when unplugged from he PC?
Feb 17, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
Deleting music from kubik evo 8gb
Select track to be deleted, press and hold the volume button, a box will appear asking if you want to delete, select yes and press the large centre button,it will then state file deleted .
Sep 28, 2014 | Kubik Digital Electronics Kubik Evo 8Gb...
How do I put MP3 files on Kubik Evo 4gb?
The easiest way is to plug it into a PC - any Mac, Linux or Windows machine will see it as a USB flash drive. Copy the mp3 files you want to listen to into the Music folder. The trick is when you disconnect - unmount the flash drive (or eject it if using Windows) and then wait for the Evo to switch from USB connect symbol to the charging symbol. If it does not change after 5 minutes, unplug it, flip the side switch to off, then back to on and it should be OK.
Aug 01, 2014 | Kubik Digital Electronics Kubik Evo 8Gb...
Kubik evo
You need to use the option under the Music Menu to reIndex the device and then that should show the songs in the lists
Jul 05, 2014 | Audio Players & Recorders
Why am i having transferring files problem with kubik evo
What are you using to transfer the files?
Attach the device to your computer using the USB lead
Wait for your computer to find the device
Then use Windows Explorer to drag and drop the files onto the device
Make sure the files are in a compatible format to the device
Once transfered power up the device and rebuild the Index of Music using the option under the music menu
Jun 22, 2014 | Kubik Digital Electronics Kubik Evo 8Gb...
How to put a playlist on a kubik evo
Try rebuilding the Music Index using the option under the Music Menu when the device is powered on
Apr 12, 2014 | Kubik Digital Electronics Kubik Evo 8Gb...
Kubik Digital Electronics Kubik Roca 8Gb Touchscreen Mp3 And Video Player Logo
49 people viewed this question
Top Kubik Digital Electronics Audio Players & Recorders Experts
richie46
ray gallant
Robin Brighouse
Robin Brighouse
Are you a Kubik Digital Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
