Question about HP PSC 2355 All-In-One InkJet Printer
Memory cards printer will not acknowledge any camera memory cards when put into the front of printer I have a hp psc2355
  • 45 Answers
I keep getting a memory card error message. i am trying to scan photos to my memory card via my hp photosmart c5180
Some computers will not acknowledge your flash cards. Depending on your flash card, your printer & computer to make sure they are compatible. Try opening your computer Icon to see if card is accepted. then click in your card to see if any file are in. You may have to load your printer software again..
time for the Geek to help!!
Jun 29, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have a HP PSC 1610 All in one printer and I tried putting my media card in the SD slot and it tries to read the card but the red light flashes and says memory card error. HELP Please!
If using the Card Reader -
The HP all-in-one has detected an error with the memory card.
1. More than one memory card is inserted in the HP all-in-one.
2. An incompatible camera is connected through the camera port.
3. A memory card is inserted and a digital camera is connected at the same time.
Solution:
Remove and reinsert the memory card. It may be inserted incorrectly. If the problem continues, the memory card may be defective.
Remove one of the memory cards. Only one memory card can be used at a time.
Check the user guide that came with the camera to see if it supports PictBridge. If it does not, try using the cable that came with the camera to connect the camera to the USB port on the back of the HP all-in-one instead of to the HP all-in-one camera port. If the camera does support PictBridge, make sure the camera is set to PictBridge mode. See the user guide that came with the camera for instructions on how to do this.
Remove the memory card or disconnect the camera. Only one can be used at a time.
You might try the following - Reformat the memory card in the camera or format the memory card in a Windows XP computer by selecting the FAT format.
Hope this helps!
May 01, 2010 | HP PSC 1610 All-In-One InkJet Printer
The internal memory is full but the camera does not seem to be acknowledging the memory card.
Putting pics on the internal memory is just asking for problems like this. You need to download them and then format the internal memory (no card in camera).
Mar 06, 2010 | Sony Cybershot DSC-H3 Digital Camera
When trying to download pics from my memory card my program HP Image Zone Plus keeps telling me that there is no memory card in the device. Why is it not acknowledging my memory card and how can I change...
Are you using your camera and a usb cord or a separate card reader? I use a card reader and it works every time. I download to a folder I create on the desktop...once there, any program can use the pics.
Dec 10, 2009 | Fuji FinePix S5000 Digital Camera
When putting the memory card into the slot, the screen reads 'memory card error'. Also, will not read the camera when plugged into USB socket. Please Help!
The camera port only supports USB-equipped digital cameras that support Pict-Bridge. If you attach a USB device that is not compactible digital camera (or Bluetooth adaptor) to the camera port, an error message appears on the color graphics display. If you have an older HP-brand digital camera, try using the USB that came with the camera. PLug it into the USB port on the back of the HP-all-in-one and not into the camera port near the memory card slots, This works with HP digital cameras only.
By default, Windows XP will format a memory card of 8 MB or less and 64 MB more with the FAT32 format, Digital cameras and other devices use the FAT (FAT 16 or FAT 12) format and cannot operate with a FAT32 formatted card. Either format your memory card in your camera or select FAT format to format your memory card in a Windows XP PC.
Hope this helps.
Thanks.
Have a good day.
Nov 30, 2009 | HP Photosmart 2610 All-In-One InkJet...
When sandisk 4gb micro card iserted to hp psc2355 screen displays memory card error
first try to format the micro sd card with computer ..then try to use it ...
Oct 25, 2009 | Office Equipment & Supplies
The camera doesn't accept new memory card put into the camera
Sorry that this answer is far too late to be of use to you, but it may help others searching for advice with the same fault. I only stumbled across your unanswered question by accident.
8GB is an SDHC card. Your camera was designed to use the earlier SD cards instead with a maximum 1GB capacity.
Dec 07, 2008 | Kodak EasyShare C533 Digital Camera
I own a pink Fujifilm Finepix z20fd and everytime I slide open the front it reads a warning that reads: "CARD NOT INITIALIZED" and when I put the memory card into my HP PSC 1610Xi All-in-One...
The problem seems to be in the card not the camera ..... try formatting the card ...... also check whether the card is readable on the computer or no .... otherwise replace the card
Oct 19, 2008 | Cameras
HP Color Laserjet 2840
There is only ONE SLOT for expansion memory for the HP 2840. The slot is located behind a cover on the right side of the machine looking from the front. Once you remove the cover you will see the one and only slot available for printer memory expansion. The slots on the front top corner ARE NOT for printer memory expansion but rather for different styles of photo/camera memory to off-load pictures etc...
If you need the printer memory cheaply (about $25.20 for 128MB) go to www.memory.com. They have it in stock.
Hope that helps you. If so, please rate me with a FIXYA. :) If not give me a yell and I'll help you further.
Sep 29, 2008 | HP LaserJet 2840 Printer
Doesn't acknowledge memory card?
I suspect your memory card is damaged. If it is new, return it. If you can find a computer or printer with a slot for that type of memory card, see if the computer recognizes it. You may be able to repair it by using the computer to format the card. Usually you right click on the card's icon in My Computer and choose to format. This erases everything on the card and makes it ready for use.
Sep 10, 2007 | Panasonic Lumix DMC-FX7 Digital Camera
HP PSC 2355 All-In-One InkJet Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
