Question about Verbatim 500GB USB Desktop 500 GB Hard Drive
Trying to use a brand new Verbatim usb 500GB portable hard drive
Firs time trying to use it. XP recognized it with message at bottom of screen and said software installed but no icon for it under "My Computer"
Blue light is on for device but XP doesn't seem to recognize it.
I have a 320GB USB HD (same design) that works just fine
Any help??
  • 23 Answers
For WindowsXP:
Goto Start> Control Panel>
Select Hardware Tab > Divice Manager
Select the + on Disk drives, and see if you see your USB Verbatim drive listed (if so good, close all thoes windows and goto the next steps) If not stop here.
From the Contorl Panel> Administratinve Tools> Computer mangement>
Under Stoage select Disk Management on the left panel
Look in the Right panel and single click your USB drive in the "Volume" colume.
Know look at the lower panel and make sure the drive states that it is "Online", look at the "Health" Status. And;
Make sure it has been "Partitioned" in the Layout colume. If not right mouse click the drive letter and select "Mark Potiton as Active".
Right mouse click on the USB drive in the Volume colume> select "Change Drive Letter and Paths"
If there is on drive letter assing to it select the Add button, if one is there, select the Change button and assign one to it or change it to a drive letter that is beyound the number of drives you have.
In other works if you have drives C:, D: and E: before you add the USB drive, make it the H: drive.
Exit out.
Now check your drive files.
Posted on Feb 14, 2009
Why wont windows recognize my verbatim 500gb serial no JB0094011152
Go into Device Manager and if it doesn't appear there click "scan for hardware changes". If that doesn't work, makes sure you have plug and play enabled. Always use the safely remove hardware option when unplugging it.
Jul 11, 2016 | Verbatim 500GB USB Desktop 500 GB Hard...
It want come up on my computer
Step 1:
Problems with Verbatim portable hard drives vary depending on your model of hard drive, your operating system and your computer hardware. Some problems can include insufficient USB power output, the file system format, and potential overheating due to enclosure materials.
File System b> Verbatim portable hard drives come formatted for use with Mac computers. If you're using it with a Windows or Linux computer, you will need to format it to a file system that your operating system will recognize; Windows computers typically work with NTFS, while modern Linux distributions use ext4. If you have computers with mutliple operating systems, FAT32 is usually considered easier for all operating systems to recognize. Verbatim does not recommend switching a portable drive between PC and Mac computers once you've formatted the drive one way or the other. Adequate Power While most computers supply adequate power with one USB port, older computers can have insufficient power output. If your computer doesn't seem to be powering the drive, use of a Y-shaped USB cable, designed to be plugged into two USB ports, can get more power to run the drive. Additionally, consider trying different USB ports on the same computer; some USB ports get more power than others. Drivers b> Make sure that you have any relevant drivers related to the hard drive that you have purchased. If your drive didn't come with a setup disc, you can check the Verbatim website for product drivers. Overheating b> Of Verbatim's seven portable hard drives, four are enclosed in plastic; of the other three, one is enclosed in aluminum, one in leather, and one in rubber. While all the drives are tested to run well with their enclosure, metal enclosures conduct heat away from the hard drive and help to prevent overheating. Plastic, on the other hand, is an insulator, so plastic enclosures may contribute to heat buildup. Check plastic-enclosed drives for overheating and avoid leaving them plugged in when not in use.
Apr 05, 2013 | Verbatim SmartDisk Firelite Portable USB...
I have a Verbatim 250USB drive and have never had a problem with it until I attempted to copy some HD movie files to it from my computer's hard drive. I am attempting to copy .mkv movie files to the...
firs:
try to format your hard drive, then try again.
if you still cannot do it, do a low level format, using this tool:
http://hddguru.com/software/2006.04.12-HDD-Low-Level-Format-Tool/
if you still cannotdo it, it may be a harware problem. try to copy a big .mkv file like that from another pc, to be sure it isn't your pc's fault, if you can do it, then it's your pc, if you still cannot it's the disk.
in the firs case the troublesooting is quite difficoult but if you post your system configuration i may help.
in the second case if allso a low level format fails, then i don' think we can do something for youo... you should get assistance from the manufacturer....
hope this help,
Paolo.
May 19, 2010 | Verbatim SmartDisk Firelite Portable USB...
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
Usb devise not recognised
You probably damaged the drive from sudden disconnection of the signal line. I would suggest trying it on one other computer before considering it trashed.
Jun 08, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Undetectable External hard drive
i am unsure about this but its worth trying
go to start control panel administrative tools services and look for plug and play and make sure it is set to auto at start up and enabled it so it is started this lets your computer recognize new hardware on your computer which should let see it in your my computer screen
i hope this as help if not well i tryed
Apr 17, 2009 | Verbatim SmartDisk Firelite Portable USB...
USB External hard drive 160 GB not recognized by desktop Windows XP OS
Very possible your problem is that this drive is not externally powered and your desktop does not put out enough power to drive it.  I'm guessing your desktop is older.  Especially if your desktop is USB 1.0 this problem would occur.  Your best bet in this case is to either mount a newer USB expansion card into your desktop, or get another externally powered harddrive and transfer data over to it from this one with your laptop.
Nov 01, 2008 | Verbatim SmartDisk Firelite Portable USB...
Verbatim 500GB USB Desktop 500 GB Hard Drive Logo
183 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
