Question about GE PSC25MSTSS Stainless Steel
Freezer in GE side by side melts the ice
My GE model # psc25mstss thaws the ice to a point where it melts and drips into the freeze. It then cycles back to freezing and re-freezes everything in the freezer. I suppose the defrost cycle remains on too long. Do you have any suggestions where I should start?
Thanks,
Greg
bobotfel
  • 236 Answers
SOURCE: GE side-by-side freezer not freezing.
Defrost the unit until all ice melts( force defrost by unplugging the unit for several hours). Then plug and start the unit check if the blower inside is operating. If no air present in the vents check for stock up blower motor. If blower is operating and air is present in vents. Mas be the unit is out of gas.
sample only:
Posted on Jan 21, 2008
  • 54 Answers
SOURCE: Freezer
If the freezer is in defrost then the freezer fan should be off. Only on the electronic will the freezer fan come on in defrost but the freezer door has to be held open for 3 min before the fan comes on
Posted on Jul 03, 2008
  • 531 Answers
SOURCE: GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Posted on Apr 07, 2009
  • 62 Answers
SOURCE: GE side by side. The freezer will freeze up with
Try turning the defrost timer until it clicks if it advances and does not defrost the heater or the limit switch is bad if does defrost and the timer does not advance the timer is bad
Posted on Aug 05, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Stops cooling ice melts and leaks water on the floor
That model refrigerator uses the mother control board for deciding when defrost is to take place. It has no defrost timer or Adaptive Defrost Control like other refrigerators. This sounds like *********** board part number WR55X10942 is malfunctioning. The board decides most functions of your refrigerator. Until the board is replace I do not believe the problem will resolve itself. Thanks, Sea Breeze
Posted on Sep 26, 2009
Freezer freezes but at some point thaws and then cools again. So everything is melting then freezing again; ice cubes melt and drip then refreeze.
The auto defrost timer may be broken. The freezer is going for a too long time in the heat cycle. Also ice can be stuck behind the cooling circuit and the cold air is not circulating well. Check if water is going in the evaporating pan at the bottom of the fridge. It should have a little water everyday.
Oct 11, 2016 | Whirlpool Refrigerators
I do not believe the other advisor understand my problem. I have a GE Profile Arctica refrigerator PSS25NGMDBB. The problem is the cup fill (GE part name) is frozen and full of ice. So when the ice...
You are right. The water inlet valve is leaking a small drip and it freezes when it reaches the cold air in the freezer at the fill tube. Melt the ice in the tube with a hairdryer and replace the water inlet valve. It's on the back where the water supply connects to the back.
Feb 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a problem with a GE Profile PSS26PSSASS. The ice maker barely makes any ice. The ice that is made, is melting, dripping, creating icicles in the freezer, and then re-freezing in the ice bin as a...
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Feb 17, 2011 | GE PSSS3RGZSS Side by Side Refrigerator
Refrigerator: General Electric Model GSS25XSRE Side by Side At times the refrigerator and freezer work properly, but most of the time the freezer section is freezing at the bottom and thawing at the top...
This could be a complicated problem to figure out exactly...
My feeling is that the defrost cycles and defrost termination is not working correctly...this is all a result of the main board being bad and giving wrong signals to the different equipment of the refrigerator...
I would change the main board and your problems will be over...
heatman101
Dec 21, 2010 | GE Refrigerators
Freezer Defrosts on its own
Yes it is supposed to. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If it seems to defrost too long and start thawing the contents then the defrost thermsotat may be bad. It's purpose is to stop the defrost heater when the temp reaches around 32 degrees. If it doesn't work the heater will stay on for the entire defrost cycle and possible melt things.
Check here for how to check it and where it is. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Ge profile refrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Refrigerators
sample only:
Jan 21, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PSC25MSTSS Stainless Steel Logo
99 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
