Question about Celltronix 06-ce-bth200h Motorcycle Bluetooth Headset
Celltronix headset pairing
To samsung cell phone
How to pair phone to samsung bluetooth headset wep301? I do not have my user guide.
Bluetooth Headset
Pairing Instructions
1. When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone's guide. Typically, the
steps involve going to a 'Setting', 'Connection',
or 'Bluetooth' menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
Jun 01, 2011 | Samsung SGH-U600 Cellular Phone
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
How do I setup wep301 headset to a simple at&t phone
Follow the steps to connect your WEP 301 bluetooth headset to phone.
1.When you turn on your Samsung Bluetooth
mode immediately.
blinking.
by following your phone’s guide. Typically, the
steps involve going to a ‘Setting’, ‘Connection’,
or ‘Bluetooth’ menu on your phone and then
pairing.
Thank You
Aug 14, 2010 | Samsung Cell Phones
I have a kyocera bluetooth and I lost the code to pair it with my phone how can I find it? 739G-001 is on the headset. I can pair it with my phone if I can find the passkey I have a samsung phone. The...
I just paired one that sounds like yours with my phone and don't remember needing a pass code, but try 0000
From the quick start guide at:
http://www.kyocera-wireless.com/support/pdf/bluetooth-kyo105-quick-start-guide.pdf
PAIRING THE HEADSET WITH YOUR CELL PHONE
Note: Ensure your headset is powered off, and your cell phone is powered on.
a. Press and hold the Multi Function Button for 6 seconds until the LED Indicator flashes red and blue. A tone will sound indicating your headset is in pairing mode.
b. Activate the Bluetooth connection from your cell phone. Execute the search function to search for Bluetooth devices. When the search completes, a list of supported devices will be displayed on your cell phone screen.
Note: The headset will not be detected unless first placed in
pairing mode.
c. To start the pairing process, select KYO105 from the device list.
d. When prompted select 0000 as the passkey.
Jul 18, 2010 | Samsung Lands Phones
Lost instructions for how to get my cell phone connected to my samsung mep 350 calls for pin and i dont have one
1 Enter Pairing mode.
• Turn off your headset and press and hold the Multifunction
button until the blue indicator light remains lit
after blinking.
• If you turn it on for the first time, it proceeds into Pairing
mode immediately.
2 Search for and pair with your phone according to your
phone’s user guide. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will
flash 10 times rapidly before entering Standby mode.
• If the blue indicator light remains lit, retry pairing.
Pairing with your Bluetooth phone
When the headset and the phone are paired, the
headset attempts to reconnect automatically each
time it turns on. Otherwise, press the Multi-function
button to reconnect.
USER GUIDE
Jan 03, 2010 | Samsung WEP350 Bluetooth Headset Red
HOW TO PAIR MY MOTOROLA H500 TO SAMSUNG CELL PHONE?
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Dec 26, 2008 | Motorola Mobility Bluetooth Hands Free...
Can not pair cell phone with Bluetooth.
I neglegted to put the Bluetooth in pairing mode.
Nov 30, 2008 | Samsung Bluetooth?® WEP200 Headset...
I need the access code to pair it to my cell phone.
Follow the steps below:
5) Select the Explorer 3XX device and click add
So - 0000 (four zeroes)
hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Nov 20, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Celltronix 06-ce-bth200h Motorcycle Bluetooth Headset Logo
Top Celltronix Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Celltronix Radio Communication Expert? Answer questions, earn points and help others
